rc123
04-13-2009, 05:13 PM
Hi,
I'm quite a beginer in FE and I've bought this Hydro Marine Spider (near to 27' long) already build
It came with a cheaper motor a KD 10L and I decided that the hull deserves more and I've put in a plett HP220/30 A3 in it and a Hi model 200Amps esc.
Link for the motor is here
http://www.plettenberg-motoren.com/UK/Motoren/Brushless/220_30/motor.htm
I will be running it on lipo 4s or max 5s -5000mah 30/50c
Now I don't know what prop to use.
Tried it with a x642 and it went quite well before the flex cable blew away ..
Still on the Octura prop chart I saw that I should try bigger ones but the reco was more for nitro and not FE.
I've already bought a 1742/3 and one 1745/3 will this two fit or should I look for more?
