View Full Version : ☼ WANTED → Expert woodworking services please ← ☼
Diegoboy
06-07-2009, 10:08 PM
I am in need of someone with the facilities, and the desire to duplicate my Hydrofoil wings out of hardwood. I have had these sitting on the shelf too long. I have tried other options to remake the wings, but I simply don't have the tools to do so.
If anyone would like to remake these wings for me, I'll gladly mail these to you for ease of duplication.
Let me know an estimate and we can go from there.
♫ Thanks for your time ♫
http://www.diegoboy.com/misc/100_3341-sm.jpg (http://www.diegoboy.com/misc/100_3341.jpg)
http://www.diegoboy.com/misc/100_3342-sm.jpg (http://www.diegoboy.com/misc/100_3342.jpg)
Diegoboy
06-08-2009, 10:46 AM
No one with woodworking expertise? :confused2:
Diegoboy
06-08-2009, 07:33 PM
Okay, no duplication? How about repair these for me then?
egneg
06-08-2009, 08:22 PM
Diego - I am assuming that they are metal to start with. I don't think that wood, even hard wood, would have enough strength to hold up at the joints.
BTW ... how much wood could a woodchuck chuck if a woodchuck could chuck wood? :ThumbsDown01:
shockerman80
06-08-2009, 08:24 PM
why not make them from balsa and then glass them? glassing isnt a big deal once you get the hang of it.
Diegoboy
06-08-2009, 08:26 PM
They are hardwood.
I think that Balsa will be too fragile, even if they are glassed
Diegoboy
06-08-2009, 08:28 PM
Thanks for the reply!
knpc
06-08-2009, 08:34 PM
Is it a shelf queen or a boat that you run? Any idea on what type of wood they are made of? I'm a finish carpenter so this is a project I may be interested in.
Diegoboy
06-08-2009, 08:40 PM
She's been a shelf queen, but she was a runner before I got her. I want to get her running again. I don't know the type of wood other than "hardwood"
The model is made by Hegi (http://www.foils.org/gallery/hegi.htm).
LiPo Power
06-08-2009, 08:47 PM
...Guys, this is where Diegoboy is going with his project...maybe...? I think it will be cool to have them fixed....
shockerman80
06-08-2009, 09:03 PM
it shouldnt be a huge job to do its just cutting the angles right that would be a pain.
knpc
06-08-2009, 09:05 PM
It seems very doable. The way the joints are done is actually a very strong connection. Its amazing how strong wood glue with the right dowel or biscuit can be. A lot of the cabinets and entertainment centers I build don't have a nail or screw in them.
Is this boat still produced, if so have looked into getting the pieces from them. If those get repaired or new one built glassing them is a good idea for added stregth and protection from the water.
Jesse J
06-08-2009, 09:08 PM
I made some out of brass. Used brass sheeting and tubing, the oval kind. I bent the sheeting and the crease made the trailing edge, then solder (I used a blow torch) the bottom to the tube and then the top. I also made some curvature in the upper half of the bent over sheet so when it was soldered onto the tube it was a pretty nice airfoil. It was a small exercise in patience, but actually really fun and not too hard. I may be able to replicate them later this fall/winter if you are not in a big rush. I may just make two sets and keep one for my shelf non-queen.
shockerman80
06-08-2009, 10:06 PM
other option is to cut a slot in the bottom of the foil all the way around and epoxy a heavy gauge wire into the grove then fill it with micro ballons or bondo icing. that would really strengthin it up
Jesse J
06-08-2009, 10:22 PM
here is sketch of what I was describing...
Diegoboy
06-08-2009, 11:32 PM
Here's 2 pics of how each joint is done. This joint was the weakest, so I seperated it a bit for the pics.
Diegoboy
02-05-2010, 08:18 PM
I thought about this recently...
Could one take a wooden heli main rotor blade, flatten one side with a big sander, and assemble them to looke like what I need??
westbeach
02-05-2010, 08:32 PM
Danny, have you though about duplicating it in brass and brazing it together ?
Diegoboy
02-05-2010, 08:38 PM
I did, but i think it'll be too heavy for it.
hydromaddicted
02-05-2010, 09:43 PM
What about carbon fiber?Could'nt you make one out of carbon fiber sheeting and rods?
ncornacchi
02-06-2010, 07:26 AM
I think your on to something..What if the rods were light aluminum (coathanger) and you made up a nice wire frame .....add tiny gusset plates at weak impact joints and then carbon fiber?
bustitup
02-06-2010, 09:03 AM
here you go Diego
http://www.youtube.com/watch?v=VePsTJzgc_g
egneg
02-06-2010, 05:02 PM
Just saw this ...
http://www.rcuniverse.com/market/item.cfm?itemId=600971
westbeach
02-06-2010, 05:28 PM
Danny,
Foam core with either carbon or fiber glass might be an option?? The only thing is I would strongly suggest vacumm bagging and heat cure for strength.
Diegoboy
03-08-2011, 09:10 PM
Can anyone help me before I give up?
shockerman80
03-09-2011, 07:39 AM
how big are they? length width height
Diegoboy
03-09-2011, 05:10 PM
The front wing is made up of 4 sections of 3-5/8" long pieces. Each wing piece is 2" front to back.
The rear wing is made up of 3 sections, the two outer sections are 4-7/8" long each and the center section is 3-7/8" long. All are 2" front to back
The thickest part of the airfoil shape is 1/4".
Anyone willing to help, I'd be more than happy to ship the wings to you and pay for your time/material/shipping back to me
tiqueman
04-06-2011, 05:59 PM
Diego, what about making a mold of them and casting them in re-enforced resin?
Diegoboy
04-08-2011, 11:59 AM
They're warped. that would just copy the defects
tiqueman
04-08-2011, 12:07 PM
bummer.
Doby
04-08-2011, 12:23 PM
Stupid question...but have you tried to run it as is,,,maybe it will still work with the warpage???
Diegoboy
04-08-2011, 01:04 PM
No I haven't My scale club guys say that any defect in the wings will be amplified when she's run, so I took the wings off then apart
