View Full Version : 6s Rico Racing 31"?
BassBoat88
06-15-2009, 05:57 PM
Can the Rico 31" handle 6s?
You may want to PM doug smock or mike martin. Mike has built a few of them and Doug just finished one. Both are very knowledgable.
mike martin
06-15-2009, 06:20 PM
I placed 2 at the namba nats in Q-mono(6s) with the 31 it can handle it but on 4s its plenty fast unless you already have the 6s setup I would build it 4s
BassBoat88
06-15-2009, 06:38 PM
Thanks for that info, i do have some 30c discharge 6s already for my 1/8 scale brushless cars, but i might build it with 4s anyway. What kind of speeds should i expect to see with 4s? I would like to see low-mid 50s.
BassBoat88
06-15-2009, 10:08 PM
Any more comments?
mike martin
06-15-2009, 10:18 PM
with a 1515 1y neu or a 1521 1d set up loose around 60mph. the rico if you are raceing set it up a little tight once you get into race water it will come alive and eat any chop you can throw at it. I recomend useing accu tec trim tabs.
line6
06-15-2009, 10:37 PM
Mike what works better in a p mono the higher kv smaller motor 15151y or the bigger motor lower kv 1521 1d. I am leaning towards the 1521 1d in my 29delta
Jason:usa:
mike martin
06-15-2009, 11:06 PM
in the 29 delta I would go for the 1515 1y personaly I like the y winds better everything runs cooler and I have setup my 31 with both motors I can run as big of prop with the 1515 as i can with the 1521 and the esc came in 30 % cooler with the 1515. batts also cooler
Ub Hauled
06-15-2009, 11:10 PM
the 1521/1D is an amp hog, a SAW motor... I'd stay away from it unless you are experimenting.
line6
08-13-2009, 10:43 PM
Jason:usa:
:doh: just was looking at this old post and i realized that i made i mistake. i meant the 1521 1.5 D (1860Kv) NOT the 1D. so same Q i guess.
mike martin
08-14-2009, 10:41 PM
either motor works well on 4s
