Dear god i just put togather the biggest pile of junk ive ever seen. I had a Bandit Larsony SAW hydro that i built, it was perfectly ballanced with a 1521 1.5d , 240 hydra 22 volts and a m645 prop. Boat had gone a best of 74mph but took a bad blowover one day at 70 and cracked up the hull in a few places. So i took guts out and put it all into a Miss Attitude hull, 1 inche longer and 2 inches wider out back. Swaped everything over close to the Bandit boat specs. I put this TURD in the water and i swear i fished it out 20 times. It does not have a turn fin yet turns on a dime. ??? It will dig the left sponson in for no reason on a flat water run and flip . ?? It will flip if you get off throttle to fast.?? The only way to get the boat to remotly get up to speed is to angle the prop at a crazy "prop up" angle up ...it did go 66 mph and ovecorse blew over. I shoved batteries all over with only slight changes in performance. What the hell did i do?. Ballance point is 2 inches past sponson. This boat hates me
