View Full Version : Grim's setup
SJFE
04-07-2007, 03:49 PM
This is for you non RCU guys.
Here's the Grimracer setup.
Aquacraft SuperVee 27
Entire bottom scuffed with red scratch pad (Menards, Lowes, etc)
One thin cote of Pacer Z-Poxy Finishing Resin on all wood parts (#PT-40)
SS trim plate’s .5deg positive to the bottom of the hull
Strut set at 0deg
Rudder blade tucked full under (stock shear bolt)
Added turn fin to the port side (AQUB7882)
Octura X-440/3 prop (bag)
Top speed… 38MPH (note: the wind blows almost all the time here, typically our water is loose)
Rex R
04-07-2007, 06:54 PM
Re: red scotch brite
this is the same(close enough) as wet sanding with 320 grit sandpaper. you want to go the length of the boat, from stem to stern.
Diegoboy
04-07-2007, 09:01 PM
SJFE,
I ran boats with Dirtysouth31 from RCU. He told me that Grim recommended a replacement motor for the SV27. That recommendation came when there were no replacement stock motors available. I have searched that Ginormous thread and couldn't find it. Do you remember the recommendation?
SJFE
04-08-2007, 12:06 AM
[B][I][COLOR="Navy"]Yup...He stated it was also an upgrade. http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=000045963&I=LXLWZ6&P=K
Diegoboy
04-08-2007, 06:20 AM
Thanks.
Dirty runs that motor, and his boat is FAST!
hammertime
04-08-2007, 09:47 PM
would you need a new esc for this motor? or is the stock one ok
Diegoboy
04-08-2007, 11:05 PM
Don (Dirtysouth31) runs it on the stock ESC.
SJFE
04-09-2007, 01:19 AM
If I ever stop building new boats....I'll put one of them in the SV. Its kinda hard to upgrade boats that are in the water when you have 2 under construction and another planned.
pugman2
04-09-2007, 09:41 PM
were do you guys get the z poxy sealer to seal the wood
SJFE
04-09-2007, 09:43 PM
Get any 2 part hobby epoxy from your LHS. I would not advise using the 5 minute cure stuff. Go for the over night cure. The working time is longer.
04-10-2007, 02:29 PM
I can get some of those motors if you guys like. But the rating for the amps on that motor is 60amps continuous. That's more than the 45amp esc rating.
dirtysouth31
04-10-2007, 05:28 PM
the only problem i have with it is when i run a 447/3 sometimes the esc shutsdown.but other than that the esc holds up
SJFE
04-10-2007, 05:30 PM
I'm not afraid...Order some up. I would like to see if they fit the OSE water jacket. I'll sign the "you may smoke the esc" disclaimer:p .
SJFE
04-10-2007, 05:32 PM
Dirty..all of your numbers posted on RCU are with this motor?
dirtysouth31
04-10-2007, 05:50 PM
yep.never gps the stock.hell the stock didnt stay long..i just wanted faster.fastest i have gotten was 39.7 and thats with the 447/3.you will notice a night and day difference when switching the motors.and the ose water jacket fits;)
Diegoboy
04-10-2007, 08:24 PM
Hey Dirty!
Glad to see you here! Welcome.
Thanks for contributing your wisdom!
Diegoboy
04-10-2007, 08:25 PM
Please do.
dirtysouth31
04-10-2007, 08:45 PM
i was a member before but since the change i couldnt log on,so i just re-registered.
dirtysouth31
03-21-2010, 08:15 AM
and still a member and this place has changed into a bunch of whiners and nuthuggers
03-21-2010, 10:52 AM
Well then its simple, if you dont like it leave. Let me know if you need any help :banana:
Jeff Wohlt
03-21-2010, 11:51 AM
A buddy of mine run the 2300 KV ammo with stock AQ ESC and a M440 prop. It ran fastest with that one....we tried a bit larger and it ran hot and not as fast. It needs to spin. This was on a BJ cat so a little different. Mono should be able to take a little more prop.
wizard122
03-21-2010, 02:53 PM
I'v posted all my setups at my new sv check them out. This was my last post.:banana:
she ran 52.7 with Ammo 2300
http://forums.offshoreelectrics.com/showpost.php?p=164788&postcount=76
