Darin Jordan
07-02-2007, 08:26 PM
Yup, I have two of them to part with... ;)
Exactly the same as #1...
1 year old RC-Hydros V60-612/BEC ESC (Victory 60Amp with BEC)
Brushed Motor, 7-13 Volt, 60Amp, w/ BEC and water cooling.
Comes with Dean's on the battery side and 3.5mm on the motor leads...
I used this for part of a season on a 27T stock motor... Works perfectly...
Best brushed ESCs ever made... Out of production now... Excellent for LSH or other brushed applications up to 12-cells...
Here are the specs from Andy's site:
V60-612/BEC Features -
Watercooled & Waterproof
6-12 cells
1Amp BEC good for 1-2 servos
1.5" x 2.25" x 0.5" thick (40 x 65mm x 13mm)
Programmable for Pistol-grip or Stick transmitters
Programmable Low-Voltage-Cutoff (LVC) to save your LiPo cells
Programmable PWM to match your motor's inductance best
Weighs only 1.2oz (41g) including wires
4-FET design for low on-resistance (.0008 ohms!!)
300A surge current, 60A continuous with water cooling
Three-color LED shows OFF, PARTIAL, and FULL POWER settings
All adjustments are done on your transmitter - no pots to fiddle with!
Universal JR-style servo connector (compatible with Futaba, Multiplex, Hitec, and Airtronics Z
12" servo leads allow flexible positioning
Fail-safe powers down on radio signal loss (but doesn't glitch)
Safe-On feature prevents glitching on power-up
12AWG wire for minimum resistance
Recommended for 6-cell Stock and Modified motors (N1, N2) and 12-cell Speed 700
BEC is NOT recommended for AM radios. It might work OK, but we don't recommend it for safety reasons
Manual available Online
$75.00 shipped in the USA.
PayPal preferred, but Money Order OK as well.
Banzai240@yahoo.com
6-12 cells
Banzai240@yahoo.com
