View Full Version : Neu 1515/1Y in cat questions
bjornar
04-11-2009, 07:34 AM
Hi, I have 2 Neu 1515 1Y with Hydra 120 and I am planning to build a cat. Is this fine to use in a MHZ Mystic 114 hull, or is it to high kv? I am thinkin to start with this motors and maybe upgrade to 1521 or equal later. I was thinkin to drive with 4 cells, and I hope to do around 60mph. Its ment for oval driving, not saw. Hope to get some feedback :-)
bjornar
04-11-2009, 12:14 PM
Or should I just wait and buy 1521? At least in the beginning I woluld prefer not that high speed, just drive for fun and build a quality electric boat.
Boatman
04-11-2009, 12:29 PM
I dont know what length that hull is but the setup with the 1515 1Y on 4S is a pretty good setup for up to 40" twin since the only readily available props are the 442's.
bjornar
04-11-2009, 03:46 PM
The hull is 114cm (45"). Its almost same size as the HPR 115. Its many setups with 1940 in the HPR, and thats close to the 1515 I think. But the best solution is probably 1521. But since I have 1515 1Y that would be perfect to start with...
DISAR
04-11-2009, 07:10 PM
They might work fine. Start with them and if not happy go to 1521. The 1515/1Y is very popular and what most people use on 4s with 42-45 props.
bjornar
04-12-2009, 05:11 AM
Sounds good. But is hydra 120 enough for this motor? 2500W / 16V = 156A
DISAR
04-12-2009, 02:36 PM
The 2500W is the max. the motor can run, not the actual, it depends on the prop. With a 45mm prop. it should be around 1500W. Also from what I read (not from experience) with twin motors the load is reduced on each motor and can fit bigger props than using one motor.
