View Full Version : Guess how many runs I got before this happened...
LuckyDuc
06-16-2009, 09:13 PM
Well... After 168 runs on my UL-1 (Over 250 miles) my flex cable broke. I should have checked the teflon tube before now, but alas I didn't.:glare:
The cable broke inside the stuffing tube because the tubing wrapped itself around the cable like a screw.:eek:
It wasn't due to a lack of greasing, as I greased the cable every 3 runs. It looks like the teflon tube wore thin from use and bound itself around the cable.
For those of you approaching 100 runs, CHECK THAT TEFLON TUBE FOR WEAR. :cursing:
rightturnonly
06-16-2009, 10:05 PM
Ouch!!!!!!!!!!!!!
bigpapa
06-16-2009, 10:48 PM
boat ok
LuckyDuc
06-16-2009, 11:00 PM
Seems to be. I'll inspect the stuffing tube better tomorrow.
Camman
06-16-2009, 11:25 PM
Sorry to hear that
Tell you the truth
I have over a dozen boats & none have teflon
did it mess the boat up & stuffing tube ?
jingalls007
06-17-2009, 12:30 AM
take out that teflon duc, get yourself a .187 cable and you'll never have to worry about melted teflon. you'll free up some RPM's too.
bigpapa
06-17-2009, 07:27 AM
good luck hope all is ok
LuckyDuc
06-17-2009, 10:43 AM
Some of you are not using Teflon tubes at all?!?
I wonder why they included it if they are not necessary and cause excess friction:confused1:
Camman
06-17-2009, 10:49 AM
If I ever got a boat with it in there I always have taken it out. Most of my boats built by myself
I am not sure why manufacturers use it other than to make sure not to have any possible chatter from metal to metal bouncing but if you use a good grease in it
you won't have any, or atleast I have never had any in mine nor did my Dad when I was just a kid
Perhaps others will know why they use it
:tiphat:
AndyKunz
06-18-2009, 08:59 AM
Skip the Teflon completely. Use brass tubing that's the right size for your cable/wire/shaft.
Andy
Capt. Crash
06-18-2009, 03:30 PM
Will the .187 cable fit the stock coupler, strut bearing, props, etc?
longballlumber
06-18-2009, 03:54 PM
Crash,
If you switch to .187 cable, you will need a new coupler for the increased cable size. Everything else will be fine.
Mike
