View Full Version : Tactic receiver goes up in flames !
properchopper
05-05-2009, 07:36 PM
Here's what happened : Ran my Shovel out from the stand, turned right & forgot to reverse the steering from my UL-1 setting, { yeah, I know, should'a checked it first :doh:} so I flipped it - 60 mph hydros don't like left turns :w00t:. Got the rescue boat out to the shovel; blipped the throttle & it worked. Got back to the table, untaped & the rcvr was on fire !! Melted all the connectors & the case. Here's 3 possibilities :
1] My CC BEC was prgrmd for 6V out [ leftover setting from my LSO boat which needed some grunt to steer left]. I metered the BEC & it was right at 6V out.The UL-1 BEC puts out 5.2 V at 2 Amps ; the CC BEC puts out a "max" of 10 Amps. Overload ?
2] seemed wet, although it was Corrosion X'd, possible water shorting ?
3] random smoke-exiting for unexplained reasons.
I'm liking #1 explanation & will eliminate the CC BEC & use a rcvr pak most likely. Be Advised !!
This was right before I destroyed my sweet, sweet VS-1 by running it into a turn Buoy. What a day !! :ohmy:
Flying Scotsman
05-05-2009, 07:54 PM
Tony, #1, never use BEC
Douggie
theShark
05-05-2009, 09:06 PM
Whoa, hope nothing else got buggered. I use BEC in everything even if the esc has a bec an external will let the esc run cooler.
properchopper
05-05-2009, 09:14 PM
Douggie
the Hydra 240 BEC that I was running has the BEC bypassed [ red wire interrupted]. I was using an outboard CC BEC.
properchopper
05-05-2009, 09:18 PM
That's exactly why I run an external BEC on pretty much all my fleet except for the watercooled, Etti-capped CC 80 in my UL-1 which stays within a reasonable range [ @ 110 deg]
05-06-2009, 04:29 AM
Wow Tony thats the first I've heard of any rx. Did you see an actual flame or just smoke?
For years I have always just a cheapo 4 aa holder. So far they have never failed me, but I do use lots of Energiser batteries.
Simon.O.
05-06-2009, 05:27 AM
Tony, without seeing your setup, as seen and smoking, I can not offer a lot of help other than a 6V pack vs a 4.8V pack for a LSO justified by a powerful steering servo is a bit off.
I run a super-crawler, local mates only style comps and a 6V rx pack is fine (needed) there. These run 15 kg (35+lb) servos.
Fwiw. For a Rx pack for my boats I use a 9V flat cell that is commonly found in domestic smoke alarms, I hope you all have one or more and they work.
These are a low Ah cell but have high V for the Rx. They work for me well.
I have had one of my favourite Rx's wet so many times it is well less than funny. Each time it comes back for more. I have to do a waterproof rx box for the opc tunnel
I am surprised that a Rx would fry, including smoke.
05-06-2009, 05:41 AM
Simon I also used to run the 9v packs when I first started, but when the esc switch was rolling towards brushless, we were all told that brushless esc's would have issues with 9 volts. Wonder if that was false?
2.4 MHz recievers do not like 9V.
Ray
bustitup
05-06-2009, 06:43 AM
those can be just as bad....I never use a bec any more..... ALLWAYS RX BATT PACK NOW
Wow sorry to hear you had such bad luck Props :sad:.
Flying Scotsman
05-06-2009, 11:33 AM
Woops, sorry Tony I did not see external BEC. Although, that was possibly the cause with a malfunction or more likely a RX issue
I run a external 5 cell NI-MH 1400mah packs and have had no problems. I just do not like BEC circuitry within the RX
Douggie
Ub Hauled
05-06-2009, 12:02 PM
I was present at the time, it's a matter of fact, I asked him to go out one more time to play, I feel a little guilty but not much ;)... it would have gone up in flames anyhow...
I think the only reason there weren't any flames it's 'cause the Rx was in a balloon and had no air, it was a pretty thick smoke. I wanna say it was some sort of Rx failure, specially since it worked a couple for a rounds earlier.
Does anyone have an instruction sheet for the Rx? What is the max voltage specified for it?
Flying Scotsman
05-06-2009, 12:13 PM
The problem with 9v nominal is that many servos will self destruct, as they are designed for 6v nominal, give or take 25%. Ask a Hitec service tech this question and you will have an interesting answer.
Douggie
AndyKunz
05-06-2009, 01:02 PM
Rex - Spektrum takes 9V just fine. Read the specs here: http://www.horizonhobby.com/Products/Default.aspx?ProdID=SPMSR3100
6V is usually not going to be a problem. I'd be very surprised if the Tactic rx fried from that, since most guys run 5-cell batteries on their receivers. Tower doesn't have a voltage spec on their website.
The CCBEC is a pretty good product.
Andy
properchopper
05-06-2009, 01:19 PM
The UL-1 speed control puts out 5.2 V from the BEC circuit and apparently is designed to be compatible with the Tactic Rx since the UL-1 comes that way. It also outputs 2 amps. The Castle BEC was putting out 6V [ I metered it] although it can put out "up to" 10 Amps according to it's label. This was a pretty serious meltdown and I'm still a little baffled !
Blackjack-sven
05-06-2009, 01:33 PM
I'm guessing that there was a closed short within the Rx when it got wet allowing all 10amps from the cc bec through all at once. I've seen this happen a few times before. Also, the pic you show above shows that the heat generated from whatever went through the bec port.
properchopper
05-06-2009, 02:11 PM
I'm inclined to put this explanation on top of the list of probable causes. Thanks for the input. :tiphat:
theShark
05-06-2009, 02:26 PM
The tactic is marketed for Cars, Trucks, Boats, Nitro, Gas and Electric so its more than likely it can take 6V
LuckyDuc
05-12-2009, 12:17 AM
I have 70 + runs on my Tactic Rx in my UL-1. I have a an external ParkBEC supplying 6volts to it. No problems here.:confused2: I think you had a short and it dumped 10amps into the Rx all at once.
