View Full Version : MiniCat Hydro speeds/setup.
Does anyone have Links to any Mini hydros like the carbon edition ect. going
faster than 45mph? If so whats the setup esc motor prop and how many cells?
Iv been thinking about buying one, there decent right out the box from what Iv seen.:tongue_smilie:
repsol
01-25-2011, 09:13 PM
Sidewinder tenth scale 4600kv 3s & 32x36 prop and 45 c Hyperion 1900mah
repsol
01-26-2011, 12:18 AM
Sorry here was a link
http://www.youtube.com/watch?v=KmrO58tu2eQ&feature=youtube_gdata_player
badag98
01-26-2011, 08:15 AM
http://forums.offshoreelectrics.com/showthread.php?t=20661
Have a stock one listed for sale!! Pretty quick out of the box.
electric007
07-27-2011, 09:53 PM
Sidewinder tenth scale 4600kv ok,,, but what esc.
repsol
07-30-2011, 11:37 AM
The sidewinder comes as a package I'm using the car speed control,
I've used it with and without cooling plate
And didn't notice any difference in temps.
On another note the stock cable drive won't take all the power so I made a.048 wire drive with an Octura collet for motor coupling.
Flex hex I've found to be more reliable than set screw couplers.
bracka69
09-27-2013, 05:30 PM
Hey Repsol. What kind of prop are you running? Is it the stainless or plastic prop?
Thanks
SloHD
09-30-2013, 11:15 AM
I would not run that setup on 3s. Way too much rpm, even for 2s... The hull is not fun like that. You want somewhere around 3300kv for 3s. The boat is money with a stock-ish setup.
I run mine 3300kv, seaking 35a, with an x435 prop
bracka69
10-01-2013, 03:34 PM
Thanks SloHD. I have 2 Micro Hydros, a first generation which is my boat to test different set ups with and a second generation CF which I have ran on 4s and it is wicked fast like that. In my test boat I just installed a TP2930 4100kv motor with a seaking 60A esc. Just trying to decide on what prop to use.
