HappyOne
05-15-2009, 09:05 PM
Seems that there is an issue with an Ammo BL motor I have. It came in a boat that I bought used. When I first tried to use it, the motor would stutter and get really hot. That was only from a few one second bursts. I have taken the motor out of the hull and I have been using some WD40 on the exposed part of the front and rear bearings. I can now get the motor to spin properly but it is still not spinning as quickly as it should and it is getting really hot after spinning for a few seconds at a time.
Are they easy to take apart and re-lube or change the bearings ?
What motor timing should I have the ESC set to on 4s?
Thanks.
Thanks.
