View Full Version : My rebuilt UL1
alvinsmith75
04-30-2009, 07:48 PM
I haven't run since replacing the cap yet but I blew the cap and have replaced it with these new ones. I am also using a Fullers strut, Hughey cable, and octura collet. I didn't take a pic but there is an air damn under the boat as well made from balsa that I coated in epoxy and attached with double sided tape. Hoprfully I will be able to see the water flow from the discharge better with the brass tube I added. Still no leak from water jacket and no stress cracks. Knock on wood.:biggrin:
http://i378.photobucket.com/albums/oo229/alvinsmith75/Rebuilt_UL1.jpg
http://i378.photobucket.com/albums/oo229/alvinsmith75/Rebuilt_UL1_2.jpg
http://i378.photobucket.com/albums/oo229/alvinsmith75/Rebuilt_UL1_3.jpg
http://i378.photobucket.com/albums/oo229/alvinsmith75/Rebuilt_UL1_4.jpg
detox
04-30-2009, 08:07 PM
Now it will be easier to see the water exiting stern. How did you fix your ESC? Does it work like new now?
alvinsmith75
04-30-2009, 09:46 PM
I just replaced the blown cap. Brian Buass told me how to do this. It works fine on the bench but has been too windy to throw in the water. I'll post when I try it to let everyone know.
Alvin
LuckyDuc
04-30-2009, 10:27 PM
Could you post a "How to" thread on replacing a blown capacitor? I'm sure many of us UL-1 owners might find that very helpful.
It looks like you had a fire in the hull based on the pics. What happened?
Capt. Crash
05-01-2009, 08:00 AM
Y'all must have better eyes than me to see water coming out this hauling boat! I don't see why it matters if ya can see it, as long as she's running cool? :olleyes:
detox
05-01-2009, 08:59 AM
Who peed in your Corn Flakes Capt. Crash?:tongue:
Capt. Crash
05-01-2009, 09:31 AM
Hey I wasn't meaning it ugly! I was just wondering why you need to see the water jet? :zip-up:
detox
05-01-2009, 10:44 AM
Like all water cooled boats it's just good to know that water cooling system is operating correctly. Using the 45 degree bend just allows you to see it better.
Capt. Crash
05-01-2009, 12:27 PM
I'm all for functionality, but I also like clean looks. If I could get rid of the ugly external tubing hanging off the back of this boat I would. My cracker box boat has the cooling intake and outake on the bottom of the hull. Works just fine and looks great cause ya can't see it.
jingalls007
05-01-2009, 12:48 PM
just curious what caused the ESC to fry in the first place.
alvinsmith75
05-01-2009, 05:51 PM
Too large of a prop! Not that the prop was too big but I ran it longer than the esc could handle. It was an m645. It looked awesome though. Too bad I forgot to start timer on the GPS. The fire was from the Etti ESC I tried afterwards.
jingalls007
05-01-2009, 06:23 PM
I cooked my ESC with an X645 detunged and the boat basically popped a wheelie across the water and it was pretty awesome. Im going to hook up a 120 amp controller and try it again, see what happens. What was your amp rating on your ETTI? I may rethink the X645 if it's going to burn up a new controller.
alvinsmith75
05-01-2009, 09:10 PM
Dude my etti was the 150 non bec and it didn't last 4 minutes. I would try a xl motor with the 120, then you should be safe.
detox
05-01-2009, 09:29 PM
Here's a neat chart written by Brian Buaas for Castle. I think this chart is for Lipo's with lower 20c rating. The Fiago motors may or may not allow smaller battery sizes?
http://www.castlecreations.com/support/documents/neumotors-castle_boat_apps.pdf
alvinsmith75
05-04-2009, 07:13 PM
UPDATE!!!!!
Got to run the beast today. Cap upgrade worked great. Ran about 2 min. with stock prop @ 41.7 on GPS. Then I swapped props and ran another 2min with a (I think)38x55 2 blade Grim racer @ 43.9mph. I have strut depth @ 1and a 16th with 1deg. neg. and air dam. 2 thunderpower 4s 3850mah in parallel.
http://i378.photobucket.com/albums/oo229/alvinsmith75/UL1_5-4-09.jpg
http://i378.photobucket.com/albums/oo229/alvinsmith75/UL1_5-4-09_2.jpg
http://i378.photobucket.com/albums/oo229/alvinsmith75/UL1_5-4-09_3.jpg
http://i378.photobucket.com/albums/oo229/alvinsmith75/UL1_5-4-09_5.jpg
Boat is nose heavy sitting in the water with lipo's. Had to punch it to get on plane. Will put gps in rear next time.
VIDEO!!!!!!!!!!!!
http://www.youtube.com/watch?v=CfDPIfcY43Q
Oh yeah and I can see the water coming out better and temps were as follows
ESC 114
Caps 120
Motor 130
Batts 106
Time for a more aggressive prop!
Rumdog
05-04-2009, 08:42 PM
i'd leave the gps in the front. it's in the nature of a hydro to have to punch it to get it on plane. if the cg is too far back it'll start chine walking pretty badly. looks good in the vids man!! try out the octura 440/3, i was getting about 47mph with that one and hanging real tight corners wot.
alvinsmith75
05-04-2009, 08:46 PM
I have an 437/3 and an 537/3. Would these be safe to try?
LuckyDuc
05-04-2009, 09:34 PM
Nice Vid! Nice battery choice too. Those should pack alot of wallup:thumbup:
Try and get a temp reading on the solder joint where the parallel meets the ESC leads. Just curious what you're getting after a good 3 minute WOT run.
detox
05-04-2009, 09:44 PM
Alvin, Try using just one of your 4s packs mounted on the left hand side of UL-1. Lighter weight may make you faster. Adjust your turn fin slightly upwards so boat will not be loose in the turns. I run 50mph without use of airdam.
Here's my setup:
http://forums.offshoreelectrics.com/showthread.php?t=7539
alvinsmith75
05-09-2009, 05:35 PM
2nd run specs
Prop octura y537/3
run time 3min 40sec
total distance traveled 1.71 mi.
MPH on gps 46.4
Temps
Motor 125
esc and caps 109
lipos 96
traxxas connectors 86
Temp @ parallel connection 94
When I put my batteries on charge they were @ 15.5v and when thay finished they had taken 1534mah
What does this number mean anyway? (taken 1534mah)
Thanks,
Alvin
jingalls007
05-09-2009, 06:10 PM
Alvin,
How does it handle coming out of the corners with that setup?
alvinsmith75
05-10-2009, 03:50 PM
Alvin,
Not sure how to answer that. I an not an experienced driver at all and have nothing to compare it to cause this is my only hydro ever. I'll try to get you a video this week with the same setup. Maybe you can look at it and give me some advice.
Thanks,
Alvin
jingalls007
05-11-2009, 10:50 PM
Thanks,
Alvin
Im also new to Hydros so perhaps the blind leading the blind :confused1: I was curious to know how that prop handled the turns and excelled out of the turns. My m440 was a great prop in the straights, not so much coming out of the turns. My L38X55 however was great for both but temps were higher. I was just curious if you had noticed any of the above with your 537/3 or your 437/3.
Brushless55
05-12-2009, 02:06 AM
Jingalls, I have tried a 437/3 and liked it a bit more than the m440..
I still need to try a L38x55 but you say your temps were a bit higher..
Rumdog
05-12-2009, 09:05 AM
how the hell did you burn up an etti 150 in a ul-1?!?!
jingalls007
05-12-2009, 11:30 AM
temps were higher in the 38X55 but still not hot enough to burn anything up. I ran for 10 minutes as i do all of my runs.
alvinsmith75
05-12-2009, 04:16 PM
I am pretty sure I had a short somewhere. Be careful of the Etti's I believe it was the wire going to the receiver. From the factory it it tie strapped to the battery wire and runs between the caps. The wire was burnt in that area, I should have caught it but didn't. Steven and Etti have great support. The esc and extra cap board were replaced in about 3 weeks.
alvinsmith75
05-14-2009, 09:37 PM
Alvin,
Video with y537/3 I am not an experienced driver but this prop is fast and fun 47mph.
http://www.youtube.com/watch?v=4Xnqdq8NkyM
http://i378.photobucket.com/albums/oo229/alvinsmith75/DSCN0507.jpg
alvinsmith75
05-31-2009, 05:21 PM
Ran this morning with a x437/3. It was far too windy to give a fair comparison but I can say this. On GPS it ran 42.1 and I ran for 8 minutes and still had battery to burn. Even when it is calm the boat wobbles side to side in long straights. How should I adjust my rudder and turn fin to help?
Thanks,
Alvin
detox
05-31-2009, 06:08 PM
First I would lower the strut to 1 1/8" - 1 3/16". Then turnfin should be angled UPWARD slightly against setup board edge (hull resting on sponsons and bottom of strut). Can you turn your lipos cross ways? This will move COG more forward. I like the Grimracer L40 x 57/3 prop best, but it is a little tricky to sharpen and balance. While sharpening prop I wear a cheap pair of strong reading glasses ($5.00 @ Walmart) to help see LOTS better. You should see 49mph with the above setup and boat will also be a little more stable. IMO air dam is not needed at these speeds.
alvinsmith75
06-02-2009, 05:56 PM
Thanks,
Alvin
Forgot to mention that the hottest thing after that long run with that prop was the motor at a mere 121degrees.
Brushless55
06-02-2009, 06:22 PM
8 min, thats a good run..
How many Mah did you put back after that run with the X437/3 ?
alvinsmith75
06-02-2009, 06:30 PM
I don't know because I put the batteries on a storage charge on mu Duo2. They did show 15.2 volts each when I first put them on.
alvinsmith75
06-13-2009, 09:07 PM
Ran again today. I lowered the turn fin a hair and the boat handled much better. I also tried an octura x642 prop. This prop was my favorite as far as handling. It cornered great and ran 46.5mph. I am seing a re-occuring problem. When I use these larger props the boat will shut down after about 3 minutes. Let it sit then it works again. Is this a protective shut down on the stock ESC? Has anyone else had this problem? Basically it seems as if I run a prop that runs the boat over 45mph this happens. If I use a prop that runs the boat under 45mph it works fine.
line6
06-13-2009, 09:15 PM
My friend just did this with his UL last time out. we think that it is a thermal overload protection he pinched a water line and had no cooling at all. by the time we got it back in the motor was 150. but i cant recall the SC temp i don't think it was super hot but the do cool down faster than a motor.
alvinsmith75
06-13-2009, 09:24 PM
Sorry I left out important info.
Esc temp 114
Capacitor temp 110
Is it possible I have to much capacitor capacity.(Does that even make sense?)
http://i378.photobucket.com/albums/oo229/alvinsmith75/Rebuilt20UL1203.jpg
line6
06-13-2009, 09:33 PM
Maybe you are hitting The LVC
detox
06-13-2009, 09:43 PM
Check your 4mm esc/motor connectors. Those cheap Aquacraft connectors will heat up and become unsoldered which will cause the symptoms you are experiencing. I replaced those cheap connectors with Castle's beefier 5.5mm connectors.
line6
06-13-2009, 09:59 PM
Good point detox. i replaced mine with the OSE 5.5 also just to be safe
alvinsmith75
06-13-2009, 10:40 PM
Definately not LVC. I will install 6.5mm connectors next(cause that's what I have). Or just solder the wires direct. Probably will go with the direct solder method. No need for connectors if i'm gonna keep this motor and ESC for a while. Can anyone think of a reason I should't do this?
Alvin
alvinsmith75
06-14-2009, 06:25 PM
Detox yo are the man. I don't care what anyone else says about you. JJ I sliced the heat shrink on on one of the connectors and when I pulled the shrink, guess what? The connector came off. I just finished soldering the wires directly together. I will go out in a few with the x642 and try it again.
Thanks,
Alvin
:beerchug:
detox
06-14-2009, 07:28 PM
That just comes from experience...and board member LUCKYDUCK. There are LOTS OF OTHERS who have WAY more experience than I have. TEST TEST TEST
alvinsmith75
06-14-2009, 08:18 PM
Finally!!!! Something that makes sense. Same setup as a bove mentioned. Same water conditions. The only difference was soldering the esc wires directly to the motor:rockon2: Boat ran excellet and faster, 47.6mph. I ran for a whole 6min and 20 sec. then came in(not on LVC). The hottest thing was the motor and that was only 142 Degrees, esc 124 deg. I just put the lipo's on charge and they were at 14.9volts. Will try the y537/3 again next.
Thanks Detox,
Alvin
This should be obvious, but hasn't been mentioned. IMO, you need to move either the inlet or the outlet on your motor jacket as water will take the path of least resistance. On yours, once water fills the jacket, it will flow from one hole to the other(which are too close), you really should move your inlet or outlet to the other side of the jacket.
Capt. Crash
06-15-2009, 11:00 AM
The stock UL-1 water jacket was set up this way and it made no since to me either. Plus the inlet/outlet are on the side, not on top. However....I've left mine alone because I've got NO overheating problems and it don't leak! If it works...don't mess with it! :tape:
