View Full Version : Free to a good home - ESC cooling plate
Chilli
06-13-2009, 06:37 PM
Fried my Etti 150 today. I pulled the cooling plate of it thinking someone may want it. Excellant shape. Slight burnt smell.......:doh:
Plate is 1/16 thick aluminum, 1-1/2 inches wide and 2-5/16 long.
First contact gets it.
Diegoboy
06-13-2009, 06:39 PM
Please... Me
Chilli
06-13-2009, 06:40 PM
Man your fast. PM me your address. I'll get it in the mail on Monday.
Jesse J
06-13-2009, 07:04 PM
Pray share your recipe for disaster. I have one too and feel like I am riding it on the edge. What were conditions, if you don't mind reliving it one more time.
bustitup
06-13-2009, 07:21 PM
speaking of which...how did your turnigy 180amp work out ......did you get full power out of it?
Chilli
06-13-2009, 07:38 PM
Last post on this thread.....
http://forums.offshoreelectrics.com/showthread.php?t=8439
bustitup
06-13-2009, 07:48 PM
whats that big black round thing inbetween the coupler and the tubber and where do you get them?
Chilli
06-13-2009, 08:12 PM
I think your talking about the stuffing tub support. I made it with some leftover marine plywood I had laying around. I drew two parallel lines the width of a nickel on the ply. Rounded off the top and drilled an appropriate sized hole for the stuffing tube at 15 degrees. I also made the reciever battery tray out of marine plywood. If you cut a cross section, it would look like a T except with two vertical lines. One vertical support on either side of the stuffing tube. I spooge the gap between the verticle supports with construction adhesive before I epoxy it on and this adds additional support to the stuffing tube. I don't know if it's needed but it's something I do.
Diegoboy
06-17-2009, 09:01 PM
It showed up today. Thank you! :thumbup1:
wolf IV
06-17-2009, 09:23 PM
Lucky........
Chilli
06-17-2009, 09:41 PM
No problem Danny.
Make sure you make a sacrafice to the FE gods to remove any bad Juju I might of put on it.
