View Full Version : Feigao 12xl
Mel279
04-27-2009, 11:49 AM
Can feigao 12xl handle 8s lipo?:help:
Flying Scotsman
04-27-2009, 03:27 PM
No, the Feiago big boy yes..just
http://www.offshoreelectrics.com/proddetail.php?prod=fei-580-L
Douggie
RMZDADDY
04-27-2009, 05:04 PM
I ran a 12xl on 8S in my Mean machine last season for sport. This was using a 1.22:1 geared tranny, Hacker master navy 77 and an M440 prop.
Seemed to work okay for me.
This year it will be going direct drive, I'll prop down a little and let you all know how it goes:thumbup1:
Mel279
04-27-2009, 05:56 PM
I also use the feigao 12xl with 6s lipo on my mean machine, it goes in mid 40's mph. What is the top speed of your MM?Let me know if u have try using 8s lipo and don't forget to take video also :thumbup1:
Flying Scotsman
04-27-2009, 06:02 PM
Read Jay Turner's...Fluid.. suggestions on a recent issue of a now defunct magazine.
Douggie
Mel279
04-27-2009, 06:07 PM
Douggie
where can I get it?
RMZDADDY
04-27-2009, 06:13 PM
I did run the MM on 8S with the transmission as I stated, best speed with an M440 was 57.2mph. This year it will be running direct drive. I will post a video when I test it.
Here is the video from last year. (1st run on 8s)
http://s284.photobucket.com/albums/ll8/rmzdaddy/?action=view¤t=MM8s.flv
Flying Scotsman
04-27-2009, 06:16 PM
I think that Jay will chime in, as all his hobby FE life, he wants to help and support the hobby, but he is getting older like me and we see some silly questions..yours warrants an answer from Jay.:bowdown::bowdown:
Douggie
RMZDADDY
04-27-2009, 06:22 PM
My setup from last year has at least 20 runs on it (probably more), temps on the motor never got hotter than 135 degrees, same with the batteries. The Hacker 77 never got over 120. For sport, it works. I've done it.
It was Fluid who originally coached me on dialing in my cat when it was running on 24 nimh, same setup.
Mel279
04-27-2009, 06:26 PM
Great video !!!:thumbup:...What esc do u use?got any heat issue?
Flying Scotsman
04-27-2009, 06:31 PM
With a transmission it goes out the window as far as many specifications.
Douggie
RMZDADDY
04-27-2009, 06:37 PM
1.22:1 is not steep gearing, propping down some will more than compensate for changing to 1:1. I'm assuming you've tried this and it failed?
Flying Scotsman
04-27-2009, 06:40 PM
Lads, last message does not delude newbies with a path to glory....Motors, Drivetrain and Batteries are very important in what you want to achieve.
Douggie the Ugly
RMZDADDY
04-27-2009, 06:48 PM
I tried to answer a question from a member based on my first hand experience, I mean it runs good, cool and reliable, and it's all kinds of fun.
I'll make sure to post my results after converting to direct drive, so I don't "delude" anyone further. Good night!
Flying Scotsman
04-27-2009, 06:57 PM
Delusion is only in the mind and it was not a shot at you, it was the original question annd my answer is still NO.
Douggie
10gauge
04-27-2009, 07:30 PM
Mel279, I agree with Douggie. Running 8S on a 12XL will not yield predicable success over the longterm. I don't know what your aiming for, but that's more of a SAW set up, and would not recommend using a Feigao above 35,000rpm continuously for sport oval racing. A Feigao 12XL will run predictably well with 6S @ 30,850rpm.
RMZDADDY, great run! You were smart in propping down to m440 and using a gear tranny for 8S. But, I would question running 41,100rpm continuously on a Feigao XL motor for sport ovals. It doesn't leave much room for prop changes.
ReddyWatts
04-27-2009, 07:53 PM
I agree with RMZDaddy and he has all the data to prove that a 12XL will work on 8s using a trans in a cat.
I have run a 10XL on 6s with a trans and it worked great. FE did not have the larger economy motors at the time, so I was trying to get better performance out of a 540 motor.
IMO, a 12XL setup will work for fun in the right hydro hull on 8s with direct drive, but the prop rpm and weight would be the determining factors.
Mel279
04-27-2009, 11:21 PM
I was thinking that if Im using 12xl with 8s lipo, and x430.5 prop...would that be ok?its a direct drive...
ReddyWatts
04-27-2009, 11:26 PM
Which hull and length?
Mel279
04-27-2009, 11:37 PM
Its for my Mean Machine 29", and I'll be using hydra 240 LV with lots of added caps..ehe
ReddyWatts
04-27-2009, 11:57 PM
That prop will not be large enough for the MM hull. I would not use anything smaller than an x437. The x437 on this setup in a cat hull with direct drive would use over 2000 watts, which is too much for a 540XL motor.
It would need a trans.
Flying Scotsman
04-28-2009, 01:08 PM
My point on this discussion was that 8S on the motor series described is a no no, as most FE boaters now run directly from the motor to the prop. It was a cautionary note as I perceived rightly or wrongly that many new FE boaters would perceive this as a go ahead to put more voltage to their motors than they were designed for and run them for 2 minutes or more :flashfire:
As, I stated a transmission changes the values.
I really think we need a sticky for new FE boaters does and donts, especially for RTR boats and large hulls
Douggie
RMZDADDY
04-28-2009, 03:05 PM
Douggie
Understood, my apologies Douggie. Sorry if I offended:o
DISAR
04-28-2009, 03:06 PM
If your MM is set up nicely and light maybe it can do it with a 438-440 max. You can try it and tell us the results.
However,
a) the voltage is high (ESC damage potential)
b) If your MM is not set up correctly and running heavy amps draw will be high (over 100), hence motor burn hence ESC burn?
What everyone here tries to tell you is that there is a high risk of damaging motor-esc and who knows what else-flex?
It is a rare setup and "pulled" to max.You have only one positive feedback from RMZDADDY who did it but with trans.
The risk is yours, it is not something that is "impossible".
Flying Scotsman
04-28-2009, 03:11 PM
No apologies needed, as I respected your point of view, and it was very valid
Douggie
RMZDADDY
04-28-2009, 05:09 PM
Right now with the trans, I'm getting 33724 no load rpm at the prop (after the 1.22:1 reduction).
If I were to switch to a 14xl direct, that would yield 35253 no load at the prop. Does this sound more reasonable?
Sorry Mel for hijacking your thread!
Oh, and thanks Douggie.
ReddyWatts
04-28-2009, 05:27 PM
Yes, the 14XL will work on 8s.
Mel279
04-28-2009, 06:04 PM
Hey RMZDADDY
Thats ok, I needed to know as much info and opinion from all u guys here, regarding the 12xl, 8s setup, so maybe I'll be thinking also getting one 14xl, or maybe should I go for KB45 12L(1400kv) or KB45 8xl(1600kv), for 6s. Thanks to u RMZDADDY also for sharing your experience regarding your MM setup and also the video. Thanks alot for all of you guys here helping me out regarding the 12xl, 8s setup, if I go to other forums beside here and RRR, it would takes days or week to get reply, but here was pretty fast, as fast as FE boat can go..LOL :thumbup:
RMZDADDY
04-28-2009, 06:16 PM
Glad I could be of some help, best of luck to you:thumbup1:
Mel279
04-28-2009, 08:43 PM
What flex cable size do u use on your MM?Im using .150 flex
RMZDADDY
04-28-2009, 08:55 PM
I've been using .150 as well. No problems at all. Haven't twisted one yet!
Mel279
10-30-2009, 07:49 PM
hi guys
Im having a bit of problem with my 12xl motor, it seem to stuttering and gets hot, I try to remove the rotor and check the winding, but all seem to be ok. Does anyone know what happen?:help:
