View Full Version : receiver hook-up
bwells
05-29-2009, 01:43 AM
I just got a traxxas 2216 receiver 3 channel but noticed it has 2 channel 1, channel 2, channel 3 and batt. My ESC has a BEC so where do I plug the ESC into, either of the 2 channel 1 and servo to channel 2. Thanks:confused2:
Blackjack-sven
05-29-2009, 08:44 AM
just plug in your esc and servo into channel one and two and then add the bec to the third. But dumb question :confused1: . You said you had a bec to plug in as well??? :confused1: A BEC is supposed to eliminate the extra connection. :confused1:
bwells
05-29-2009, 09:01 AM
The ESC has a built in BEC circuit but which of the 2 channel 1's do I plug it into or does it matter?
bustitup
05-29-2009, 09:35 AM
servo = channel #1
esc = channel #2
make sure the red wire stays connected on the esc if your using its internal bec
Blackjack-sven
05-29-2009, 10:14 AM
I doubt it'll matter. Try one of them and see which the true channel 1 is. You won't do any damage if you get the wrong one the first time. Usually the real channel one is the one right next to channel 2 though.
