View Full Version : Who's Running a Micro? => Less than 16"
Meniscus
05-20-2009, 02:02 PM
Who's running a Micro => Less than 16"
Tell us what you have, what setup works best including props used, and what speeds your able to achieve! :smile: Also describe how it handles in various water conditions.
:popcorn2:
ride1226
05-20-2009, 02:20 PM
Im quite curious as well. I really like the minis made my Minicatracing just unsure of getting something so small. Debating either one of those or trying to find a used vac-u-pickle or DF hydro.
bustitup
05-20-2009, 02:24 PM
I'm getting ready to buy this set up
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300266886047&sspagename=STRK%3AMEWAX%3AIT&viewitem=&salenotsupported
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300256641799&sspagename=STRK%3AMEWAX%3AIT&viewitem=&salenotsupported
Diegoboy
05-20-2009, 02:27 PM
Please LMK if that strut has any Vert adj
Meniscus
05-20-2009, 02:30 PM
I've been looking at that for quite some time. Can't wait to see what you can do with it!
ride1226
05-20-2009, 02:31 PM
That looks to be a pretty nice little setup. And im sure with this boat being so small you really save alot on electronics as well. What do you plan to use for a motor mount and whats your power plant gonna be? So far Im thinking of following your footsteps.
JimClark
I have one of the struts I would have to measure it but there is not a lot of adjustment available. It is like .187 to .25 max
Meniscus
05-20-2009, 02:32 PM
After recent testing at the pond in some of the smaller stuff, I recommend trying a 380L ;) Yes it's overkill, but on my Oberto and with Diego's Warrior, it's ridiculous! And lots of fun too!
bustitup
05-20-2009, 02:36 PM
Jim I havnt seen the strut close up but it seems you could dremel the strut to adjust farther if need be
bustitup
05-20-2009, 02:46 PM
ride
I ordered this mount and plan on running a 380l with a hextronix 120 or one of those 60amp seaking esc's on 3s
http://www.offshoreelectrics.com/proddetail.php?prod=tfl-502b12
JimClark
05-20-2009, 02:49 PM
I think there ia a little more you could open up the hole but it seemed ok as long as you could mount the bracket near the bottom which is easy in most boats. It would also be easy to make a different bracket to lower it even further if needed.
Jim
Meniscus
05-20-2009, 02:54 PM
ride
I'd go with the water-cooled mount ;)
http://www.offshoreelectrics.com/proddetail.php?prod=tfl-509b13
(http://www.offshoreelectrics.com/products.php?cat=43)
bustitup
05-20-2009, 03:00 PM
yup I would have done that but there out of stock
Meniscus
05-20-2009, 03:07 PM
Oops, use the link again, I fixed it. In the 380 only size, there's one in stock. Sorry for the confusion.
Meniscus
05-20-2009, 03:10 PM
OK, somehow the link doesn't work. Go to motor mounts, then one down from the 380/540 size, you'll find the 380 only size. There's also the ETTI version at the bottom of the page for 380 size.
ride1226
05-20-2009, 06:20 PM
Would be a pretty neat build. I have never built from bare hull before so im scared to death about running the shaft through the hull and how to place everything. And for the price it seems its cheaper to just go with one of the minicatracing hydros, or even one of the ebay hydros. Just dunno which would come out most cost effective and perform the best. Might just keep my eyes open for a used bigger hydro with a sv setup in it. Thats plenty fast enough and fun for my sport running.
egneg
05-20-2009, 07:02 PM
This is my shovel nose and it was my first build. Not quite a micro but all builds are basically the same.
http://www.youtube.com/watch?v=-MzZlOAlGM4
bigwaveohs
05-21-2009, 03:04 PM
This hull is very similar to the ones my son and I run from MiniCatRacing. They are a lot of fun and as someone pointed out less costly for the motor, electronics and batteries.
The smaller size means you have to sharpen your driving skills!
Meniscus
05-21-2009, 03:20 PM
What setup are you running begwaveohs?
bigwaveohs
05-21-2009, 04:35 PM
Completely stock:
LENGTH: 380mm
WIDTH: 200mm
WEIGHT: 372.5g without receiver and battery
MOTOR: 200mm x 40mm, 2 pole, 2600KV, 64g
ESC: Water cooled, 30a continuous, 40A (10 seconds)
BATTERY: 3S1P, 2100 mAh LiPo, 2A-6V BEC, programmable, 27g
SERVO: Mini high performance
DRIVE: Flex shaft, 4mm prop shaft, drive dog
PROPELLER: Plastic 30mm x 36mm
Meniscus
05-21-2009, 04:59 PM
Great info, what speeds are you seeing? And what props have you run?
ride1226
05-21-2009, 05:51 PM
Im really looking into the little minicat hydro. I like the fact I can run it in smaller pond areas that dont get hit with as much wind.
Is it possible to add a turn fin to both sides and maybe have it able to turn equally as well in both directions for sport running?
Im really trying to get my skunkworks cat finished so I can decide if I wanna sell the cat or the titan 29 that I have to just keep one for sport running then maybe build a larger hydro. God if only I was rich I would just keep and run every boat I want haha.
HOTWATER
05-25-2009, 09:18 PM
I would like to have one of the Minicatracing Hydros to run while I wait for my Renegade Rigger to cool down between runs. Also like the fact that it is about the same size as my rigger!!:thumbup1:
Anybody else having any luck running these?
Miniscus...Cool avitar! Are you going to be buying one also, or do you have one already?
-Kent
Rumdog
05-25-2009, 09:53 PM
I had a mini cat racing micro hydro and it was fantastic! fast and stable ride, I loved that thing!
HOTWATER
05-25-2009, 10:12 PM
Hey Rumdog, What size lipos did you run in it? Did anything ever overheat >ESC, Motor or lipos?
Rumdog
05-25-2009, 10:28 PM
I ran a 3s 25c 2000mah rhino lipo. no heat issues at all, the water pickup worked very well. I did upgrade it to a feigao 380 8l and it was ballistic! totally overkill and unnecessary though, but fun!
I'm running a megatech h2o 9" hull with a 3000kv tiny outrunner a 30 amp mystery esc and a 1300 2c lipo. Octura 27mm prop cut down to 22mm, semi surface drive. No cooling and it gets warm not hot, runs for about 15min goes about 15mph and is self righting. It needs to be pretty calm water to run it but it is very fun.
MikeV
Meniscus
05-26-2009, 04:27 PM
That is sweet!!! Can you post a picture?
If you are asking about the H20, then no I don't have a camera.
It runs back heavy until you get up to speed, about half throttle. Then it rides slightly bow up. With trim tabs.
MikeV
Meniscus
05-27-2009, 05:51 PM
You'll have to borrow one from a neighbor and post for us to see ;)
I like your description, it may help others with setup.
Meniscus
02-02-2010, 03:22 PM
I figured I'd bring this one back up.
We may need a new definition for micro:
http://www.christians-raceboats.de/download/mrigger.wmv
WOW THAT IS SMALL!!!
wakeboardfusion
02-02-2010, 03:30 PM
wow, now that is truly micro
damfurst
02-02-2010, 07:48 PM
I didn't know "Oh, Oh" was German for my prop fell off lol. I can't believe how small that was. I guess mine won't qualify now.
screwball
02-02-2010, 08:07 PM
not to be immature but THATS WHAT SHE SAID!!!!! :banana:
ive got a renegade rigger, a minicat velocity mono and a bby micro scat cat. the monoand the cat run around 35mph and i havent tested the renegade yet
the velocity mono is stock also a little bit over 16 in but i figured id throw it in.....
Length Overall: 450mm (17.7 in)
Beam: 124mm (4.88 in)
Weight: 18.3oz (not including receiver and battery)
Hull - Epoxy resin/Fiberglass Hull
Power - Water cooled B24 x 45L Brushless Motor
ESC - Water cooled 30A with BEC
Prop - 2 Blade Carbon filled
Boat Stand - Plywood
Strut - Aluminum and Stainless Steel
Rudder - CNC machined, anodized aluminum and stainless steel
Flexshaft Drive System - Stainless Steel and Brass
Turn fins (2) - CNC machined, anodized Aluminum
Ultra plug installed on ESC with mating plug included
Hatch seal tape included
Servo -18g
Speed: 30-40mph
and im running a 1550mah 3s 20c rhino lipo
the renegade is the reccommended setup with a 1330mah turnigy lipo
the micro scat cat
esc- custom watercooled 40A mystery
Motor- feigao 380 11s
prop- stock minicat racing velocity mono prop
hardware is my own custom made stuff out of brass
running 2 1250mah rhino 20c 2s lipo`s in parallel
Rumdog
02-02-2010, 08:12 PM
pics of the cat?
old guy
02-02-2010, 10:25 PM
I have a mini cat hydro. It has a castle creations 4600kv motor and is set up for
4s. the motor is almost as big as the boat lol. carbon props just blow up after a couple runs so when the water is soft again I will try a metal one. how fast, to fast but it turns. when you pin it it will jump out of the water and land about 15 feet away. I will try to find the youtube fid
Old guy
Meniscus
02-02-2010, 10:27 PM
Could you share a link and specs for the Turnigy lipo? Thanks! I'm always interested to see what lipos others have been using in their small models.
Rumdog
02-02-2010, 10:42 PM
Old guy
with a 4600kv motor, it surely isnt a 4s boat! :tape:
old guy
02-02-2010, 11:18 PM
not sure if this will work. this was the vid he had on ebay were I got it from. this video you will see it go, I put a little bigger prop on it and on glass water it was way faster
http://www.youtube.com/watch?v=AVXLhlXsVh4&feature=channel
old guy
hydromaddicted
02-02-2010, 11:46 PM
old guy
Something hear does'nt add up;-) :confused2:
Simon.O.
02-03-2010, 02:10 AM
Not wise but doable.
I have a 22" tub rigger that has a 7S-5070kv can that I once fed with 3S to the 432 prop for low to mid 40krpm at the prop
What is being suggested above is good for low 50krpm at the prop and there is no surprise that he blows carbons at those rpm. I blow them at 40odd krpm. Given they are suggested for up to 25krpm then we are all having fun.
Some guys use high rpm for speed and some go for prop dia. I like rpm. It sounds nice. :banana:
If the you-tube vid will ever load then I may get to see his boat doing its thing, for now I believe him.
Ub Hauled
02-03-2010, 02:53 AM
I like RPM as well Simon, actually, I like a happy medium between the high rpm and a decent size prop... I am still experimenting with it to find the happy medium.:unsure:
Simon.O.
02-03-2010, 03:22 AM
This is about to go off the original topic and may need a new thread. Non GPS tuning methods There ya go Jan, you can start that one !!
I do a lot of my tuning by eye, ear and finger, ( cooling )
If it sounds like it is screaming, I smile and feed in more prop and watch. :thumbup1:
Ub Hauled
02-03-2010, 03:52 AM
I was merely agreeing w/ Simon but I can see where how can stray, sorry everyone.. back to topic...
damfurst
02-03-2010, 09:05 AM
These are the micros I have.
MHZ Gecko,13 1/3in long
has been ran with 7.2 Nimh packs, but mostly 9.9v A123 1100mah. On 11.1v 1300mah 22c is like a rocket. Motors have been stock Black Race Viper, 3800kv Emp brushless and currently 480 Mig brushed (just for the winter months to run on the creek) 2.4 Tactic radio, Running Gear is all MHZ stock, original flex cable replace with 2mm shaft which freed up this boat immensly.
Minicat Racing Micro Hydro
All stock though current motor is 3800 Emp brushless w/25a Scorpion ESC w/pistix. Battery is 11.1V 1300mah 22c Desirepower lipo.
Meniscus
02-03-2010, 09:21 AM
Very cool damfurst. What props are you running? If you don't know, at least measure the diameter so that others can benefit of knowing what setup works for you. Any pictures?
Thanks.
hydromaddicted
02-03-2010, 11:34 AM
I was just trying to say it sure does'nt sound like 50-60 thousand r's in that video
hydromaddicted
02-03-2010, 11:42 AM
This is what a 60,000 rpm set up in a micro sounds like.
http://www.youtube.com/watch?v=CSsgCotkXsU
Meniscus
02-03-2010, 11:44 AM
Bad link, "http://http" should be just one.
Here you go: http://www.youtube.com/watch?v=CSsgCotkXsU
boater76
02-03-2010, 12:19 PM
I need something that can fit my 2s 3600mah lipo and turnigy built in watercooled 3600kv. Would prefer a hydro or cat. I had 2 hulls before and was not satisfied with the severly warped hatch and the one I just got in the mail is too small and can't fit them in.
Ken
sailr
02-03-2010, 01:06 PM
what is the physical size of the 3600mah battery? You may be asking for a lot to find a boat to carry that and still perform!
Ken
Meniscus
Can you provide dimensions of the lipo, motor and the ESC you're planning on using?
boater76
02-03-2010, 01:37 PM
Here is the motor and battery. 60amp Turnigy
http://hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=5145&Product_Name=TR_28-45_3600kv_Brushless_Inrunner_(WaterCooled)
http://hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=9504
http://www.r2hobbies.com/proddetail.php?prod=rcbp1814010
Meniscus
02-03-2010, 03:03 PM
It looks like you have some good components to get you started. The motor mount you are referring to is sold here on OSE: http://www.offshoreelectrics.com/proddetail.php?prod=ose-80100
If you take into consideration that:
your lipo measures roughly 5.5"
your ESC measures roughly 2"
your motor measures roughly 3"
Then you're talking about a model that has to have 10.5" worth of space up to 13-14" when you consider the receiver, stuffing tube, etc., without having to cram components in. This means that you'd probably be in the 17-18" model range in order to fit this configuration and allow for COG (Center of Gravity) adjustments.
My concern is, with your lipo being 2s or have a nominal voltage of 7.4V and the motor being 3600 KV, you are looking at 26,640 RPMs before considering loss due to driveline, slip, etc. Many of us are running RPMs more in the 33k to 36k range for sport boating.
You have a few options when you add all of this up. With the lower RPM, you could run a larger prop to make up the difference. Of course this will result in a larger amp draw which shouldn't be an issue for the lipo, but could be for the motor and the ESC.
Another option you have is you could pickup a 3s lipo at 11.1V. This would result in a high RPM, but would allow for smaller prop and result in less torque roll.
Regarding a hull for this exact setup, a good option might be a mini Sea Drifter at just under 18". You can see a picture here. (http://forums.offshoreelectrics.com/album.php?albumid=19&pictureid=813) This one is mine, but I might entertain letting it go. I don't know what your budget is and I don't remember seeing your goals for this build. This specific model is a little taller and your lipo may fit sitting sideways in the front.
Anyway, just a few ideas if you are intent on using the equipment you already have. Here's a link to one of these new, along with a video. (http://www.novahobby.com/brushless-mini-drifter-racing-boat-p-90.html)
I hope this helps. :thumbup1:
damfurst
02-03-2010, 04:19 PM
Thanks.
On the Gecko I have ran Graupner 4mm 30mmD 2 & 3 blade. Right now it has a 29mm 2 blade. Here is a couple of vids of it one with the brushless & one of the 480 brushed on the creek
http://rcuvideos.com/video/MHZ-Gecko-Zebra
http://www.youtube.com/watch?v=f4BcZ8vUJEU
Pics http://forums.offshoreelectrics.com/picture.php?albumid=131&pictureid=1337
The Micro Hydro has had a 32mm, with a 27mm currently with the 3800kv.
Here is the only vid of it in stock setup.http://rcuvideos.com/video/Micro-Hydro-by-TenShock-Mini-Ca
HYDROJERRY
02-03-2010, 09:53 PM
Hay fellas this may not qualify but i have a 17'' pickle fork hydro i got used, im trying to put back together, hull is plastic has a 4200 or 4800kv motor not sure wich one,will be using a 30amp esc i think and it came with a plastic prop and two octura x427 props. gotta put everything back together, hulls in two halfs. O will run on a 3s lipo, i think,,,:huh:
egneg
02-06-2010, 06:21 PM
I now have a micro rigger ...
HYDROJERRY
02-06-2010, 08:14 PM
aahhh looks cool, where did you get it,how much, how does it run,any pics of the inside lets see please....:banana::rockon2:
Meniscus
02-07-2010, 12:36 AM
LMAO!!!
I was just admiring this pic in your avatar in another thread. Then I find it here! :doh: There's something suspicious about those numbers on top :glare:
Hilarious and caught me off guard. :bowdown: So, I can I buy one of these micros at the street vendor over by the Loch?
Meniscus
04-08-2010, 10:54 AM
OK, I'm bringing this thread back up.
Share what you have in micro size or close to it!
Ctonez
04-08-2010, 02:20 PM
I also have a brushless gecko...
I think the motor is a Feigao 6S. I run it with a 2S 2050mah lipo.
It has the blue micro hardware from OSE.
45amp ESC with a Pistix.
does 30ish with a 31mm prop...still tuning.
I have yet to flip it...pretty much self righting which is really cool. Really really fun!!!
no video or pics yet.
NativePaul
04-09-2010, 03:09 AM
My Oncilla 430mm cat for mini hydro currently running on 3s1p 2300mAh A123, Mega 16/15/2, Castle Pheonix35, 1mm wiredrive, X427 with about 3/5ths its original blade area.
For reference the European Mini Mono, Mini Hydro, Mini Cat(where existent) and Mini ECO(the only Mini class which has been adopted by Naviga and gone worldwide at the moment) classes are all for hulls of 450mm and under(around 18") so there a decent and growing number of hulls in this size range.
http://i22.photobucket.com/albums/b310/nativepaul/oncillia001.jpg
Not the prettiest boat ever but function over form, the cockpit is that shape to fit the gear in and it does only just fit.
http://i22.photobucket.com/albums/b310/nativepaul/oncillia012.jpg
No room for or need for velcro to hold the battery in, it hasn't got anywhere to go, what you cant see here is the motor and servo, the servo is hidden in the tailpipe, although it has since been relocated to the starboard sponson.
http://i22.photobucket.com/albums/b310/nativepaul/oncilla004.jpg
The motor sits up front in the cockpit to maintain CoG and keep the bend on the wire to a minimum. Seen next to the battered and abused old 448mm Firecrest which it replaced, designed for a lot less weight and a higher top speed the sponsons are a lot narrower and there is much less tunnel lift.
http://i22.photobucket.com/albums/b310/nativepaul/oncillia013.jpg
First time in the water and she does float, Just.
http://www.astecmodels.co.uk/gallery/albums/uploads/Nats2009/nats2009_41.jpg
Running in Mini Hydro at the nats, different rules to my local series so running 2s 1800mAh 30C Kokam pack here on stock X431, I may make a slightly smaller but much prettier one for LiPo at some point.
Meniscus
04-09-2010, 09:36 AM
Paul, I really like that cat. I have a few questions for you if you don't mind. Where's your COG and also, do you have any other pictures of local guys that have similar small boats?
Thanks for the input guys!
NativePaul
04-09-2010, 11:41 AM
From memory the CoG is at about 40% now, was 30% in that photo of its first wetting with its arse under water, but it was too flighty there.
No similar boats, I believe I am the only one racing cats in Mini Hydro, I know I'm not the only one that has a mini cat but most are the scale type that are too narrow to compete with a rigger for ovals, although I have heard rumors that someone has made a self-righting F1 cat for this season. No close up pics sorry, I'm running on a crappy copy of windows without any service packs and Linux at the moment and neither will recognise my USB2 external had drives. Our first race of the season is on sunday assumeng my car makes it there, which is not a foregone conclusion at the moment, I will take some close ups of the mini classes for you, no action shots as I should be running. till then best I can do you is this closer shot of the Oncilla and a mini rigger.
http://www.astecmodels.co.uk/gallery/albums/uploads/Nats2009/nats2009_43.jpg
Theres a thread about my Oncilla here (http://www.astecmodels.co.uk/bb3/viewtopic.php?f=18&t=791) if your interested have a look, if your really interested I have the WoF templates on paper, we may be able to come to an arangement.
Those look neat. I need more time to build boats, looks cool.
I have finally seen a cat with a wider aspect ratio than the mean machine now!
Brian
Meniscus
04-09-2010, 01:28 PM
Great info Paul! This kind of input captures the spirit of this thread and is exactly what I had in mind when I started it.
I am very interested in the design plans and your lessons learned. I'm not so much concerned about the action shots, but definitely take lots of pictures of the models not on the water. As we begin to generate more interest in micros and minis here, it will help to show what the rest of the world is doing.
With regards to your car, remember there are a few things you should always have in the trunk. They are as follows: #1 Duct Tape, #2 Electrical Tape, #3 Zip Ties. If it can't be fixed with one of those, it probably doesn't need to be fixed! J/K, LOL! Realistically though, a set of pantyhose or extra serpentine belt is good as well as Starting Fluid/Ether. A cell phone isn't a bad idea either!
I hope you make it to the race!!! If I was there, I'd certainly give you a ride.
Meniscus
04-13-2010, 09:34 AM
Paul,
How did your race go? Did you make it?
NativePaul
04-13-2010, 11:50 AM
Yeah I made it, got the car fixed on Saturday, but my brain and my battery box didnt make it so the race didnt go for me, I did stay to do dutys and take some pics though. the wind was blowing in the worst possible direction and it was rougher than I have ever seen that lake before with breaking waves on the course, and conciquentially the micro classes were not very well supported we combined the classes to get a race but had only 4 starters, 3x mini monos and 1x mini ECO all selfrighting, after seeing the first heat I wasnt to disapointed about not being able to run, I dont think my Oncilla would have stood a chance.
Here are the close up Pics:-
H&m Redbird, Feigao 380 10s, 2s 2100 thunderpower LiPo.
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010002.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010004.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010006.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010007.jpg
NativePaul
Modified ToysPort Joker family, mini in the forground cut into 13 peices, some discarded and joined back together to make it under 450mm and narrower than the origional, standard in the middle, and large at the backwith bits of 3 boats grafted togeather for rough weather, the mini has a lehner 15 series, cant remember which one. on 2s LiPo.
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010009.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010012.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010013.jpg
NativePaul
04-13-2010, 11:52 AM
Eagle. cant recall who makes this on but its an old Mono1 hull from brushed daysthat at under 450mm is was too small for the Current Mono1, theres a few old hulls like these and my Firecrest coming out of retirement with the new Mini class power here is a Lehner 15series on 2s LiPo.
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010015.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010016.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010018.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010020.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010027.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010029.jpg
NativePaul
04-13-2010, 11:53 AM
Another Eagle, this time powered by a Mega 16/15/4 and 39mm prop, I forgot to ask what the LiPo was but from the low KV I would guess 3s (Electra (http://www.electrafying.com) my local race series, has a 43v maximum voltage limit for all classes and restricts power with a pack weight limit)
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010033.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010037.jpg
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010031.jpg
NativePaul
04-13-2010, 11:54 AM
Befu, wider aspect ratio than the MM is an understatement, I was very suprised when I got my MM how narrow it is considering the good reports I've had of its handling, it isnt any wider than some of the german cats, my Oncilla is only about an inch or so narrower despite being a foot shorter.
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010039.jpg
Because its carrying a lot less weight, 5-700g instead of about 2kg the ride plates are much smaller so although it is narrower than the MM the tunnel is considerably wider.
http://i22.photobucket.com/albums/b310/nativepaul/willenlakemicros2010043.jpg
Meniscus
04-13-2010, 03:25 PM
Paul, great pictures!!! Thanks for the link to Electra!
After I do some reading, I'm sure I'll have lots of questions, but in the meantime, I really appreciate you taking the pictures and convincing your local guys to allow you to take them. :thumbup1:
Meniscus
04-13-2010, 04:21 PM
Here's a video for anyone interested in what micros can do:
http://www.youtube.com/watch?v=9BuiITad0dk&feature=player_embedded#
Amp User
04-14-2010, 04:55 AM
Most of this thread shows what I would consider mini boats.
Micro boats are really down in the 16inch range. Nano boats are under 9inches.
Here is my10 gram out runner powered original micro rigger design.
weight ready to run 4.5oz.
Self made 20mm metal surface prop.
Rino 20C 3S 360mah Li-poly cells .
Radar confirmed 24mph with a 2009 Bushnell Velocity Gun on 37.4 watts.
No load 36,400rpm checked with a laser tach.
Note the motor uses silver winding wire for max performance.
(There is no boat going faster on a 10gram motor currently in the world that I know of and I have been watching for it.)
Anyone else willing to try to go fast on a 10gram motor? Prove it lol.
I replaced 248mah back into the 3S 460mah pack after the run in this posted video. Actual motor time 4.46 mins burning average of 55.6 mah per min.
It would take 8.27 mins to run the pack to 0 mah. Watt meter shows 12.4v .92amps no load at 11.3w. Average amp draw under load was 3.34amps,that's average watt draw of 37.4w. :buttrock:
Beyond Spec Races; All (types of boats) should be based on weight of motor for proper races along with cell count and mah range. Size doesn't matter after that as the designer will build to suit his power package.
The goal was to have a rigger ride high on its prop spinning as much rpm as possible from of one of the smallest outrunner motors on the market today.
To perform balls out with high rpm to give the operator the joy of performance from a very light and small rigger at minimal cost! This was made to enjoy small local ponds near home or right around homes. The size is not to harm turtles, birds or upset home owners with annoying activity and noise.
There is enough room for up to 26 grams of (out runner) motor. The design is stout enough to handle 45mph in moderate water conditions. Of course make fatter boats and you can shove 300watt systems in most sub 15inch boats with ease. The tub on this rigger at its widest point is 1.25inches and 1.15 inch tall in the belly area for the motor.
Enjoy the vid after about 4 laps I settle in close to the shore line.
Back in the day we had small, med and large boats. Times have changed.
:popcorn2:
http://www.youtube.com/watch?v=ok2rXbFo1jc&feature=related
NativePaul
04-14-2010, 07:58 AM
Race classes by motor weight is probably the least fair way you could possibly run a class, if one person can afford a 90% efficient motor and another can only afford 80% then the guy with deep pockets has double the output power available to him before overheating his motor than the other guy, if you have a set run time with a set battery energy the guy with deep pockets only has about 12% more output power, which is what we see here, guys with feiagos and zippys can compete against guys with lehners and thunderpowers and actually have a chance of winning as good setup and driving can easily make up for 12% more power which should yield a boat 4% faster down the straight, doubt even the best drivers can make up for 100% more power which should yield a 25% faster boat.
Meniscus
04-14-2010, 11:13 AM
Kyle, thanks for sharing your build. What prop were you using?
Paul, I was just talking to one of the local guys about the approach you'll are using to level the playing field. I really like the thought process.
Amp User
04-14-2010, 11:30 AM
Spec races that require the use of only a handful of preselected motors is for sure the best way to level the field with the same done for the batteries. I was refering to all the other races, when any motor brand is used in a given size hull. Pardon me for getting off subject.
Large, Medium, Small/Mini, Micro, Nano
NativePaul
04-14-2010, 12:23 PM
HydroNigel is definitely the man to beat in Mini Hydro, he always builds light and VERY fast boats, last time we raced was at the 08 nats, he won, I came second but that doesn't tell the whole story, he was on another level to the rest of the field, 4 laps up on me after our best two 5 minute heats.
I haven't seen that particular boat run, but I wonder if he gets the runtime on that setup or runs his laps then pulls in till the end, the Het 2w 4800 is a clone of the mega 16/15/2 that I use and on 3s 1500 LiPos should be spinning a few K higher, about 50,000rpm.
lucozader
04-15-2010, 12:46 PM
D-4nUFj0084
my baby
HYDROJERRY
04-15-2010, 01:16 PM
Runs good and the dog likes it cool..i keep trying to win some mini-c's on ebay to do the same with them but i keep getting beat...o welll
Meniscus
04-23-2010, 10:08 AM
Here's a boat video of a micro rigger out of France (http://www.dailymotion.com/video/x9whgi_micro-h-deuxieme-version-en-3s_sport). Enjoy.
And another video after tuning. (http://www.dailymotion.com/video/x4iflr_micro-h-a-fond-un-peu-trop-by-mf44f_fun)
305MIAMI
08-09-2010, 10:04 PM
who makes micro riggers? i have a starship and want to get a smaler rigger.
Amp User
08-09-2010, 11:56 PM
How small do you want to go as far as micro and how heavy is the starship?
Meniscus
08-12-2010, 09:09 AM
305MIAMI,
There are several available throughout the world. Amp_User's question is very appropriate.
In addition to his question:
What size are you looking for, what do you want to do with it (oval, small pond, swimming pool, etc) and what speed do you want to go?
4X4FABGUY
08-13-2010, 04:31 AM
Hi Guys, heres a pic of a couple of my little guys. The one in front is a wood hydromite I built from plans I got free and scaled down 14 inches. It has a mystery brand 3000kv outrunner and 25 amp spd con. I run a rhino 40c 3s 1050Mah lipo. The prop is a 432 cut down to 430, detounged and very thin and sharp. Its crazy fast. Very fun to run. The cat is a carbon fiber micro scat cat from BBY. Its now an empty hull, I am still looking for the right set up for it. Mike M http://i758.photobucket.com/albums/xx224/4x4fabguy/100_1425.jpg
Meniscus
08-13-2010, 09:36 AM
Mike, those are some good looking micros, nice builds. What setups have you tried in the micro scat cat? I've been looking at picking one up for quite some time and have crunched numbers and setups. Send me a PM and I'll share with you my thoughts on setup.
Can you confirm where you got that turn fin for the hydromite?
305MIAMI
08-13-2010, 11:21 AM
Welll i was thinking some thing like this check it out.
http://www.microhydros.com/stephan_lindenau/stephan.htm
305MIAMI
08-13-2010, 11:28 AM
This is my back yard where i can run almost anything!
Always flat!
MINY V-HULL AT HOME
http://www.youtube.com/watch?v=_8UMPec2Z1Y
MINY HYDRO AT HOME
http://www.youtube.com/watch?v=pD11d8fXtzE
sailr
08-13-2010, 11:39 AM
I tried the website that the guy said sells that beautiful little hydro but it's only a forum. No store. No products. Bummer. I would love to have that hull about 32" long!
305MIAMI
08-13-2010, 11:47 AM
This is really what I want but cant find one!
305MIAMI
08-13-2010, 12:36 PM
If i can get it to run like this i would be happy! LOL
http://www.youtube.com/watch?v=J9kOqcc198A
Meniscus
08-13-2010, 01:42 PM
I have communicated with Stephan through email many times before. If you PM me, then I'll provide his contact information. Otherwise, you can go to his website here: Translated Team Lindenau Link (http://translate.google.com/translate?hl=en&sl=de&u=http://www.team-lindenau.de/&ei=1oNlTKiLH5D4sAOg4OWpDQ&sa=X&oi=translate&ct=result&resnum=1&ved=0CBcQ7gEwAA&prev=/search%3Fq%3Dteam%2Blindenau%26hl%3Den%26prmd%3Dvd f)
He's really great at returning email and will provide pricing if you ask for it. One thing though, as a designer and a manufacture with limited free time, try to refrain from arbitrarily contacting him unless you're serious about ordering one.
Here's a video of the Atomos running. (http://213.239.214.134/lindenau/cms/cms/upload/videos/atomos.zip)
Hope this helps.
Meniscus
08-13-2010, 01:48 PM
That looks like and Eco hull. On this forum, User: 'sailr', see post #90, has some similar mini ones on his website that really jam: http://minicatracingusa.com/eco.html There's even a video for your viewing pleasure!
305MIAMI
08-13-2010, 02:25 PM
MENISCUS
WOW COOL THANKS
I think im gona order the ATOMOS its bad azz.
CaptPJB
08-13-2010, 05:06 PM
That is a great looking hull. What is it?
305MIAMI
08-13-2010, 05:17 PM
305MIAMI
08-14-2010, 10:03 AM
Does anybody have an ATOMOS?
i sent email to try to get one 87 euros.
305MIAMI
08-14-2010, 09:49 PM
CHECK THIS ONE OUT
http://www.myvideo.de/watch/2261618/SRT_Speeder
SweetAccord
08-31-2010, 07:34 PM
I wanted the ATOMOS a year ago at one point but then realized parts are non existent and support would not be a phone call away. Also, I've seen it run and was not impressed with the handling, seemed to bounce a bit and not handle corners well. It looks neat though! Instead I purchased a Starship from Mini Cat Racing and can't be happier. Great quality and great support. It has parts that are available and it's easy to setup and run. Motors are abundant as props and hardware.
Jim is great with support and is always very helpful, actually too helpful? We end up talking forever and it's wonderful, he seems to have a lot of time to help you with your needs not "limited free time". The Starship is a blast to run. I always get a crowd that gathers with 50 questions about it. I'm still tuning it with different props and batteries and am getting close to where it runs great. So far been using 1800 and 2200 3s (1550 are on the way) Lipo's and the 34x32 metal prop with a 3600kv 20-40 motor. Nothing gets over 120 degrees.
I like the Mini Cat line so much that I ordered the Micro Hydro. I'll post thought and results once I have them and will likely do a full review on both.
Thank you.
NativePaul
09-01-2010, 08:22 AM
RE the above post: I dont get it. What parts do you need for a Hull? If you damage it you fix it, patching with glass most likely, if you damage it beyond repair you cry then buy a new one. Motors, props and hardware aren't specific to a hull and there are just as many suitable for the Atomos as any other hull of its size. The comparison the Starship is apples and oranges the starship is a rigger and a much bigger boat, while the Atomos is very rigger like in its design and handles very well for a full bodied hydro, it is still a full bodied hydro and won't handle corners as well as a rigger can, and due to the size difference given the same size waves a small boat will always bounce around more than a bigger boat, that nothing to do with the boat design its just the physics of scale.
If you want a small full bodied hydro the Atomos is one of the best, but check out the MHZ mini Miss Madison too, thats scale, is still hellishly quick and if racing on a normal size oval turns plenty good enough, if you run a 2 buoy mini oval course the Atamos will beat it though with its wider stance cornering tighter at full speed.
SweetAccord
09-01-2010, 12:12 PM
What parts do you need for a Hull? = None it's ARTR.
If you damage it you fix it, patching with glass most likely, if you damage it beyond repair you cry then buy a new one. =This is true for all boats not sure what the point is to that statement?
Motors, props and hardware aren't specific to a hull = Sure they are check Offshore and Mini Cat's site for parts. They are specific to these hulls, they have to be cause of the size.
The comparison the Starship is apples and oranges = Sure, I never said that they are the same boat only point is that both are fast and small and one has parts available and full support not "limited free time" support.
The starship is a rigger and a much bigger boat = not really it's about 16" long, that is pretty small.
The Atomos is very rigger like=I don't see how it's rigger like it's a Hydro like you said.
The Atamos will beat it though with its wider stance cornering tighter at full speed. = The Starship has a much larger stance in width in the front. I have tried to flip it and can't seem too. It turns like it's on rails and I don't even have the optional turn fin on it!
What are the Atomos hull measurements? So we can compare the width?
Don't get me wrong the Atomos looks great and all but getting parts (if any as none are listed anywhere that I was able to find) and support from over seas is difficult. Like I said, I looked at the ATOMOS for over 3 months of web searching and reading forums, and don't find anything for parts or phone support.
Peace.
SweetAccord
09-01-2010, 02:02 PM
I just got the Mini Cat Hydro and it's sweet! I will be posting video's on the Starship soon.
NativePaul
09-01-2010, 05:55 PM
What parts do you need for a Hull? = None it's ARTR. = I was trying to ascertain why you would need parts for a boat hull, and the atomos is sold as just a hull by the way not a RTR
If you damage it you fix it, patching with glass most likely, if you damage it beyond repair you cry then buy a new one. =This is true for all boats not sure what the point is to that statement? = As above just trying to ascertain why you think you need parts for a hull.
Motors, props and hardware aren't specific to a hull = Sure they are check Offshore and Mini Cat's site for parts. They are specific to these hulls, they have to be cause of the size. = No there not, just specific to a size of hull, minicat, HOtR, ETTI, MHZ, Astec and Dr Psycho all do hardware that will fit the Atomos as well as any other mini size boat. Feigao, Mega, HET, Nue, Lehner,tenshock and many other chinese companys make motors suitable for the Atomos or any other mini sized boat. Octura, Graupner, Hor and Tenshock all make props suitable for the Atomos or any other mini size boat.
The comparison the Starship is apples and oranges = Sure, I never said that they are the same boat only point is that both are fast and small and one has parts available and full support not "limited free time" support. = The Atomos is a bare hull, no parts or support are needed.
The starship is a rigger and a much bigger boat = not really it's about 16" long, that is pretty small. = Please forgive me, here in the UK there are 2 starships, one called "starship" (hydro1 size) and a "mini starship" (what you know as the starship) I forgot that there was only 1 in the states so when you said "starship" I was thinking of the bigger one.
The Atomos is very rigger like=I don't see how it's rigger like it's a Hydro like you said. = primarily its length to width ratio, while not as wide as a rigger it is much wider than a scale hydro, but it also has little in the way of tunnel lift, as the tunnels is exceptionally thin and it has no air traps, what lift it does have is as far back as possibe as seen in the pickle forks which start at the back of the sponsons, it is not a rigger, But like the insane sport hydro its as close to a rigger as it is possible to get while still being a full bodied hydro, if you saw the bottom of one in the flesh you would get it.
What are the Atomos hull measurements? So we can compare the width? = The Atomos is 420mm long and 230mm wide, the ride pads go nearly to the outside, for comparison the scale MHZ mini Miss Madison is 435mm long, 225mm wide and the ride pads are tucked in under shallow anti trip angles.
FECrazy
09-01-2010, 06:14 PM
Here's the thread link to my 14" F1 Tunnel Hull
http://forums.offshoreelectrics.com/showthread.php?t=17513
FE Crazy
NativePaul
09-01-2010, 06:15 PM
I saw that earlier it looks very good, cats are my bag baby, I may have to pick Up one of them or at least half of one from Allan.
FECrazy
09-01-2010, 06:28 PM
NativePaul
Alan's got a sale going on right now on all H&M hulls.
He's a super good guy.
My first hull got squished by the Posties, and he immediately sent me a replacement.
Unfortunately for me, like you, I really like his F1 Tunnel Hulls, so I now have 2 !
He's got micro hydros, monos, 2 different cats and the F1 Tunnel Hull !
Cheers,
FE Crazy
SweetAccord
09-03-2010, 06:38 PM
I've run the Tenshock again and great results. This boat just does not disappoint. This setup is with a 3600KV on 1800 3S with a D32mm X P34mm prop. Plan to get more tuning into it to get more speed.
Here is the video as promised:
http://www.youtube.com/watch?v=YoPuUuX2hk8
Enjoy!
steamboatbob
09-03-2010, 07:45 PM
here is my micro tunnell hull built from templates out of a pacific balsa kit in ply
http://i231.photobucket.com/albums/ee84/steamboatbob/The%20Dictator/29072010229.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/The%20Dictator/26082010256.jpg
ok stats the motor and esc are out of a jowsway ripmax boat
length 380mm long OA / 15 inches
width 170mm
motor unknown 2445 kv brushless water cooled
esc unknown 40 Amp
best prop X430
Video
running on 7.4 V
http://www.youtube.com/user/MrSteamboatbob#p/a/u/0/Ptj1UognfDM
running on 11.1V
http://www.youtube.com/user/MrSteamboatbob#p/a/u/1/tyKmeJ_As30
:banana:
steamboatbob
09-05-2010, 08:30 AM
ok slight addition to my little boat pics
http://i231.photobucket.com/albums/ee84/steamboatbob/The%20Dictator/DSC_0361.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/The%20Dictator/DSC_0332.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/The%20Dictator/DSC_0333.jpg
SweetAccord
09-05-2010, 10:19 AM
Well, here is one thing that the Mini Cat Starship can do that the
Atomos can't, the people in the video are having a blast! Pretty funny.
http://www.youtube.com/watch?v=QKBLp3UsXPo&feature=youtube_gdata_player
britscoot
09-05-2010, 05:54 PM
anybody manage to get hold of the atomos guy?
I'm having no luck.
SweetAccord
09-12-2010, 12:52 AM
I'm having no luck.
My point has been made, good luck on customer service. Oh, wait there there is no service cause you can't even reach'em. Good luck anyways really most sincerely.
Peace.
Meniscus
09-16-2010, 04:05 PM
You are all quick to pass judgement on a custom manufacturer. Have you considered that they may have shut down the daily operations to do testing and travel for races?
I would be patient. If you are looking for a more immediate solution for your hull hunger, consider talking to Randy at BBY. He has many micro hulls that aren't displayed on his website that are in stock and ready to go. If you want a custom version in Carbon or Fiberglass, he can accommodate as well. I can personally guarantee that if you call him, you will get him on the phone.
Meanwhile, I'll try to see if I can reach Stephan at Lindenau for you guys.
britscoot
09-16-2010, 04:11 PM
If you could get hold of Stephan that would be great!
I want the Atomos....!
But i will be patient as i have other things going on.
Cheers
Gerwin Brommer
09-17-2010, 06:22 AM
About Lindenau : even the Germans now have problems contacting Stephan.
Maybe he's just too busy ?
SweetAccord
12-14-2010, 02:52 AM
Well any luck?
sailr
12-14-2010, 02:57 AM
We are still here and we will answer you!
SweetAccord
01-24-2011, 03:27 PM
Update:
I've been talking to one person who has the ATOMOS and as much as he seems to like it also says how it's finicky to setup. He's made it clear that it took him a year to finally get it dialed in. He also mentioned how parts are non-existent as this is all custom made so if you break it you have to fix it. As much as I like from what I've seen on this boat I'm not 100% sold on it unless you are the type that like to make your own parts and do not need support etc.
I have e-mailed them 6 months ago and have not heard anything still. This is a good example where a company like OSE and MiniCat Racing and others are there for you and have the parts and has the support to back up the product which I have been more than happy with. I think it's sad as that boat looks very nice and I would love to own one.
martin
01-25-2011, 04:03 AM
Dont hold your breath on getting any Lindenau boats, I was told he stopped answering mail etc quite some time ago & that he has/was going through some very personal problems. This came from a guy in Europe that is a serious racer who had ordered & payed for a boat but never ever got it & didnt get any answers to his mail sent. I believe their were others that payed & didnt see their boats, I was told do not pay money into his account as i was interested in an Atomos. Thanks Martin.
SweetAccord
01-25-2011, 11:49 AM
Right, that is how all this seems to be playing out, thanks you for the info.
Gerwin Brommer
01-31-2011, 10:40 AM
Yep, forget MR. Lindenau !
What about : http://www.hdanz.de/html/minis.html ??
Very nice boats and a very very friendly man !
He asked me if contact can go via me. He's bought a new house and needs a new provider. So his site will be offline for some time.
Meniscus
02-23-2011, 03:36 PM
Gerwin, what is the current preferred platform folks over there are using for hydro 1?
Any more info on those fiberglass riggers that were supposed to "appear" beginning this year?
jacksblack
03-19-2011, 10:26 PM
I had a proboat mini cat with a eflight 3700kv in runner.
Works great on smooth water but slightest ripple and it was all over, mines launched out of a ripple into a stationary rock, didn't end up to well for the cat:(
Meniscus
03-19-2011, 10:32 PM
Sorry to hear that. I haven't run any of the small cats yet, but my understanding is that for a general rule of thumb, set the strut very high and push the COG as far forward as possible and still get up on plane.
Did you ever fix her up? You know there are a few very nice small cats available in the marketplace. I've been toying with the idea of building one next Winter.
jacksblack
03-20-2011, 01:46 AM
I bought a sv27 since that which is going through a re build and I am trying to find a 32" cat to make a twin engine fe.
If a new mini cat hull pops up at the right price I will get another one, I love the mini cats they are so much fun and no body expects them to go as well as they do with a brushless in them.
