View Full Version : Turnigy Sentilon HV controller and Programer
bustitup
06-14-2009, 07:44 PM
I have decided to let this go to fund other project...its brand new never used and no bullets ever installed and will handle 12s lipo has custom water cooling installed and I will also include the NIP Turnigy programer that is made for this controller
$125 shipped in USA no insurance
http://www.rgcbuilders.net/100amp.jpg
http://www.rgcbuilders.net/100amp2.jpg
txboatpilot
06-15-2009, 08:58 AM
Why sell?? You can use this on the 2215/2Y for a LARGE build.. These are acually "good" esc's.. Not the best, but they will work just fine if you dont over prop...
Jesse J
06-15-2009, 09:04 AM
Is the trick using low KV motors and small props? I was eyeing this for my 1521/1.5D in my DF33, what would over-propping this set up for a 100 amp ESC?
Might be interested in trading i this will work for this application.
bustitup
06-15-2009, 09:19 AM
Tex that's exactly why I bought it but when ever I asked about using in build I was told not enough amps
If that's the case I will try to use it
Jesse J
06-15-2009, 09:28 AM
Go for it! Bust it up!
txboatpilot
No tricks,,, The physical size of the motor combine with Low KV (450-900kv) and high voltage (8s-12s total) with the right size prop, will push larger hulls at good speeds. And will draw less amps than a 4s-6s setup with a physically smaller motor,, that is why you can get away with running a 100a esc on 10s2p with 2215/2y,, but not ok on a 4s2p with 1521/1.5d...
Keep in mind the "D" wind Neu's will pull more amps than the "Y" winds,,, I would recommend a High amp esc vs. this High voltage esc....I always run a CC 240 on my 1521/1.5d with 4s2p for great results in any hull from 29"-33"........
txboatpilot
06-15-2009, 09:34 AM
Yes it is not enough amps to go 60+ for a race,,, but low 50's for sure.. Untill you can get a CC HV controller this will work for practice... Just dont go over X455 prop and you should be fine... If you go up to the x460-62 you will pull too many amps and blow the 100a esc for sure!
I raced a 40" Insane Cat with a Neu 2215/2Y on 10s1p 6000mah 25c total with a x455 prop at one of the races last year and was getting 54-56mph and pulling 105-115 amps cont. I ran one of these esc's,, just the older version...
bustitup
06-15-2009, 09:44 AM
That's the first time anyone has explained how HV low amp controllers do there thing
Thanks tex
bustitup
06-15-2009, 09:53 AM
Tex
I think this IS the older version
txboatpilot
06-15-2009, 09:54 AM
Thanks tex
It is really not the controller that is doing it..,,, the added Voltage of the 10s lipo vs. 4s is what brings the amps down... As well as the larger size motor,, which can move more wieght/bigger hulls at a given speed without needing too pull those extra amps...
bustitup
06-15-2009, 09:59 AM
Off the market
txboatpilot
Tex
Now that I look at it,,, you are right.. It is the same as the one I used.. Good esc's, just remeber it has LIMITS...
NOW GO ORDER THAT EBAY CAT AND GET TO BUILDING!!! LOL
You will have a fast fun Cat that will handle race water better than any 4s boat could dream of!:tiphat:
