View Full Version : 49.9mph Using M440 Octura
detox
04-25-2009, 10:02 PM
Today using Grimracer L40 x 57 my UL-1 went 48.9 mph and boat handled perfect with no chine walk and no cavitation that I noticed.
Grimracer L38 x 55 was about the same speed as L40 x 57 and boat handled verywell.
Grimracer L38 x 63 too much chine walk
Octura 2140/3 too much stern bouncing, chine walk, and slower
Octura V940/3 too much stern bouncing, chine walk, and slower
Octura m440 went 49.9 mph and boat handled verygood (my favorite prop so far... motor temp 119, esc 93, batteries 115)
Al testing was done with strut set 1 1/8" below hull and turn fin was angled upwards slightly according to setup board. My new G3 Hyperion 2s 25c 5000mah packs were faster than my older Flightpower 2s 25c 4900mah packs (new packs are allways faster). Jeff Wohlt .078" wire drive and custom .078" OSE Octura collet worked perfectly. I will try to get video soon.
God I love the UL-1! Turn fin area has no cracks either. Throttle was held wide open in turns!
EPower
04-26-2009, 12:38 AM
Al testing was done with strut set 1 1/8" below hull and turn fin was angled upwards slightly according to setup board. My new Hyperion 2s 25c 5000mah packs were faster than my older Flightpower 2s 25c 4900mah packs. Jeff Wohlt .078" wire drive and custom .078" OSE Octura collet worked perfectly. I will try to get video soon.
How do you like your new batteries are they up to your expectations
detox
04-26-2009, 01:02 AM
So far so good...I ran them all the way down to the Low Voltage Cutoff. Boat never slowed down before hitting LVC, but stuttered then died very quickly on pond. The Flightpower batteries did slow down more noticably before hitting LVC.
LuckyDuc
04-26-2009, 09:24 AM
Nice write up on the props. I may order a M440 to test with for a heat prop. I wonder how much the results would differ between the stock flex cable and the wire drive setup you tested with?
detox
04-26-2009, 09:43 AM
The UL-1 Motor loves to spin high so I am sure the .078" wire helps free up some RPM's. I may test stock cable vs. piano wire next.
jingalls007
04-26-2009, 05:29 PM
thanks again for sharing this info. I put a .150 hughey flex in mine with an Octura Collet, bad idea, collet didn't grab flex shaft and boat didn't move. Put back stock shaft and collet, no problems. I will order my M440 this week.
04-26-2009, 06:04 PM
Why was that a "bad idea"? The Octura flexhexes work great, apparently there is something wrong with your parts. Are you certain the cable is 0.150"? Is the flexhex for 0.187" cable? Did you put anti-seize on the collet threads and cone? :confused:
jingalls007
04-26-2009, 07:50 PM
Flex hex for 5mm to .150, same as flex shaft at .150. I may have had the flex hex to fat down on the drive shaft of the motor so the flex shaft may have not been inserted far enough in the hex flex to really hold it tight.?
detox
04-26-2009, 08:55 PM
Collet needs to be TIGHT, but not overly tight. Tighten until you poot. If you crap you went too far.
detox
04-26-2009, 09:16 PM
I puchased a pair of $5.00 extra strong +3.00 reading glasses from Walmart to help see LOTS better while sharpening all my props.
Here's some good sharpening instructions:
http://www.aquacraftmodels.com/accessories/prop-tuning.html
detox
04-28-2009, 02:02 PM
Today my UL-1 went 50.2mph using the Grimracer L40 x 57/3 prop. Water conditions were smooth as glass with a very slight wind chop here and there. This Grimracer prop is now my favorite because it handles ruff water better than two blade prop. Mike knew what he was doing when he designed this prop for the stock UL-1.
More attention to detail during sharpening should make prop faster. Any ideas?
Capt. Crash
04-28-2009, 02:09 PM
I got 50.0mph out of my old dull 40X57/3 this weekend too. :thumbup1:
detox
04-29-2009, 03:45 PM
I converted my UL-1 batteries over to Castle's 6.5 bullet connectors. I am using 7/16"OD x 5/16"ID clear Vinyl tubing as an insulator (purchased at Homedepot). I also replaced just the factory male motor connectors using Castle's 4mm male bullets.
LuckyDuc
04-29-2009, 04:02 PM
Did you notice that your connectors were building heat?
jingalls007
04-29-2009, 04:06 PM
Good idea!! I've noticed my deans getting a little warm as well.
detox
04-29-2009, 04:10 PM
Yes...Plus my Brushless Traxxas Emaxx uses the 6.5 bullets also.
detox
04-29-2009, 04:13 PM
Bullets are more troublsome to handle, but well worth it sometimes.
jingalls007
04-30-2009, 03:24 PM
soo, which is your favorite prop now? Is it the 40x57 or the M440?
detox
04-30-2009, 04:40 PM
I like the L40 x 57 because I think it handles slightly better crossing wakes, but both are fast.
Capt. Crash
05-01-2009, 08:04 AM
Anyone detounged the 40X57 and try getting on plane yet?
detox
05-05-2009, 04:00 PM
Thanks to Alvinsmith75 recent post http://forums.offshoreelectrics.com/showthread.php?t=7630 I repaired my old damaged esc by soldering on a new capacitor (original capacitor failed). I remove the old capacitor then coated end of ESC using liquid electrical tape. Then I soldered on new capacitor to battery leads (yes there is a positive and negative side to a capacitor). I got the new capacitor from work so I am not sure if they make this version anymore (2000uf 25v).
I think these will work also
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMsCnlYck6hSqD5NQpID FweZkqUyH0XnouY%3d
detox
05-05-2009, 04:23 PM
BTW...before a run be sure to tape down the Nose Canopy also. My Nose Piece flew off after hitting some rough chop. Nose piece floated as designed then I retrieved it.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVXR3&P=Z
alvinsmith75
05-05-2009, 05:34 PM
Awesome! Glad it worked for you.
Caps were .90cents each. Sure beats buying a new ESC. Thanks Brian B.
Brushless55
05-06-2009, 12:12 AM
What does the cap do? and do we need a special kind of cap?
longballlumber
05-06-2009, 09:21 AM
Below is the cap that I added to my speed control. The cap helps smooth out voltage spikes the controller can see at times. I woulds say YES to you second question. I doesn't need to be "special" but it does need to be speced out correctly... Again, I have been using the below cap with out any problems.
http://www.newark.com/rubycon/25zlh1500m12-5x20/aluminum-electrolytic-capacitor/dp/38M3253?_requestid=246709
detox
05-06-2009, 11:59 AM
Some say the Rubycon capacitors are the best. Longballlumbers choice (Rubycon 1500uf 25v) is a verygood one.
Brushless55
05-06-2009, 12:18 PM
Thanks, does this go in between the battery and esc?
detox
05-06-2009, 12:28 PM
Yes...Solder negetive side of capacitor/capacitors to negetive battery wire and positive side of capacitor to positive battery wire. You can coat exposed wire using liquid electrical coating. This .56 cent cap fix beats spending another $90.00 for new UL-1 esc.
longballlumber
05-06-2009, 01:16 PM
Adding a cap to any controller is a small price to pay...
Brushless55
05-06-2009, 02:05 PM
Awesome!
It this what usualy goes on the esc? or causes it to fail?
and can you add extra on a good working esc?
detox
05-06-2009, 02:26 PM
Awesome!
Yes, Yes, and Yes
Brushless55
05-06-2009, 08:00 PM
Awesome! Great! Thank you!
detox
05-14-2009, 12:31 PM
Today I tried my Hyperion G3 35c 4s 3300mah (4s2p) in my UL-1. The added weight and more forward arrangement of these batteries made the boat more stable crossing wakes. Speeds also appeared faster (no room for my GPS). Motor/ESC temps were about the same as before, but the new batteries were slightly cooler in upper 90's. I checked the temperature of my newly replaced Rubycon 1500uf Capacitor and it was 195 degrees... WOW capacitors can get really hot. I can see why the stock UL-1's smaller 680uf capacitor goes bad so easily. Adding one more should make them run a little cooler.
Ten Rubycon capacitors in picture were $12.71 shipped to my door. Thanks Longballlumber!
Brushless55
05-14-2009, 12:43 PM
Thanks for the update detox.. let us know your speed when you get your gps back in that boat..
detox
05-14-2009, 01:30 PM
me no fit gps
Capt. Crash
05-14-2009, 01:31 PM
If you think about it get some temps on deans connectors too. I'm only running 2s 5250 30c and mine were @150 degrees.
Crash
You can put the GPS aft.
Brushless55
05-14-2009, 01:32 PM
me no fit gps
can you put it in the back of the boat?
Capt. Crash
05-14-2009, 01:41 PM
Like this!
detox
05-14-2009, 02:07 PM
I guess I could mount GPS at rear, me forget.
Running 4s 2p 6600mah seems easier on the Dean's connectors than running 4s1p 5000mah.
longballlumber
05-14-2009, 02:16 PM
No Problem, it's a small price to pay for a little extra protection with very little risk invlolved.
Mike
Detox, Whats your run time on 4s2p???
detox
05-14-2009, 02:32 PM
I try not to run them down to LVC because boat will stutter bump then suddenly stall on water. Then I will have to wade for it. But 6600mah should run longer than 5000mah...plenty long enough for me.
Grimracer
05-14-2009, 02:57 PM
The UL-1 Speedo has a SB (Stutter Bump) system as well as a LVC (Low Voltage Cutoff).. The UL-1 SB comes in at 12V and the LVC at 11.6. Just so you know we did not pick those numbers out of a hat.. We have tons of data regarding lipo discharge and also qualified our finding with some of the fastest FE RC boaters in the world.. True!
From our testing we have found about 15 to 25 second from SB to LVC.. more then enough time to get the boat back to shore.
Haivng said that there is certanly NOTHING wrong with only using part of the MAH the batts provide..
Hope this helps
Grim
detox
05-14-2009, 03:09 PM
Cool Info...I will test the Stutter Bump and LVC again this evening.
Capt. Crash
05-14-2009, 04:18 PM
I've hit the speed bump a couple times and was able to get her to shore before she cut out.
I'm still curious about those dean temps. :popcorn2:
detox
05-14-2009, 04:21 PM
I will check the Deans temps this evening also.
detox
05-14-2009, 06:49 PM
OK I am back from the pond. It was 5:00PM when I ran UL-1 so the winds were still blowing and water had more chop than I like for speed runs. Second run lake was more calm than first run.
First Run Using the HEAVIER 4s2p 6600 mah combo. The heavier weight help UL -1 handled a little better
49.1mph max speed
Close to 5 minute runtime
Dean's temps 159-161 degrees
Battery temps 131 degrees
motor 119 degrees
esc 121 degrees
Second Run Using the LIGHTER 4s1p 5000mah combo. The lighter weight caused propeller to jump in and out of water causing wide voltage spikes. Thus popping a another cap. Or maybe cap was still too hot from the first run building even more heat then popping the brown capacitor fluid inside hull.
49.6mph max speed
3 minutes (popped a cap?)
Bullets...did not record temp
Stutter and LVC test: Again the boat stuttered then died very quickly so I had to wade to retrieve it. Second run I popped another cap so boat just died on water, but would rearm to bring back to shore. I will try two caps next time...Two caps should run cooler.
Here are pictures...I will try to get video one day
Capt. Crash
05-14-2009, 06:56 PM
Some of those temps are pushing it....bad on battery! Good info..thanks! :thumbup1:
Were you using the M440?
detox
05-14-2009, 07:40 PM
No...I was using the Grimracer L40 x 57/3
In this UL-1 I have seen battery temps reach 170 using new Flightpower batteries. These G3 batteries run cooler.
detox
05-14-2009, 08:16 PM
EDIT: Next I will try to get the most out of the UL-1 by using different prop angles, prop depths, and props. Lead ballast also.
Brushless55
05-14-2009, 08:18 PM
Hope this helps
Grim
Today my SB came in and 3 seconds later it stopped, but was very close to shore
I love this boat!
05-14-2009, 08:20 PM
Not really, good cells can handle 140F+ without damage - the internal resistance is lower at high temps. Over 160F is where good cells can start to go bad, although I prefer not to exceed 140F-145F personally. Heating the cells before running - or running them at an ambient of ~100F - is easier on the cells.
detox
05-14-2009, 09:04 PM
I love this boat!
My LVC came on MUCH SOONER than 15 - 25 seconds...more like 3 seconds after Stutter Bump. But I still love the UL-1
alvinsmith75
05-14-2009, 09:31 PM
I ran mine today and @ 2min 53 sec with y537/3 boat stopped and then started back up. The hottest thing was the motor at about 125 degrees. What could this be?
here is vid
http://www.youtube.com/watch?v=4Xnqdq8NkyM
It looks like I stopped but it just so happened to be coming towards me when it happened.
jingalls007
05-14-2009, 09:38 PM
you might be over propped. Next run change it up with a new prop, see if you get the same results.
alvinsmith75
05-14-2009, 09:53 PM
I'll go with the y437/3 thanks.
detox
05-14-2009, 10:13 PM
Could have been the Studder Bump Grim was talking about or...
Today after running my boat I noticed 4mm banana plugs (female esc side) started to become unsoldered. If these wires seperate boat will briefly stop then restart. I will soon switch to beefier Castle 5.5 bullets. These beefier versions will not get as hot as the CHEAP factory versions .
I think maybe the heavier weight and longer runtime using 4s2p caused this
alvinsmith75
05-14-2009, 10:22 PM
Oh yeah I forgot to mention that when I put my batteries on the charger they were at 15.6 volts. I will try new connectors and 437/3 prop.
jingalls007
05-14-2009, 11:05 PM
Jay Turner runs 5.5 bullets on his UL-1, he said you might see a speed increase as well when switching to the larger bullet connectors.
Brushless55
05-15-2009, 01:05 AM
More speed with bigger connectors, cool!
Are you serious..:confused2:
Maybe take more heat from 4s2p setup..but no faster..:tongue_smilie:
jcald2000
05-15-2009, 06:29 AM
Lower resistance from bigger plugs, equals less heat AND higher voltage to the motor.
Capt. Crash
05-15-2009, 08:12 AM
As quoted by Jason @ MaxAmps:
"120 amps is hot but with in 10 degrees of the max that a Li-Po should ever get which is 130 degrees. Chances are the issue of the pack puffing is due to the fact that your running it at or close to it's max rating for the whole run."
http://www.rcgroups.com/forums/showthread.php?t=1046645
After the smoke cleared in that thread, I'm not so sure about his knowledge on the subject nor do I think he makes a very good representative for MaxAmps. All I was trying to get was the minimum recommended temp to run my lipos at and was wondering if I puffed one due to running it too cold.
This is from the MaxAmps lipo care page:
"Lipo Battery Warming Devices/”Bumping” Lipo Packs:
Do not, under any circumstances, attempt to “heat up” your batteries or increase the voltage of a pack above 4.2V per cell using these devices or techniques. Some insidious lithium polymer retailers/distributors have suggested using these devices and techniques to increase the performance of your lithium polymer packs. THIS IS NOT SAFE AND IS LITERALLY PLAYING WITH FIRE!
Devices on the market that heat up lithium polymer batteries can increase the risk of a fire. Lithium polymer cell manufacturers suggest that exceeding 140 degrees is NOT a safe temperature for a lithium polymer cell. At 140 degrees, the pack can become unstable and very dangerous. The small increase in performance is not worth the risk of a fire. PLEASE STAY SMART AND SAFE BY NOT USING THESE PRODUCTS!
Some retailers/distributors of other brands of lithium polymer batteries have suggested that their customers and racers “bump” the voltage of their packs using settings other than the lithium polymer setting on their charger. The manufacturers of lithium polymer cells suggest a voltage range of 3V-4.2V. Increasing voltage above 4.2V per cell is not safe. You should never attempt to charge your packs beyond the voltage set for lithium polymer packs on your lithium polymer charger. Using other battery settings to “bump” the voltage beyond 4.2V per cell can cause fire and injury. The small increase in performance is not worth the risk of fire. PLEASE DO NOT USE THESE METHODS!"
http://www.maxamps.com/lipo-care.php
So as per usual there is a whole mess of opinions and conflicting information out here on the subject and this lipo newbie is trying to sort it all out!
:doh:
Grimracer
05-15-2009, 09:22 AM
Please consider
If you are running high load props (like the 40X57/3-or other) you are taking the ESC to its limits.. This load will reduce the time you have to between SB and LVC..
Having said this it will be my pleasure to look into the shorter times between SB and LVC you are seeing.
Grim
05-15-2009, 03:44 PM
I prefer to listen to the ThunderPower and FlightPower techs, and to read their instruction sheets. Both have told me that 140F is okay. Both have told me that heating the packs can be a good thing. The fastest R/C boater in the world told me not to exceed 160F. Max who? :olleyes:
If higher temperatures scare you, then by all means run at 120F or less. It ruins all the fun if you are always worried about damaging your packs. :smile:
Brushless55
05-16-2009, 12:42 AM
Please consider
Grim
I run a S220 and my esc temp is only in the upper 90s, and I only have about 3seconds after the SB kicks in..
Also the LVC kicks in to low.. Last time I ran my UL-1 I had 7.1v in one pack and 7.2v in the other.
detox
05-19-2009, 11:28 PM
I've installed the 5mm bullet connectors on the motor/esc wires. I also installed two capacitors on the esc's pos/neg wires. I will also try adding lead to sponsons to make UL-1 more stable in rough water conditions.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK204&P=7
detox
05-19-2009, 11:34 PM
Double post
