View Full Version : VIPER by H&M Conversion Brushed to Brushless
Camman
05-28-2009, 07:27 PM
Finally got around to work on my Viper
Old school Nmh & 700 Cordite just does not cut it with the BL/Lipo nowadays
Saw all these UL-1's on the scene at our club "HOTMBC" Thought I had a good platform to start my
UL-1 killer :cool2:
http://www.jrcbd.com/photopost/data/752/medium/110.JPG
http://www.jrcbd.com/photopost/data/752/medium/31.JPG
After some looking real close when stripping her down I noticed rudder might had been dragging. With straight edge to bottom of hull runs right into rudder where it shouldn't
http://www.jrcbd.com/photopost/data/752/medium/6.JPG
Gona have to scooched things up some on transom & reglass
http://www.jrcbd.com/photopost/data/752/medium/7.JPG
Everything scooched up & reglassed
http://www.jrcbd.com/photopost/data/752/medium/16.JPG
Thanks for looking
Camman
05-28-2009, 07:32 PM
Every thing out
http://www.jrcbd.com/photopost/data/752/medium/8.JPG
Test fit AMMO 36-56-2030kv with OSE cooling jacket & 2 packs 5000mah 25C Hyperion Lipos
http://www.jrcbd.com/photopost/data/752/medium/10.JPG
http://www.jrcbd.com/photopost/data/752/medium/111.JPG
Industrial Velco with straps
http://www.jrcbd.com/photopost/data/752/medium/15.JPG
Velcro under 60 amp Aquacraft ESC
http://www.jrcbd.com/photopost/data/752/medium/13.JPG
Camman
05-28-2009, 07:34 PM
Make a mount for my steering servo, epoxy in with slow cure epoxy
http://www.jrcbd.com/photopost/data/752/medium/17.JPG
http://www.jrcbd.com/photopost/data/752/medium/18.JPG
Good decision to make the jump to brushless/lipo power. You will definately be surprised when you pull the trigger. I am in the process of building up the one in my avitar right now. Set up correctly these boats are very comfortable in the mid 50's. Don't forget to get some video.:thumbup:
Camman
06-16-2009, 06:54 PM
HOLY SMOKES
Tracy
You were not kidding about the difference when pulling the trigger :eek:
I did not run to big a prop so went with a K42 & man !!!
when you say go it GOES :eek:
I am so glad things are going as good as they are. I was reluctant at first to play with the FE stuff but now I am soooo glad I did.
I can not wait to finish sharpening & ballancing some other props for this weekend
I must have tabled it very well because first run I could literally pin the throttle & just steer it around the course
Zero signs of anything bad
Temps after first race esc 103, batts 99 & motor 99
I think I can prop up don't u'al think ?
:beerchug:
Mike
Get's a little loose at that speed doesn't it! Have fun, sounds like you already are.
All the best,
Ray
Camman
06-16-2009, 08:12 PM
All the best,
Ray
Actually it was not all that loose at all
I was really surprised that it ran very very smooth & tight no dancing at all
I will try to get someone to shoot vid this weekend
I am sooo hooked on FE
especially these smaller boats
pretty cheap for the speed you get
:thumbup1:
Meniscus
06-18-2009, 12:30 PM
Are you running a turn fin? I don't see one in the pictures.
I find that mine doesn't run loose either, but I have to be very, very careful with the COG. Otherwise a blow-over is certainly in order.
