View Full Version : 78.671 mph p-mono
mike martin
04-24-2009, 10:19 PM
well thought I would post some pics of my p-mono set the new p-mono record at saws last week this boat is amazingly sturdy at 78 mph its a 25.5 delta force with a new 1512 and castle creations hydra 240 this boat also holds the n-2 record at 68 mph.
I can't wait to run it in Q:o
Mel279
04-24-2009, 10:28 PM
Got any video of it?
line6
04-24-2009, 10:32 PM
Great job mike. Wish i made it up there for it. Anyone got any video of it. I seen it set the n-2 rec. in sept. and it was screaming i cant imagine another 10mph out off it. Very impressive :tiphat:
properchopper
04-24-2009, 11:06 PM
Way to go, Bro ! :rockon2:
Bill-SOCAL
04-24-2009, 11:12 PM
Now put a 1521 in it and let's see how it can really go!!!!!!! It must have looked awesome, a boat that small, going that fast. Must have been something to see.
04-24-2009, 11:54 PM
Mike you must have worked some magic to keep it on the water at that speed. Great job!!
ozzie-crawl
04-25-2009, 12:24 AM
thats 10mph faster than i can legaly do on the motor way with my car:w00t:
i have a df25 copy but when steve gets some more in i will buy a real df 26 hull
Raydee
04-25-2009, 08:41 AM
I am amazed that you can keep a 25" boat on the water at those speeds, good Job!
Meniscus
04-25-2009, 09:12 AM
Congratulations, that's amazing speed! Plus the fact you pulled it off without mishap! I'm sure that many of us would be happy with 2/3 that speed LOL.
I have a question that may seem silly, but I'm not a mono guy. How come these DF hulls are capable of more speed than, let's say for instance a H&M No Step 2?
Is there a difference in hull design that I'm missing? Angles? Balance?
Thanks
As a final thought, I can't see the prop you're using with your setup ;) :laugh:
:sarcasm1:
mike martin
04-25-2009, 11:37 AM
I think ken got some video I,ll have to see if he will post it
mike martin
04-25-2009, 11:46 AM
Balance Balance Balance and some good luck:thumbup1:
go up a prop and add some weight?
mike martin
04-25-2009, 12:05 PM
Thanks
:sarcasm1:
there were plenty of mishaps please don,t think it was a easy task just look at the hatch it had some overnight fiberglass repair but persistence payed off in the end
the df hulls have nice aero dynamics but so do alot of outher boats I don,t know if it couldn,t be done with with a H&M no step 2 with the right setup and balance
prop I think was a ABC 1818 I'll have to check my notes
Flying Scotsman
04-25-2009, 01:23 PM
That is an amazing speed for that hull. The water must have been like glass. Congratulations
Douggie
That is great speed Mike, you're definately a pro. Congrats on your record.
DISAR
04-25-2009, 05:35 PM
This speed with a mono hull of that size is not easy to achieve. Very nice!
Doug Smock
04-25-2009, 06:43 PM
:blah::blah::tt2:
Congratulations again Mike, you earned it.:thumbup1:
I'm trying to figure out if I want to take it back myself, or let Casey do it............Hmmmmm
See ya at the races my brother!!!!:buttrock:
Doug :tiphat:
bustitup
08-29-2009, 03:04 PM
any pictures of the inside?
properchopper
08-29-2009, 08:09 PM
Thanks for reminding me; I have to bring my DF 33 P-Boat to the D 19 SAWS tomorrow; not to try to get close to those speeds; they like me to use the boat to chase the ducks away from the lights :doh:
mike martin
08-29-2009, 10:10 PM
sorry no time to get it done right know get with me after the nats . its nothing special thow
bustitup
08-29-2009, 11:27 PM
no prob..I just wantd to see where the fron of your motor was in front of the transom.....i'm bullding a 25" copt right now...i set mine at about 5"....I think cog is about 8"
blakybob
08-30-2009, 12:51 AM
I think that's the same boat you ran in Valdosta isn't it? That thing was rock solid every run. We were all absolutely amazed how well it was balanced. Nery nice work and congratulations!!!
Blake
mike martin
08-30-2009, 10:25 PM
that should be good I think mine is 4 1/2" but i had to add a little weight to the front
mike martin
08-30-2009, 10:30 PM
Blake
yea Blake this is an old thred they bumped up
I hear maybe May for the next saws I think with some new cells I can get her over 80mph
blakybob
08-31-2009, 11:14 PM
Looking forward to next time. Hopefully third year's the charm for me. See you there!!!
Blake
ps. sorry for the typo...Very nice work....
mickvk
09-01-2009, 01:51 PM
First, congrats Mike.
I'm trying to understand this section of the NAMBA rule book.
P ... Power Limits: 10.1 to 15 Volts nominal, any chemistry.
Maximum of 2 packs in parallel. Maximum capacity of 10,000
mAh
Does that mean P class competitors typically run two 7.4V 5000MAH packs in series? Thanks. -Mick
Doug Smock
09-01-2009, 05:32 PM
You could two 2s 10,000ma packs in series, or two 4s 5000ma packs in parallel.
Hope that helps.
Doug
mike martin
09-01-2009, 09:44 PM
Hope that helps.
Doug
what Doug said
in NAMBA you have a 10'000 ma max
IMPBA has no ma rule
