View Full Version : Motor replacement for UL-1?
jingalls007
05-06-2009, 08:54 PM
I wanted to run some larger 6 series props with a 120 controller, is 9xl too much?
detox
05-06-2009, 09:01 PM
I think the 6 you are refering to is the pitch
Example... Octura m645... the 6 is the pitch and the 45 is diameter in millimeters
detox
05-06-2009, 09:08 PM
I was wondering the same thing...I also have the Fiago 9xl and a Hydra 120 esc. I do not know if the esc would live using 4s1p. It should easily work using 4s 2p 8400mah.
It seems to me that the UL-1 likes the lower 4 and 5 pitch props better.
jingalls007
05-06-2009, 09:10 PM
Higher Pitched props is what i was referring to. Now back to the motor, any suggestions?
jingalls007
05-06-2009, 09:12 PM
you just posted this as i was responding to the other, so ya, the question remains- what may be a good upgraded motor for the UL-1?? hmmm..
Jeff Wohlt
05-06-2009, 09:20 PM
Grim suggested the ammo 2300 on the stock SV and never heard of any problems. The 9Xl can be prop up as well becaus it is a lower KV...very close to the SV motor. Remember as well...more poles are easier on the ESC. Ammo is 6 pole. When doing this just be sure and prop down and move up after some testing. Amps will remain lower until you begin proping it up. Might try anything around 2200 rpm and at least a 56mm motor but do not go over 2300.
LuckyDuc
05-06-2009, 09:40 PM
I'm going the Medusa 36-060-2200 route. I plan on pairing it with an Etti 150 and starting with an Octura m445. This is my intended IMPBA P Sport hydro setup.
detox
05-07-2009, 06:01 PM
I really like the Grimracer L40 x 57/3 prop. I think getting this prop to spin faster in the UL-1 is just the ticket for good handling and higher speeds. The Ammo 2300 sounds like a good idea and so does the Fiago 8xl.
jingalls007
05-07-2009, 06:17 PM
I think im going to get that ammo 2300, tunrigy 120, and the m440 you suggested. should be fun.
Ub Hauled
05-07-2009, 06:26 PM
NEU 1515/1Y and prepare to fly...
just as a footnote, this hull was not design with
huge speeds in mind, I think Grimm himself mentioned
40-45mph or around there somewhere. Once you start changing
motors to go faster and faster, it will be a loose canon... just watch
out for kids on the shoreline, ;)
jingalls007
05-07-2009, 06:30 PM
Agreed! I wouldn't go any more then what's been suggested to me here. i like to push the envelope but not be unsafe.
LuckyDuc
05-07-2009, 06:36 PM
Just keep in mind that the ammo 2300 has a shorter can (50mm), so it will most likely build alot more heat from the extra wattage your pumping through it at those rpms. The stock can is 56mm long. If you are going to up the kv/rpms you should look for a 56mm or longer can.
jingalls007
05-07-2009, 06:41 PM
I though the ammo ran more efficently then the stock AQ motor. from what i've read the ammo motor runs very cool, however, each application is different. and since this was the upgrade motor for the SV and has been tested I figured it may be a decent upgrade for the UL-1. Originally I intended an XL motor, maybe an 8XL or 9xl. I've looked at those Medusas but i don't know much about them. your going to get the 36-60-2200 correct? what water jacket will you use?
LuckyDuc
05-07-2009, 06:55 PM
I’m not familiar with the Ammo 2300, or it's use with the SV. Are they running similar sized props... i.e Grim L40x57 3 blade? Cool temps on the outside of the motor can trick people into thinking that a motor is running within it’s limits when it may not be.
I can’t speak to the medusa in this application, but I do run a few of them in my EDF jets. They handle huge watts and spin 45,000 – 50,000 rpms constantly without a hiccup. I'm sure that the Neu 1515 will rock too. A tad out of my price range though. I plan to measure the Medusa when it arrives, and test fit my after market UL-1 jacket on it. I'm sure it will fit just fine.
jingalls007
05-07-2009, 06:56 PM
im intrigued by the medusa motors, never heard of them until you mentioned them. when are you planning to stick that in your ul-1?
LuckyDuc
05-07-2009, 06:59 PM
Hopefully next week.:banana:
jingalls007
05-07-2009, 07:00 PM
cant' wait to see your eagltree data read 60+ with your setup.:laugh:
Brushless55
05-08-2009, 12:57 AM
Let me know when you get this setup running, I want to see it run... I'll bring my camera. :banana:
Ub Hauled
05-08-2009, 03:21 AM
I forgot to mention this, but make sure that you can fit a can that is that long in the UL, if I remember correctly, there is a bit of an angle on the motor mount and if the can is too long it'll hit the hatch... borrow an XL and stick it in there for fitting...
detox
05-08-2009, 05:30 AM
I am sure the XL and the NUE 1515 size motors will fit. You can also set the Hydra 120 ESC on top of motor and hatch will clear it. Thats a 9XL and a NUE 1515 1y/s in picture.
LuckyDuc
05-08-2009, 08:54 AM
I see that your 3300 4S packs arrived. Have you tried them yet?
jingalls007
05-08-2009, 10:41 AM
I most definitly will. Steve's out of the motors I need right now so it may be a little while, but Ill let you know.
Brushless55
05-08-2009, 12:12 PM
Awesome!
here is a vid of my stock UL-1 doing 48mph
http://www.youtube.com/watch?v=OSOzWkoAYU8
jingalls007
05-08-2009, 12:18 PM
Awesome!
nice!! where in Longmont is that pond??
Brushless55
05-08-2009, 12:32 PM
My Mom's in Platteville
she lives next to a sod farm and that is there holding pond..
detox
05-08-2009, 04:00 PM
I've been working nightshift and have not gotten around to it. I will do a test run using these packs in the stock UL-1 probably this Sat. or Sun. It seems the UL-1 likes a more forward COG which is why I have them arranged differently (sideways) in picture.
Brushless55
05-08-2009, 04:48 PM
any one though of an 11L ?
I was thinking of trying one in my SV and possibly try in my UL-1
Ub Hauled
05-08-2009, 04:59 PM
The "L" can may give you good speeds for a couple of passes, but I don't think it'll be good for more then that... it's a 2 pole motor, a lot of RPMs and not much mass to dissipate the generated heat. I used a 9L on my Dark Horse a couple of times and
got her in the 60's but the heat was too much even with a cooling jacket, that'll give you an idea.
Brushless55
05-08-2009, 05:11 PM
The 11L is a 2200kv motor, so not that high of rpm.. only about 10% higher than the UL-1 motor
Ub Hauled
05-08-2009, 05:14 PM
I know, 2234 actually... still a small can with 14.8v (nominal) hooked to it, it'll turn out to be 33,000+ RPM
Brushless55
05-08-2009, 09:39 PM
only 3k more and a slight bigger can that the stock UL-1 motor
