View Full Version : What to do? moded apche 24
SweetZ28
04-11-2009, 10:11 AM
Well here she is ...Flex cable routed through stock rudder that's fixed in place and then added a pro boat turn rudder put a extra section of plastic behind the back of the hull wall to make the rear stronger... One thing now i am wondering if i should cut off the fin as show in the photo?...Or will this fin make it more stable in the turns?
Jesse J
04-11-2009, 10:23 AM
how does it run? it is probably how ever you like it to look. what do you want it to do? what speeds are you after?
SweetZ28
04-11-2009, 12:47 PM
Did not try it yet...I am probably going to put a brushless system in her and a motor of 3,500 or like 4,100 KV and probably a 40mm CF prop and run on 6 cell packs....Don't know how fast it will go and what motor will be better for this boat.
It looks great though now with the rudder on!
THANKS
brad65
04-11-2009, 05:07 PM
I'd stay with 2500-3000kv motor with 3s motor mine rips! What size flex shaft?
SweetZ28
04-11-2009, 05:47 PM
The KV will be for only 2s so that's why i need more... the write up is here with what i used read through the posts.
http://forums.offshoreelectrics.com/showthread.php?t=1667
04-12-2009, 07:14 AM
I would also run it first, before cutting anything off so you have an idea on how it performs.
SweetZ28
04-12-2009, 09:52 AM
Yea that's what I am going to do....:bounce: I will probably run it and say wonder what it will do if i cut the fin off then i will cut it off and next time i will try it and go MAN I SHOULD HAVE LEFT IT ON!!:laugh:
brad65
05-03-2009, 11:04 AM
SweetZ28, ya ever run her yet with the new setup?
SweetZ28
10-03-2009, 10:53 PM
yes it works ok but with the 3300KV motor it's a dog the rpm of the motor i was using the traxxas titan 12 is 26000 RPM my 3300KV is only 22000 RPM so it like a slug!
Think i need a 37ooKV to 4000KV maybe?
