View Full Version : SV motor and esc
saleens7
06-22-2007, 01:36 PM
they came today (thanks tom)!!!
cant wait to get the supervee setup...my only question....when i plug in a 6 cell batt, the motor (????) beeps.....and theres no throttle response....does the esc need to be programmed? if so, is there a manual for it?
Darin Jordan
06-22-2007, 02:07 PM
You have to arm the ESC EVERY TIME you plug in the batts...
1) Turn on your transmitter.
2) Plug in the Batts.
3) When it "beeps", pull full throttle on your TX.
4) When it "beeps", release the throttle.
You should now be armed and ready to go...
saleens7
06-22-2007, 02:53 PM
i tried that...it only works when the throttle is reversed (so when i push out the trigger, it goes) and it only shakes (i think people cal it cogging) and has quick bursts of throttle...
Darin Jordan
06-22-2007, 03:11 PM
Sounds like your TX needs to have the "Servo Reversing" set to the opposite of whatever it is now for the throttle...
Not sure about the cogging part, but I'm going to assume for now that has something to do with the reverse settings on the TX... Ususally they are a % of the Forward settings, etc...
saleens7
06-22-2007, 03:21 PM
got it to work...im only testing it on 6 cells...
Rex R
06-22-2007, 06:25 PM
btw, don't hold full throttle when you plug-in the batts...unless you want to enable the 'brake' function :)
saleens7
06-22-2007, 06:32 PM
....turns out proboat radios dont need to be reversed, but you need to set the throttle trim all the way clockwise or the motor will already go when you plug in the bats....yeah, i noticed the motor brakes now....but since i have the setting right, next time i plug in the batts the motor wont take off on me
Mich. Maniac
06-24-2007, 09:53 PM
Just a quick question about motor, I have this xtra 9L feigao, would that work for the sv?
saleens7
06-24-2007, 10:00 PM
unless you run a very small prop (youll be getting very close to 40,000rpms) it wont....at those rpms, an L size motor will have barely any tourque to it...
Mich. Maniac
06-24-2007, 10:03 PM
So what application would you use an L motor. why would steve even bother?
Rex R
06-24-2007, 10:10 PM
6-8 cells with limited space, I gather that the L series(same overal size as a 600) works nicely for an 8cell boat.
saleens7
06-24-2007, 10:19 PM
something that ive been wondering for a while, is the supervee motor an S size motor? because when i compare it to my quantam (exact same dimensions as feigaoXL) there is alteast a 20-25mm difference in can length....i know it has a low KV level, but im surprised an S motor can push the supervee that fast and have the tourque to spin a 40mm 3 blade prop...
Mich. Maniac
06-24-2007, 10:38 PM
well maybe ill try it and only run a 2cell lipo. I cant seem to sell it so what the heck.
Rex R
06-25-2007, 02:21 AM
you're overlooking one distinct difference between a feigao and the sv motor(henchforth svm) a feigao is a 2 pole while the svm has 6 poles, that gives the svm the torque to twist a whole lot more prop! well the svm is running on twice the voltage too...
hammertime
06-25-2007, 01:50 PM
the 9l motor is a good motor for low cell count and a light boat
saleens7
06-26-2007, 04:27 PM
since the stringers where the motor mounted were lose, i epoxied them up....i might be getting the motor mount soon as well....once i finish up the SW36, ill just need to buy a difference receiver, 5mm to .150 coupler, and some batts and this boat will be good to go...what speeds should i expect from 14 IB3600's?
