View Full Version : Bilge Pump?
Do thye have a sort of thing that will pump out or sifen the water out of your hull?
Rumdog
05-30-2009, 12:16 AM
Autobailer, get one here on ose. Shouldn't have water in a fe boat though.
Ok, i just have a problem with water coming up through the teflon stuffing tube and im afraid of too much water coming in.
ozzie-crawl
05-30-2009, 12:42 AM
some boats seem to pull more threw than others always found by adding a fair amount of grease fixed it for me
Rumdog
05-30-2009, 12:45 AM
Grease should help out for sure. if it's still syphoning in water drop a lil' sponge by the stuffing tube so that little bit of water gets trapped and doesn't flow around the hull.
ozzie-crawl
05-30-2009, 12:54 AM
yes the sponge works well. i dont use grease as such but a product called lanotec (made from lanolin) its water proof and used in high temp high pressure machinery. works great and never had any rust on my flex cables.
OK, i will try filling the tube with grease. Gotta have a well lubed shaft. :iagree:
ozzie-crawl
05-30-2009, 04:30 AM
:w00t::w00t::w00t:
I have some marine lubricant for 1:1 boats, can i use that on here?
Rumdog
05-30-2009, 11:56 AM
that stuff works well for me
