View Full Version : Home made balsa catamaran
OldMann
04-26-2009, 02:51 AM
In the following I want to meet a catamaran made of balsa with hardware home made
OldMann
04-26-2009, 02:52 AM
next
OldMann
04-26-2009, 02:56 AM
From the back I balsa reinforced with ABS, there will be port propeller mounted tubes
OldMann
04-26-2009, 02:57 AM
foto
OldMann
04-26-2009, 03:00 AM
to increase the resistance we put on a whole surface of the reinforcement fiber glass
OldMann
04-26-2009, 03:05 AM
port propeller tubes
OldMann
04-26-2009, 03:06 AM
next
OldMann
04-26-2009, 03:31 AM
assembled and ready for painting
OldMann
04-26-2009, 03:41 AM
final
http://www.dailymotion.com/video/x8sy4s_lipo-2xroxxy365604_tech
Length= 1000mm
Width= 320mm
height= 120mm
engines = 2 x Roxxy 3656/04 , 20V, 60Amp
batteries = 2 x 5 cell Li-Po 2200mA, 33C.
ESC = 2 x HiModel Navy Fly-70-Opto, Cooling water
Propellers = 2x 42mm pitch 46 , 2 blade carbon
lomdel
04-26-2009, 06:55 AM
It turned out great Oldmann! Must have been a lot of work...
eboat
04-26-2009, 08:36 AM
You have to be very happy with the way it turned out
Looks and works great
OldMann
04-26-2009, 09:07 AM
Thanks for the feedback, really was a lot of work. But the satisfaction is great when you see that everything goes as you want.
Meanwhile I redid the painting catamaran and I made new couplings and tube port propeller. They will be mounted on the new catamaran that is working. Il catamaran built after the plans received from "lomdel. I will try to increase the size slightly.
lomdel
04-26-2009, 03:39 PM
Are you still waiting for the plans, or have I sent them to you already? My mind is letting me down lately, sooo much going on here... I built mine recently and needed to adjust a few parts here and there, nothing major though...
OldMann
04-27-2009, 12:05 AM
I have already submitted plans, only now have time to start building.
OldMann
06-21-2009, 02:22 AM
I started construction on another catamaran.
I finished the propulsion and rudder.
lomdel
06-21-2009, 10:01 AM
Are you going to run the twin drives on the tunnel floor as in the pics or are you going to install them in the sponsons? I'll be watching this build...:popcorn2:
rawsonreyes
06-26-2009, 09:50 PM
hi oldman, what type of drives are those and where did you get them. the cat looks great post some pics.rawsonreyes
OldMann
06-28-2009, 01:07 AM
elastic coupling and engine cooling ... made... home made
OldMann
06-28-2009, 01:17 AM
transmission totally
ace028
06-28-2009, 12:44 PM
Awesome work man, I can't wait to see more pics and vids.
OldMann
09-03-2009, 05:22 AM
I reinforced fiberglass hull, I sanded it and we prepared it for painting. Some samples with rudder and engine-shaft coupling port propeller
OldMann
09-10-2009, 12:18 AM
crabstick
09-10-2009, 02:01 AM
the angle from the shaft to the motor looks a little extreme and could be robbing you of a little power via the drag its probably creating, but man nice cat!
OldMann
09-11-2009, 04:22 AM
Coupling between the engine and port-propeller axis is made flexible shaft spins in a teflon sheath. Sheath is in the brass pipe is shown in the picture, that you can lead to error. Guarantee that is how can the system functional.
Eodman
09-11-2009, 09:47 AM
Two questions - and no I'm not being a smart a** !
1.) Why did you round the rear corners of the cat as you did! This is the second cat that I have seen like this. Is there a performance advantage? The first one was a manufactured hull.
2.) Why mount the outdrives so far inboard towards the tunnel --- if you centered them would there be angle on the motor?
OldMann
09-12-2009, 01:03 AM
I did not understand the second question. Rounding corners has nothing to do with performance, maybe the design.
OldMann
09-12-2009, 02:33 AM
If you have a hull made of the factory after all standards can go down the assembly in May in the middle boat in the water, so in my case when it made... home made,
not get what you get factory, trying to mount the axles as close to the inner walls of the second crest to raise it up more water. The idea is to slip on a surface as small.
Hi OldMann!
Could you tell me what current flow through one motor in your setup?
I building cat and planing to use double drive Octura X442, so looking suitable motors. I think yours motors like feigao 540L. Are they too hot?
Thank you!
Serge
G Doggett
09-12-2009, 05:17 AM
Eodman - I think what OldMann is saying is the drives should be as close to the inner edges of the sponsons as possible. Thats what I was told when setting up my twin cat.
Serge - My twin Jolly uses X442 ( r/h and l/h) props and I use 2 Ammo 2300 motors which draw about 50 -60 amps each on 4S lipos. Top speed is 90 kph. Hope this helps you.
Graham.:rockon2:
OldMann
09-12-2009, 08:16 AM
Hi OldMann!
Thank you!
Serge
I using two engines Roxxy 3656. These engines were 2550 kV, the power supply to 20V and consumes 70A, perhaps more.
carbon propeller diameter is 42 and step 56.
OldMann
09-12-2009, 08:18 AM
Graham.:rockon2:
Right. In this case the boat will glide on the water surface. Drag is very small.
OldMann , Graham Thanks!
What is your opinion - will be able 10 wind 540L motor turm x442 in this cat?
or in other words do the AMMO and Roxxy motors have realy power advantages to little bit bigger feigao motor?
OldMann
09-12-2009, 11:34 AM
wen choose the engine choose the controler... drives and they have to withstand the engine speed.
I think feigao 10 wind motor 540L Turm x442 is a good choice.
CornelP
09-12-2009, 11:42 AM
I agree, my 30" screams on a 540 10XL with 6S, wiredrive with a 45mm carbon prop. I will upgrade at some point to metal prop...
Thanks All for advice!
ESC no problem because i can make them.
OldMann one more question
Please explane why "drives should be as close to the inner edges of the sponsons as possible. "
I understand why they should be as lower as possible, but cant find difference in horizontal plane.
roadrunner
11-25-2009, 09:22 AM
Hi Oldmann
I'll start sooner the same catamaran. The size will be nearly 80 cm. I have several choice with brushed motors. At this moment I wont use brushless.
1) 2 motors (Trinity 16x3 turn car motor) geared 2:1 single propeller
2) 2 motors (Trinity 16x3 turn car motor) 2 propellers
3) 700 size neodyme single propeller (not sure)
4) Robbe Pro Navy 20 (like plettenberg) single shaft
Especially I'm interessted in two motors but I can decide between geared or not. what is your opinion?
thanks
OldMann
11-27-2009, 12:54 AM
I know nothing about these engines. But if you want to build a twin-engine CATT, recommend no gearbox, and propeller speed to cross the 25,000 rpm.
NativePaul
11-27-2009, 03:32 AM
Oldman, if you are running 4s I think a x442 will be too big, I ran a 10L in a 26" lifting scale type hydro with a M442 for a while but I changed to a tonguecut X637 to try and get more run time and it picked up a lot of speed as well as going longer, the pitch of the props is similar but you could hear it unloading revving out a lot higher with the X637.
If you go over a wave with a twin and one sponson comes out of the water (lets say the left for arguments sake) that left side loses all trust from its prop that is no longer in contact with the water, but the right sponson that missed the wave is still in the water providing thrust, with trust coming only from the right hand side the boat slews to the left, and the weight shift towards the right from the left turn slows the left sponson coming back down and exacerbates the problem, the further towards the centre the drives are the less force there is trying to turn the boat left. Ideal from a handling view point is both props next to each other in the middle like you would with outboards but to do as such with motors in the sponsons requires quite hefty S bends in the flex shafts, disallows wire drives, has more aero drag from the angled stuffing tubes and struts in the tunnel instead of hidden in a low pressure area behind the sponsons and doesn't look scale, I've seen it done successfully to make wider oval style cats twins, but folk with long narrow current scale offshore type cats tend to just mount drives on the inside of the sponsons.
Roadrunner, back in the '90s I used to favour 16tripple motors on my geared 2:1 on 7x 1700 nicads and an X642 in my 18" cats for a 4 minute run time in the high 20s, if I was using them again I would still gear them 2:1 but try 3s lipo and X637s or probably a X645 if geared together, I know back then twin geared 540s had the legs on 700s but had trouble getting the runtime so were mainly used for records days but I think that was before 700 neyodyms too, never used one of those or the Robbe motor so cant comment about them.
roadrunner
01-08-2010, 05:07 PM
Hi NativePaul,
I know it's a late reply :( I had the laser cut parts of the catamaran. I start to build. I'll use a powerfull single motor. Not dure but 6S or 4S lipo I'll use, time to go to lipo ;)
NativePaul
01-08-2010, 10:14 PM
Cool, 1 big motor will be faster for the same cost or cheaper for the same speed.
Simon.O.
01-10-2010, 03:10 AM
Hi Oldmann
thanks
I'll jump in here as I have travelled this road well.
Once you are building a boat this size you will need a lot of power to make it run well.
I stuck with brushed for a long time and even used gear drives too. Today with the low price of BL systems there is no need to go through all that pain.
I used brushed and Ni cells well after I was told to go BL and Lipo. I learnt and now can offer the advice.
If you want to then I'll not stop you, but I will strongly advise against it.
Go with BL and go with a single if coins are few.
Twins are fine, not faster but very cool looking and sounding.....I will do one soon.
roadrunner
02-05-2010, 05:15 PM
Hey Simon,
Thanks for your advices. Actually I'm building and I'm sheeting the boat. Sure that it will powered by a single burshed (a powerful motor) and depending the boat and my contstruction, it's possible that I change it with a brushless.
To go with lipo, good idea but I have to change all my charging setup, new batteries, new chargers, I wii decide what to do.
OldMann
05-28-2010, 11:58 AM
I finished my new catamaran
OldMann
07-27-2010, 01:25 PM
TotalPackage
01-23-2011, 09:16 AM
can i get plans for this hull
OldMann
01-24-2011, 10:40 AM
plan pdf format.
Jesse J
01-26-2011, 09:58 AM
beware of this PDF - My blocker found it had a trojan.
Oldman, your computer might be infected...
