View Full Version : Twin Catamaran Question
BassBoat88
06-11-2009, 04:35 PM
When building a twin drive catamaran, and u want to run, say 12s lipo, is it better to run 12s on each side/esc or can u run 6s on each side/esc for a total of 12s? Or is it just a personal preference?
12s on each side if your going to call it 12s...
BassBoat88
06-11-2009, 05:29 PM
How would it do performance wise....
Depends on hull, motor, prop... But usually 12s cats are insane.
BassBoat88
06-11-2009, 07:37 PM
Well, it could be too much power, but i want to put it in the Toysport Jolly cat twin, but 10s might be better?
I'd go with 6s max... It's not that big of a hull.
For an economical, but very powerful setup, do twin 580 6L's on 4s. Two packs, one for each side.
crabstick
06-11-2009, 08:02 PM
WAYYYY Too much power . Graham D in our club had a Jolly on 2 x 8xl's and 4s each motor, it was pretty much a wheelie monster, hes replaced the 8xls with ammo motors and its still very very fast, but not overpowered.
Eodman
06-12-2009, 09:28 AM
I don't know about the Jolly being a wheelie monster ... I'm running a twin jolly on 8xl's and 4s to each motor and I love it!
My only problem when I first built it was - it porpoised alot! Contacted the manufacture(Joseph Toth) and he sent me an additional part to add to the back of the tunnel and now it just gets up & goes!
BassBoat88
06-12-2009, 03:01 PM
So, this is a 4-6s cat....
Jesse J
06-12-2009, 03:34 PM
Depends on what motor and props you want to spin...
BassBoat88
06-12-2009, 04:14 PM
I will most likely be running 2 Medusa 70-80mm motors in the 1600kv range on 5 or 6s, don't really know much about boats, so what size prop would be a good starting point?
crabstick
06-12-2009, 05:29 PM
ok I do admit that I believe in the "too much power is not quite enough" theory :bounce:
But I wouldn't go as far as to put 10s into a Jolly cat even though that is very :rockon2: it might not be a good introduction into FE:flame42:
Eodman - yeah the tunnel tab fixed the porpoise on Graham D's one he made a bling stainless adjustable one. Might have been half the issue. It is a good handling hull for a small boat, but I personally if i was to build one for myself I probably go for 2 9L on 4s each and start with an x632 on each side counter rotating.
Choosing an Esc is a hard choice at the moment... you get what you pay for, and sometimes you don't :flame42: although I have been lucky with some chinese ones so far, touchwood, my 120amp hextronic from hobby city got a watercooling and conformal coating and has been good to me for a few years, i think its got thermal protection as when I had it in my rigger trying silly props in nimh days it would just shut down if you over prop the hell out of it (x455 on 8xl :unsure:) IMO If you want to spend the cash once and do it right then id prolly go shultze. I-care has a big sale on at the mo. Have you had any other boats BassBoat88?
BassBoat88
06-12-2009, 05:53 PM
The only boat i've had experience with is a SV27, but i'm used to the power of brushless because of my 1/8 buggy and truggy i run on 6s and have had in excess of 65mph. I am fairly new to boats and i'm not scared to spend money:lol:. And instead of schulze, is there any wrong with Castle escs? I guess by 9l u mean feigo?, I would like to use something closer to the top of the pile, i've had nothing but trouble with those in my cars. Does the jolly get to plane quickly on 4s?
Boatman
06-12-2009, 06:56 PM
Just a suggestion I would go with a couple Neu 1509 2y motors on 6S each and with a set of hydra 120A esc's. Those with a pitched up set of counter rotating 442 props would be quick off the line and amazing top end speed. Over powered? Maybe. With the more efficient motors your run time and temps would be decreased. I write this seeing money not a problem for you. I am sure many would argue this selection but going to the 1512 motors there is not much to choose from that would not yield high amperage while going any over 4S.
Boatman
06-12-2009, 07:04 PM
Hmm. spoke a bit to quick there. IF you were to go that route just would suggest toning those props down to reg 442's detounged and thinned. Goodluck no matter your choice and remember how much we like video's!
That makes it easier to know that your into spending money...
But i'd still use these as opposed to the hydra 120's>
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8937&Product_Name=Turnigy_Marine_180A_Brushless_Boat_ES C
These motors are also very economical, but massively better than feigao's in performance. Not as good as a neu, but close. Especially for the price>
http://www.lightflightrc.com/
Go To products/motors& esc's/36mm motors
The 36-55-1 would be a good 4s motor, and the 36-55-1.5 would be a good 6s motor.
More info on the Arc motors>
http://www.rcgroups.com/forums/showthread.php?t=819392
BassBoat88
06-12-2009, 08:02 PM
The esc looks good for the price and the motors aren't bad either. Have u had any experience with Medusa's in boats? I really like them in cars.
