View Full Version : Dead charger
Diegoboy
06-21-2007, 09:24 PM
I was charging my ep4200's (2x 6-cells) at 5 amps. first one completed. Started the second one, walked away for a few minutes, (okay an hour) when I got back the charger was dead. The AC input is 120VAC the output of the transformer is under 2VAC. The problem is the transformer. the thing is only about a month old, but I did mod it a bit. What to do?
It's a Vision Peak Ultra (http://www.dynamiterc.com/Products/Default.aspx?ProdID=DYN4053).
Diegoboy
06-21-2007, 09:28 PM
Mods are...
Cut the AC input, Installed sockets in order to remove the cord when not in use.
Installed one of these...
http://www.singatron.com/gif/SS-7B-VDER-4.0.jpg
dirtysouth31
06-21-2007, 09:29 PM
stop the presses!!!!!!!he was charging his batteries people..charger wasnt used to having a battery connected to it.lol...anyways it has a warranty so i hope you saved the box and receipt..call me and ill let you borrow a charger or charge them for ya..
Diegoboy
06-21-2007, 09:33 PM
It's just a BAD day for me.
Couldn't run the Bud, because work sent me out till after sunset.
Lipo discharged beyond min voltage, now it's trash.
Now my charger is dead.
http://www.addemoticons.com/emoticon/animated/AddEmoticons04268.gif
Diegoboy
06-21-2007, 09:35 PM
Box, No.
Receipt, I think so.
Do you think they'll honor the warranty after the modding I did to it? You've seen it Dirty, What do you think?
dirtysouth31
well i got my flex shaft and rod so i can fix the rudder,so ill be ready...dont cry over broken chargers:cool:
dirtysouth31
06-21-2007, 09:36 PM
well i still have my box so you do have a box
part time
06-21-2007, 09:42 PM
Box, No.
Do you think they'll honor the warranty after the modding I did to it? You've seen it Dirty, What do you think? no, did u try using the dc side?
Diegoboy
06-21-2007, 09:47 PM
No, I'll go try that right now...
Mich. Maniac
06-21-2007, 09:51 PM
Did you check the water, choke it? LOL!
Piranha2
sounds like some of the secondary winding insulation has been compromised.....(shorting) this can be caused and relieved by temperature....the primary and secondary are wound together, tranformation takes place when the magnetic field induces flux on the ferrite core...........ah, forget it...you need a new one!:confused:
Diegoboy
Wow. It works on DC input.
Odd
Piranha2
06-21-2007, 09:54 PM
not the transformer, the regulator works on DC.
saleens7
cool..it works...sorry bout those lipos....the sad face thing keeps cracking me up...
Diegoboy
06-21-2007, 09:58 PM
Ya. I liked that one better than this...
http://www.addemoticons.com/emoticon/animated/AddEmoticons04219.gif
I'm not quite to this point yet
Piranha2
06-21-2007, 10:00 PM
transformer theory is easy...the input / output are a direct relation to number of winds, IE: 4 input winds to 3 output winds equals a 4 to 3 step-down and vice versa for a step-up.
part time
06-21-2007, 10:02 PM
thats good to here. if u dont have a power supply i saw some cheap ones that i could track down for u.
Diegoboy
Piranha2,
You sound very knowledgeable in things transformer. Can I send it to you for repair?
http://www.addemoticons.com/emoticon/animated/AddEmoticons04217.gif
LOL
Diegoboy
06-21-2007, 10:03 PM
...seriously, can I?
LOL
Piranha2
06-21-2007, 10:05 PM
Transformers are AC (not DC). It needs to be AC to create the EMF-electro-magnetic-force (or field). Then they rectify the AC into a DC voltage (this is where your DC input goes to) and then they regulate it.
Piranha2
06-21-2007, 10:07 PM
Just please be careful around the capacitors (look like cans) because they pack a good punch even after your charger has been off for awhile.
saleens7
06-21-2007, 10:10 PM
my head is starting to hurt after reading your posts piranha2...:confused:
Piranha2
06-21-2007, 10:19 PM
yeah, so is mine:confused: ......I deal with this all day, every day.......except its usually an acoustic-optical-modulator:cool:
Piranha2
06-21-2007, 10:22 PM
I almost forgot.....Diego, send it back because usually the OEM of the transformer will reimburse the seller of the charger.
Diegoboy
06-21-2007, 10:23 PM
Back to the MFG or LHS?
Piranha2
06-21-2007, 10:28 PM
try LHS first see what they say then the MFG.......it's worth the effort......I've gotten alot of help just by asking.
Diegoboy
06-21-2007, 10:33 PM
I'll be bringing it back to the LHS tomorrow.
Thanks guys!
http://www.addemoticons.com/emoticon/animated/AddEmoticons0423.gif
Jeepers
06-24-2007, 12:16 AM
A WHAT? what does that do?
Piranha2
06-24-2007, 07:40 PM
Jeepers, it will allow a certain wavelength of light pass thru when modulated by a specific radio frequency. In other words, it's a part of a laser.
saleens7
06-24-2007, 07:42 PM
...ahh my heads hurting again...
Jeepers
06-25-2007, 01:32 AM
oh ok that makes more sense! at first I thought it was something "Marvin the Martian" would use to blow up the earth! :D
