View Full Version : My Eagle Tree data with m445
LuckyDuc
04-16-2009, 08:27 PM
I did a run this evening with my new prop and consistantly ran between 46 - 51mph each lap in race setup.
My motor leads and batt/esc connectors are still getting too hot for my liking.
Here's the eagle tree chart with amps and gps speed... also the Eagle Tree statistics snap shot showing Peak Amps, Peak watts, mAhs used, low voltage, etc.
Temp A is the motor temp and Temp B is the motor bullet connector temp.
My wife took some video... I'll try to post it later.
Brushless55
04-16-2009, 08:37 PM
1911 watts!
LuckyDuc
04-16-2009, 09:09 PM
Surprisingly enough the stock setup and stock prop is only 26 watts less.
Here is a chart and Stat print out for the "All Stock" setup.
LuckyDuc
04-16-2009, 11:09 PM
Here's the video from today's run.
http://www.youtube.com/watch?v=wvRokCeJ8f8
teach
04-17-2009, 12:06 AM
Great video. Even better commentary! My boys get just as excited.
LuckyDuc
04-17-2009, 12:24 AM
The kids really get a kick out of it... they get super excited.
longballlumber
04-17-2009, 08:33 AM
That was a great vid!!!! the Kids were cracking me up...
Personally I don't have any kids, but the first time I ran my boats with my dog around he immediatly jumped in and tried swimming after the boats. That's the last time I took him wiht me....
Boat looks great. I hope to have mine out there on sunday.
Capt. Crash
04-17-2009, 09:17 AM
Cool vid...I'm thinking that was a really long run. Seemed like around 2 miles to me. Have ya tried a 1 mile run?
LuckyDuc
04-17-2009, 11:34 AM
I'm sure that the temps would be better with normal race distance.
Now I just need to build some buoys and setup a race course. I'm still trying to decide what to use for buoys.
detox
04-17-2009, 12:19 PM
This is really good info. Sounds like we need to upgrade to bullet connectors.
BTW...what are the battery specs?
LuckyDuc
04-17-2009, 12:37 PM
Yep. I have some 5.5mm bullet connectors on order.
The batteries are 2 x 4s 2250mAh packs in parallel. They are rated at 20C cont discharge. I'm using these because they are the packs I use in my 70mm EDF jets.
LuckyDuc
04-17-2009, 01:22 PM
FYI... I re-posted the Data Chart as the original wasn't enlarging correctly. Now you should be able to see the detailed amps and speed.
detox
04-17-2009, 01:27 PM
I wonder if using 35c Lipos would make the UL1 faster?
Check out these new Hyperion batteries:
http://www.allerc.com/product_info.php?cPath=3_4_93&products_id=4553
http://www.allerc.com/index.php?cPath=3_4_93&osCsid=ac8be4cc5340bb67da59039b52a09db8
Brushless55
04-17-2009, 02:35 PM
Wow! 147amps cont.
That should do something! :thumbup:
LuckyDuc
04-17-2009, 08:41 PM
Here is the last chart I'm doing with the m445 before switching to a Grim L40x57 for testing. Hit 52mph in the straights.
Check out Temp B. That is the ESC's Deans Connector!:eek:
detox
04-17-2009, 09:02 PM
Be carefull...my detunged x645 killed my ESC.
LuckyDuc
04-17-2009, 09:13 PM
If it cooks the ESC then others will know not to try it :w00t:
I've been looking at a Hydra 120 anyway:cool:
Capt. Crash
04-18-2009, 07:46 AM
52mph...congrats....that is way cool! What was your prop setting? :rockon2:
LuckyDuc
04-18-2009, 09:49 AM
The strut is at 1" and the prop is angled down at 2 degrees. Batteries are all the way forward.
Brushless55
04-18-2009, 10:53 AM
Ok, I think I know what the 1" at the strut means, but what or how do you get the 2* prop angle? :help:
detox
04-18-2009, 02:25 PM
Lowering the strut will usaully put the needed angle on the strut. Using a setup board you should see light under the front edge of strut. 030" clearance will work. Some have used more in the UL1 with good results . You just have to test
Brushless55
04-18-2009, 02:29 PM
Does lowering the strut loosen the boat up?
LuckyDuc
04-18-2009, 08:45 PM
Lowering the strut helps stabilize the boat by lowering the nose of the boat. If it is running too wet then raise it a tad.
Brushless55
04-20-2009, 06:53 PM
Does your cool Eagle show RPM ? :buttrock:
LuckyDuc
04-20-2009, 08:00 PM
It can, but I don't have that sensor. I have the two temp sensors and the GPS expander.
I could give you a chart with voltage and you could estimate RPM using math.
Motor KV (2030) x voltage = RPMs
Brushless55
04-20-2009, 08:16 PM
But under a load would be different...
LuckyDuc
04-20-2009, 08:24 PM
It wouldn't be as far off as you think because voltage drops as well when load is applied.
detox
04-20-2009, 10:13 PM
I hope your newly sharpened L40 X 57 prop goes faster. Please post Eagle Tree numbers and speed afterwards.
Brushless55
04-21-2009, 12:21 AM
Yes voltage does drop under load, but you cannot just multiply volts (4s) times kv to get your top rpm under a load...
I have a 60 size Cap 232 with a 500kv motor.. On 6s it will spin well over 11k free, but with a 16x8 prop my rpm is around 8k..
So by your math I'm only at 16v but in reality my batteries only drop about 1.5v.. :biggrin:
LuckyDuc
04-21-2009, 09:50 AM
Will do. The weather has been cruddy for the last couple of days.
LuckyDuc
04-21-2009, 09:57 AM
Here is a graph I made of the stock setup/prop when I had the Brushless RPM sensor hooked up. I've since removed it from the boat because it was eating up RAM on the logger, and I didn't feel that the data was as relevant as the other sensor data.
Brushless55
04-21-2009, 11:03 AM
Very cool LuckyDuc..
that's just the iinfo I was wondering about! :rockon2:
LuckyDuc
04-21-2009, 01:42 PM
Anyone have some suggestions on other props to test in this size range?
I don't want to goto a 6 series type prop after reading about over amp issues with the ESC.
I was considering a Prather S220 next after testing the Grim L40x57x3.
jingalls007
04-21-2009, 02:12 PM
Detox likes the Grim L38X55, he also suggested the L38X63.
bigpapa
04-21-2009, 02:49 PM
still has the stock motor ?????????
LuckyDuc
04-21-2009, 02:58 PM
Yep. The only changes I made are the prop and strut depth/angle.
jingalls007,
Do you race with the guys from Longmont and Greeley? I just moved to WI from Denver. I used to run my Shockwave 36 in Longmont at the county building lake.
jingalls007
04-21-2009, 04:08 PM
WHAT?? No, I have only run my gassers at a Lake just off I-70 and Colorado Blvd. near Commerce City. I run my FE's at Wash Park since I live so close. It takes me 3 minutes to get to Wash Park, it's awesome. Do you have those dudes contact info, would be nice to run my FE's with some other dudes this summer here. thanks man,
Jarrett
LuckyDuc
04-21-2009, 04:49 PM
PM'd you.
Brushless55
04-21-2009, 05:48 PM
jingalls007,
I'm only 10 min from that place, have yet to run there..
detox
04-22-2009, 09:36 PM
Here's three of my Grimracer props. Two props on right have been hardened. I will do a comparison soon.
From left to right L40 X 57, L38 X 55, L38 X 63
LuckyDuc
04-22-2009, 10:22 PM
Nice looking props. What do you charge? ;)
Brushless55
04-23-2009, 01:19 AM
Awesome, we want to know how they compare. let us know.. :thumbup:
LuckyDuc
04-23-2009, 12:01 PM
I posted my initial eagle tree data on the grimracer L40x57 here (http://forums.offshoreelectrics.com/showthread.php?t=7486)
jingalls007
04-24-2009, 03:13 PM
did you get a chance to run the 38x63?
tharmer
04-26-2009, 12:50 PM
How do you harden a prop?
-t
detox
04-26-2009, 02:32 PM
-t
A really sharp prop is thin and easy to bend along the sharp edges so I heat treat. I bake my props at 600 degrees for 2 hours then let them cool slowly over night.
Originally Posted by raptor347
I've done it a couple ways.
#1. If you really want them HARD: Anneal them at 1225F for an hour and quench in water. Do all you prop work: sharpen, balance, thin, cup etc. Then 600F for 2 hours and turn off the kiln and just leave them to cool overnight. This yields very hard props, but you can no longer work them at all.
#2. Just do the 600F step after yo work the prop. Still very hard, but you canbend them a little if you really need to.
LuckyDuc
04-26-2009, 07:28 PM
I took a break from balancing and sharpening my next test prop, a Grimracer L42x66, and decided to run my M445 again.
Apparently my driveline has loosened up a bit and is now broke in. I hit 55mph and it is pulling a lot less amps than prior testing. Data below.
detox
04-26-2009, 10:35 PM
dayuuuum that is fast. I will have to try my m445 tomorrow.
detox
04-26-2009, 10:42 PM
Looser/faster water conditions will help pull less amps and make boat faster also.
