Mikey D
05-04-2009, 06:01 PM
Greetings
My apologies if this was stated elsewhere in the forums. I am a newbie crossing over from the R/C Airplane world.
I noticed talk of a Octura M440 prop.
Upon closer inspection of the M440 Prop it appears to have a couple notches (I assume to prevent any slippage on the main shaft. I did not see the matching male notch on the UL-1 stock shaft for the stock propeller.
I noticed there is an adapter called a "Drive Dog".....am I assuming correct that this would be required to run the Ocutra M440 prop?
If so there were several to pick from...which one on the "Offshore" site should I pick?
Thanks
Mike D.
My UL-1 is awesome...!
Thanks
Mike D.
