View Full Version : UL-1 Replacment motor
BIGDG357
06-08-2009, 09:08 PM
I have been having trouble with my UL-1 and currently hobby services has my motor but i do have an ammo 36-56-2600 w/ the cooling jacket ready to go along with an m440 and an x642 prop on hand would this be an alright set up or would i damage something?
LuckyDuc
06-08-2009, 10:00 PM
IMHO a 2600kv is too much, and you run the risk of smoking your ESC and the motor... at least with the props you listed.
detox
06-08-2009, 10:07 PM
It may work using 3s power.
BIGDG357
06-08-2009, 10:14 PM
thanks lucky thats what i thought. and detox when you say 3s do you mean 1 pack (11.1v). Do you guys know what voltage this esc is good for
LuckyDuc
06-08-2009, 10:16 PM
It would work with 3S if you don't use the stock ESC as the stutter bump that's programmed into it will prevent you from using anything less than a 14.8 volt setup.
My next setup will be a feigao 13L. I wanna see what this motor does with the stock esc, I had nothing but good luck with the 12l on my 45amp in the SV27.
:thumbup1:
BIGDG357
06-09-2009, 06:29 PM
hey nate what kind of speeds are you getting on the supervee with the fiegao and is the 45 amp esc the stock one
Uhh well I need a GPS. but Im thinking maybe 42-43 at most depending on the water..lol she gets wild in rough water.
I was running it in 10mph wind two days ago and it caught air around 40mph and blew over..
Left a massive crack on both sides of the hull...
BIGDG357
06-09-2009, 10:40 PM
I am wondering speeds people are running on the sv27 I have had mine for 2 years and have recently added a gps to my rc toolchest and ran 38.6 on the stock set up besides a 40x52 3 blade grim racer prop which I balanced and sharpened to add about 3.5mph to that run which I am pretty proud of because this is my first balance and sharpen job.I am also running 2 5000 mah 2s lipos which I'm pretty satified with........ for now.Sorry to hear about your SV though that sucks man
MonsterMaxx
06-25-2009, 04:16 PM
would it take 6s in stock form? or would that let the magic smoke out?
I have lots of 3s2200s and 6s 2650s. Are either of these good candidates?
No, Id never run over 4s2p on the 45amp SV27 esc.
I ran 5s on my blackjack motor and esc with an x440.. it held up, but ran very hot.. a few more passes would make that esc toast!
My sv is close to the mid 40's with the feigao 12l
I swapped over to a 13l because i wanted to run a bigger prop on 4s..
now its probably running 45mph at most...
6S HYDRO
07-02-2009, 11:41 AM
actually you can run 5s no prob on ac 45 amp esc, but you must upgrade to a better water pickup to flow lots more water than the rudder pickup. iv been running my blackjack on 5s with a 42-55 prop for over a year now, just keep runtimes short 5-6 lap heats
6S HYDRO
08-04-2009, 01:27 PM
Hey nate i just ran my 12l in one of my sv's w/ stock 45 esc on 5s lipo and hit a gps verified 51.9 mph ON S&B X642
