View Full Version : NEW Spektrum MARINE Receiver
Darin Jordan
06-19-2009, 11:30 AM
I can FINALLY say something... ;)
Spektrum Radiosjust announced the release of their new MR3000 Marine Receiver.
http://www.spektrumrc.com/DSM/Products/marineReceivers.aspx
More details and information can be found here:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=SPMMR3000
I have been testing these receivers for them since the start of the season this year and have had very good results. I've tested them in my P-Spec OPC Tunnel at ranges out to 980ft (that's as long as the lake I was on... so I couldn't go any further), and still had full control of the model.
These RXs are VERY light, and are potted in a water-resistant casing, which is a great feature. They are essentially water-proof.
There are two antenna. I run mine with the main (longer) antenna as far out of the boat as possible, and I just lay the secondary antenna inside the cowling. Seems to work great. The attached pictures show the initial testing version, where I ran the second antenna outside the radio box and down the side, but the released version I just coiled the second antenna inside and it seems to work fine.
From what I've been told, the only official products at this time with Marine support are the DX3S and the MR3000 (that's the receiver itself). Some other radios will eventually be added as we can train, support, etc. Some radios will NOT be upgraded, in particular the old 2.0/3.0 series.
Diegoboy
06-19-2009, 11:40 AM
Very nice indeed
Flying Scotsman
06-19-2009, 11:56 AM
Darin, how long is the main antenna?
Douggie
Darin Jordan
06-19-2009, 11:58 AM
Douggie
I haven't measured it directly... It's a little over 10" long on the samples I have.
The actual "antenna" is only the last 1" of wire that is exposed... the rest of the length is really just to give you the opportunity to get that last 1" up as high as you can...
Flying Scotsman
06-19-2009, 12:11 PM
Thank you for the answer. The reason I asked is I have been looking at 2.4ghz systems for over a year and my concern was my existing FM antenna lead lengths are much longer than the wire lengths offered by other 2.4ghz systems. The Spectrum length would allow me to use their RX without modification to my existing antenna placements
Douggie
06-19-2009, 12:19 PM
Thanks for the info Darin.
Ub Hauled
06-19-2009, 12:27 PM
I always wondered why nobody invesed in a marine version Rx... specially one with a small footprint.
Airplanes Rx are among the smallest ones I have seen, there should not be a reason for a "ground" Rx not to follow the same size... anyway, thanks for the testing Darin.
Doby
06-19-2009, 12:47 PM
Good to have someone "on the inside" for updates like this.
Thanks Darin (although I have never had problems with my 7 Spektrum recievers to date)
ghostofpf1
06-19-2009, 12:54 PM
Did I read right??? They made the rx compatible with the air Spektrum and not the ground type ??
Steve
Darin Jordan
06-19-2009, 12:59 PM
One more thing I forgot to mention... this RX has parallel connections built into it, so if you are running dual servos or dual ESCs, you don't need a Y-harness... You can see that there are two TH and two ST connections... I'm not sure if the BD (Binding) and the AUX connections are also parallel circuits...
The additional connections might account for the larger footprint. Also, Ground or Marine dedicated RXs have different requirements that Air... The signals don't always travel as well over land or water as they do up in the air, so perhaps there is additional power or circuitry needed... Andy might be able to speak to that one.
sailr
06-21-2009, 05:47 PM
That's great. They needed to do something because Spektrum in boats was not the best combination in the past. Good to see that JR is listening and responding! That's a sign of an informed and intelligent vendor! It's cool you can be involved in the testing. Thanks for the update! The parallel connections is a great feature too!
Darin Jordan
06-21-2009, 06:53 PM
Just for future reference... JR and Spektrum are NOT the same company. They have cross licensed products in the past, but they are separate and distinct companies.
This new stuff is all Spektrum...
sailr
06-21-2009, 09:46 PM
OK. Always thought it was JR. Didn't know they were separate. Good to know.
alvinsmith75
06-21-2009, 09:56 PM
UM, are they $25.00 like Tactic?
Doby
06-21-2009, 10:28 PM
Umm,,,probably not:laugh:
LiPo Power
06-22-2009, 01:35 PM
Ummm, $79.99 @ Horizon
BILL OXIDEAN
06-22-2009, 02:10 PM
What in particular is different?
The case as I can see, but is the conformal coating different?
Hopefully the coating on the actual circuit board is different, beceause the old ones were one of the only 2.4 rcvrs that actually die after being dunked too many times.
A water "resistant" case alone won't be enough of a safeguard agaist the rigors that actually make a receiver go out, like stranded boats that cut out far out of the range of a ball and reel that gradually take in tons of water, boats that sink for short ammounts of time, plumbing ruptures, anything that will cause a rcvr to be submerged for an extended period of time.
The one in Darrin's photo looks like it has no case at all, so they must have changed, or made a thick coating, so it could possibly be bulletproof.
If its actually a bulletproof boat rcvr then I'm thoroughly impressed :buttrock:
Darin Jordan
06-22-2009, 02:21 PM
Bill,
It's all different... it has special programming a circuitry, specifically designed for use over water and in boats. The signals act differently over water than they do over land, and this system takes that into consideration... The water-proofing on the board is just an added benefit to go with the improved electronics. The dual antennas give another clue that there are some internal changes that have taken place... My SR3100 RXs only have a single antenna. (For those wondering... "SRXXXX" stands for "Surface Receiver", while the "MRXXXX" designates the "Marine Receiver"... Yes, you guessed it... "ARXXXX" stands for .... ;) )
It requires the use of a "Marine Compatible" TX as well, further indicating that there is something different beyond packaging...
BILL OXIDEAN
06-22-2009, 02:46 PM
Bill,
Sweet! Airtronics had me testing our second to latest technology developed to be utilized in boats FHSS-2 ( Frequency Hopping Spread Spektrum) which has a much higher output, better range and a much higher processing speed than previous models and anything else on the market.. Now we have the M11-X which surpasses any surface radio thus far
The results were great, I can run my boat so far that I can't see it, the response time is unmatchable, and water dosen't sem to kill them. Range is a serious problem with 2.4 in boats, and its great to see radio mfgrs stepping up to the plate and making boat minded/specific products
Spektrum has been working on this boat system for close to 3 years, I was giving input on it back when I raced for 'em.
Pretty exciting.
6S HYDRO
06-22-2009, 04:27 PM
are you kidding, so now you dont only have to fork out 80.00 for a reciever but i have to buy a marine specific radio too. oh great:thumbsdown:
Darin Jordan
06-22-2009, 04:34 PM
If you READ more carefully... It says "and is compatible with all surface transmitters featuring the marine logo. "... The new DX3S radios I are the first ones that currently compatible and have the "Marine Sticker" on them (see http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPM3140 ), and they also have a retrofit program for certain radios already out there.
http://www.spektrumrc.com/Articles/HobbyWire.aspx
Other radios will follow, from what I've been told...
6S HYDRO
06-22-2009, 04:49 PM
i did read pretty carefully, problem is none of us have the radio with the marine sticker :doh:
Darin Jordan
06-22-2009, 05:08 PM
Of course you wouldn't... it's just been released... :confused2:
Not everything can be backwards compatible...
6S HYDRO
06-22-2009, 05:18 PM
so the one you were testing with only worked with a marine tx, you didnt say anything about you using one. you said they changed it so you have to use the new marine tx. I just love it when companies do that to you just so they can make an extra 300.00 bucks and sell two radios :sarcasm1:
sailr
06-22-2009, 06:28 PM
Great info Bill!
I use the Airtronics 2.4 (first one out I guess) and it has been absolutely flawless. It's kinda puzzling that it took Spektrum so long to change when both Futaba and Airtronics never had the problems that Spektrum did. At least they have addressed it and it sounds like they have come up with a great new system. It's a shame they couldn't make it compatible with existing transmitters though.
Pretty exciting.
6S HYDRO
06-22-2009, 06:32 PM
hey sailr, your from mini-cat racing - so are you in phoenix?
Darin Jordan
06-22-2009, 06:43 PM
You need to go back and read my initial post... I DID mention what radios were supported...
They did it this way because it's the way it had to be done to make the technology work. Pretty much the way most new tech evolves. Not sure what you have against them for this, but that's just the way it works sometimes.
Makes it pretty obvious, however, that the tech goes beyond just a simple repackaging of an RX into a water-resistant package...
6S HYDRO
06-22-2009, 06:48 PM
no, no, no, the way you posted it sounded like you were saying that the one you were testing this season, worked with the regular spektrum tech. (obviosly the new radios were not out) and if it did why the need for a radio change?
Darin Jordan
06-22-2009, 06:56 PM
I don't know how much clearer it needed to be, but next time I'll try to spell it out more clearly... I didn't make it "sound" like anything of the sort... I typed what I knew... you read it as you read it... They didn't release a new radio... they just updated the ones they are currently selling, and I told you that clearly.
I'm not interested in arguing about this... If you want one, go for it... if you don't, don't. It's a good radio system and has worked well for me... even with the older SR3100 RXs I haven't had an issue with...
Doby
06-22-2009, 07:24 PM
Sounds pretty clear to me,,,,,,my DX-3.0's have been trouble free for years!
Doug Smock
06-22-2009, 08:47 PM
I've been tunning the MR3000 marine receiver in three models this year. They have been flawless.
Well done Spektrum!!!:thumbup1:
Doug
sailr
06-22-2009, 10:20 PM
No. What makes you think we are in Phoenix? We have a dealer out there. We are in Florida.
6S HYDRO
06-23-2009, 11:49 AM
yes my sr-3100's work fine ill just stick to them
6S HYDRO
06-23-2009, 11:52 AM
oh, i heard you guys were out here. but it just a dealer then
sailr
06-23-2009, 11:55 AM
No problem. The dealer is Vision hobbies. www.visionhobbies.com
HappyOne
06-29-2009, 09:16 PM
Darin, do you know if they plan to sell a radio (DX3S) and marine receiver (MR3000) combination?
JimClark
06-29-2009, 09:24 PM
from the spektrum site
Attention DX3S Owners
Thursday, June 18, 2009
New DX3S systems (SPM3140) are now compatible with DSM2 surface receivers and the Marine receiver (SPMMR3000), in addition to DSM surface receivers. The SPM3140 transmitter features the above logo on the back.
If you own an earlier DX3S system (SPM3130) and would like it upgraded with the new technology, please contact the Spektrum Service center who will upgrade it for a small fee. The upgrade costs $50 plus shipping and the turn around time is approximately 3-5 weeks
