View Full Version : H&m intruder s
DINO7
05-21-2009, 04:01 PM
Hydro & marine intruder s is my first build.it will run with a medusa 36-70-2300v2 at 4S.esc a hobbywing seaking 120A 2s-6s.so what all fe experts thinks about size of flex.0.130 or 0.150?
bigpapa
05-21-2009, 04:07 PM
great boat
Jesse J
05-21-2009, 04:25 PM
Save yourself some woes and go wire drive. No maintenance, no fraying and lower resistance. Plus you have a lot thinner stuffing tube coming out the hull, lower drag.
If you must go cable and you are thinking at 4S (~35k rpms) you want at least .150 if not bigger.
bigpapa
05-21-2009, 04:30 PM
mine is wire and luv it
Jesse J
05-21-2009, 05:11 PM
Show the man a pic of your tunnel where the stuffing tube exits, bet its super neat!
bigpapa
05-21-2009, 05:19 PM
gotta take a pic will do jesse
bigpapa
05-21-2009, 05:21 PM
back
Jesse J
05-21-2009, 05:22 PM
you got one hell of a deal on that! I bet you got a nice stand it sits in over the fire place or somewhere on display. Could you get some business end shots too? Thanks, Big papa. ------------------------------- whao, you read my mind!
bigpapa
05-21-2009, 05:27 PM
rear
bigpapa
05-21-2009, 05:29 PM
sits in the garage on the work table with the blackjack 26 superve 27 and ul-1
You are going to love that motor. I would use the .150 cable in a 3/16 brass tube (no liner).
DINO7
05-22-2009, 04:35 PM
i will go with .187" to be safe with the power.
DINO7
05-25-2009, 02:17 PM
motor and water jacket are here.in a few days i will have the H&M hardware to start my build.
DINO7
06-03-2009, 06:14 PM
vinyl stickers are on:banana::banana:
http://img413.imageshack.us/img413/1685/hminrtuder015.jpg
http://img2.imageshack.us/img2/7749/hminrtuder014.jpg
bigpapa
06-03-2009, 07:35 PM
CAN YOU SAY SWEEEEET !!!!!!!!
:banana::banana::banana::banana:
Nice looking Intruder, keep up the good work!!!:popcorn2:
DINO7
06-05-2009, 03:31 PM
final graphics
http://img195.imageshack.us/img195/1682/hminrtuder024.jpg
http://img199.imageshack.us/img199/977/hminrtuder022.jpg
bigpapa
06-05-2009, 03:59 PM
awsome awsome intruder just stripped mine for pain too great job
DINO7
06-05-2009, 04:27 PM
thank you bigpapa.your intruder was my desktop until today..:laugh:
bigpapa
06-05-2009, 04:28 PM
have you ever driven one
bigpapa
06-05-2009, 04:29 PM
you aren't even ready how fast this hull and how it turns its plain sick
bigpapa
06-05-2009, 04:31 PM
mine with UL-1 set up 48.3 and 4900 28c lipo's 42x55 grimracer prop
DINO7
06-05-2009, 04:37 PM
medusa 36-70-2300 @4S and 5S.will see...:rockon2::rockon2::rockon2:
bigpapa
06-05-2009, 04:42 PM
will fly..............
DINO7
06-08-2009, 03:29 PM
my set up
http://img205.imageshack.us/img205/6760/hminrtuder025.jpg
Jesse J
06-08-2009, 03:37 PM
Great graphics, I like sweeping designs and eye-catching checkers. Ready to see it cruisin!
jingalls007
06-08-2009, 03:47 PM
Looking very nice, clean in the inside. Are you going to stick with deans?? I would go with bullets on that baby, 5.5mm.
DINO7
07-02-2009, 01:01 PM
almost ready.only rudder link tonight......and then weekend tests..:rockon2::rockon2:
http://img37.imageshack.us/img37/1668/mpoyfanaki014.jpg
http://img188.imageshack.us/img188/8193/mpoyfanaki008.jpg
http://img189.imageshack.us/img189/3281/mpoyfanaki011.jpg
bigpapa
07-02-2009, 01:06 PM
just redid mine with a facelift and first run stats check it out here
http://forums.offshoreelectrics.com/showthread.php?t=8826
bigpapa
07-02-2009, 01:10 PM
sweet dino good luck
Brushless55
07-02-2009, 01:17 PM
I'm still blown away on how fast that is with the UL-1 combo! :rockon2:
and mine still sets at 32mph with the sv27 combo.. :cursing:
bigpapa
07-02-2009, 01:22 PM
tks, gonna try to tap the 60 mark saturday if weather holds off added 3 caps to esc and raised strut alittle sharpned prop alittle moore so we will see tks .......... moved cog alittle more foreward also
07-02-2009, 06:17 PM
I'm still blown away on how fast that is with the UL-1 combo.....and mine still sets at 32mph with the sv27 combo..
Don't get too upset, in the video that Intruder is running an Ammo 2300 motor on 4S with a big prop, not a UL-1 motor. Still very fast, I'll be interested in the speed once it can stay on the water like a real boat. :doh:
Your MM should do better than 32 mph with the SV motor. What prop and cells are you running? Strut depth and angle? CG placement? That hull 'should' be capable of near 40 with that setup...
Brushless55
07-02-2009, 08:03 PM
Ammo 2300, I thught it was the stock motor.. ok now I feel a bit better
I am running 5200mah 30c packs, a S220 prop (43.7mm), strut is set to 0 ( better speed and performance), and COG is 25-30%
I had the strut at 3/16th then moved it to 1/8th then to 0"
I do have a second motor that I am going to try and see if I have a motor issue..
07-03-2009, 02:06 AM
Mine runs plenty fast with a BJ motor with the bottom of the strut 3/16" above the sponson bottoms and angled up 2 degrees at the prop end. Do this on a flat table, not "by eye".
You may try an m445 or an x642 prop, but I'm not certain about the SV motor. Another club member has a UL-1 motor in his MM for LSO racing and has GPSd it at slightly over 40 mph - although he is probably closer to 36-38 most of the time. Water conditions can make a big difference as can hull trim. But IMO 32 mph is too slow....
Brushless55
07-03-2009, 03:10 PM
Yep 32mph is to slow!
DINO7
07-08-2009, 12:03 PM
finished boat....:thumbup1:
http://img12.imageshack.us/img12/7293/mpoyfanaki017.jpg
http://http://img98.imageshack.us/img98/6387/mpoyfanaki018.jpg
http://img197.imageshack.us/img197/9020/mpoyfanaki019.jpg
soon some test results..
DINO7
07-08-2009, 12:05 PM
bigpapa
07-08-2009, 12:11 PM
one fine little lady there congrats !!!!!!!!!!!!
DISAR
07-08-2009, 04:52 PM
Beautiful and for first boat excellent job!
Brushless55
07-08-2009, 11:49 PM
Sexy! :bowdown:
Fastang347
07-15-2009, 05:05 PM
nice
Jesse J
07-15-2009, 05:36 PM
Great job, man these boats are awesome. I just love their looks and you dun did a fine job dressin her up!
DINO7
07-16-2009, 12:35 PM
thanks.my seaking 120A is probably dead.no power to the motor but bec works.i dont know....so i ordered a etti 150 non bec.maybe tommorow i will have it here.so stay tuned for testing with various props at 4S and 5S.with max speed ,watts,esc temp ,motor temp and max amper:banana::banana:
Fastang347
07-16-2009, 12:38 PM
when you ready to sell it lmk :sold::smile:
DINO7
07-21-2009, 06:23 PM
ETTI is on.ready for tests.
http://http://img32.imageshack.us/img32/5227/intrudermedusa2300kv003.jpg
DINO7
07-21-2009, 06:24 PM
Jesse J
07-21-2009, 06:37 PM
Very nice, Man you like the zipties. Super clean, ready to get it wet yet? I really like your rails and servo mount!
wolf IV
07-21-2009, 10:13 PM
Very clean!!!!these hulls look soooo sick!!!! Im running .187 flexies with no liner, works better than wire drives that snap all the time , huh jesse:biggrin::tape:JUST KIDDING OFCORSE!!!!
ApacheDude
07-26-2009, 12:23 AM
Nice build, what kind of rudder and strut setup is that?
DINO7
07-29-2009, 11:21 AM
Hardware is from H&M.Top quality..
http://www.hydromarine.de/
extra caps on ETTI for security..
http://img199.imageshack.us/img199/4511/microhydraandintruder00.jpg
bigpapa
07-29-2009, 11:31 AM
sweet cap install looks awsome dino
Flying Scotsman
07-29-2009, 11:52 AM
For a first build very impressive workmanship.
Douggie
sailr
07-29-2009, 12:48 PM
I love the fiberglass interior mounting system for motor, receiver, servo, etc. Did you make that up yourself? Where do you get your fiberglass sheets?
Beautiful boat! meticulous setup. I'm impressed!
DINO7
07-30-2009, 02:32 PM
mounting system is from H&M too.they have it in carbon too.look at "neu" section.thanks guys for your good words.i must say that i have a friend FE expert, here in Athens,that helps me a lot...
sailr
07-30-2009, 06:43 PM
They only seem to have it in Carbon Fiber right now. Didn't see it in fiberglass. Very nice!!
DINO7
08-04-2009, 01:03 PM
http://www.hydromarine.de/hm_20603.htm
DINO7
10-18-2009, 12:33 PM
96.5kmh...or 60mph with a x442 and 2S+3S=5S rhino 4900 batteries.im very happy with the boat.i think with a little more testing on strut position ,intruder can go with 3 digits number...100kmh+...:rofl::rockon2::rockon2:
DISAR
10-20-2009, 07:00 AM
Well Done!
What were the temps? This was one-two passes or continous running?
teach
10-20-2009, 10:37 PM
Great build. How does it handle or is it a straight line kind of boat?
DINO7
11-14-2009, 01:40 PM
new motor for my intruder.Tenshock 2240 7T-2200kv.tomorow first tests runs and measurements.
http://img694.imageshack.us/img694/7046/010pc.jpg
DINO7
11-19-2009, 03:21 PM
my etti s capacitors went for a walk..:ThumbsDown01::ThumbsDown01:
http://img696.imageshack.us/img696/3465/008a.jpg
so ....popular solution=HIMODEL GX200A.Copper homemade water cooled heatsink-thanks for your tests questtek-and wet-protect for waterproofing.
http://img694.imageshack.us/img694/7119/apparition002.jpg
http://img694.imageshack.us/img694/295/apparition010.jpg
Rumdog
11-19-2009, 03:51 PM
If you add the cap board to the esc it will still work. Nice cooling plate btw.
