View Full Version : new Turnigy 120amp 180 amp esc
bustitup
04-08-2009, 01:31 PM
Anyone seen this or is it just new to me?
https://unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=8921
Flying Scotsman
04-08-2009, 01:56 PM
The Turnigy ESCS are very good value but they are large. I do not water cool the ones I have as their size does not warrant it. I am talking about the HV and high amperage units. They may not fit in small boats and get enough air cooling. Also all of mine needed (3) required a Pistix to function, that may have changed today
Douggie
bustitup
04-08-2009, 02:05 PM
Douggie
What I meant was this looks like a new upgrade of the popular Turnigy 100amp hv
that is so used in FE and it will run on 12s
do you a run fan on yours Douggie?...how big a boat do you run them in
Flying Scotsman
04-08-2009, 02:19 PM
No to the fan. a 32" mono, a 34" cat and a 29" mono and all are HV ESCS
Douggie
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8937&Product_Name=Turnigy_Marine_180A_Brushless_Boat_ES C
6S HYDRO
04-13-2009, 02:26 PM
So douggie, your not cooling them at all. They dont get hot?
Flying Scotsman
04-13-2009, 04:03 PM
Nope, the heat sink is huge. This is for the 100amp HV esc. I can not speak for the new series.
Douggie
Punisher 67
05-31-2009, 04:22 AM
I built a test stand to load test my motors and lipo's with a Seaking 180 , here is some video for what its worth
http://www.youtube.com/watch?v=KmX2NABdHFM
jcald2000
05-31-2009, 07:25 AM
Nice Job as usual!
Camara need to be closer to screen, can't read data headers.
Punisher 67
05-31-2009, 09:48 AM
Sorry about that I will re-do this video but need to buy a smaller prop for load , a 10/6 is to much for this motor and I don't want to smoke another high power high end unit
jcald2000
05-31-2009, 07:38 PM
I run an 8x4 on big motors and 7x3 on 4s motors.
LiPo Power
05-31-2009, 08:37 PM
This ESC looks good to me for the buck.... How would this compare to Castle ESC?
bustitup
05-31-2009, 08:39 PM
I cant get my turnigy 180amp to give me full voltage.....I hope its my fault..hate to think I got a bad one
Punisher 67
05-31-2009, 09:57 PM
Nick Can you post what your setup is and settings on the ESC , I find if I have the 3.4 volt cutoff even fully charged batteries hit the limiter very quickly and will not give full power on the test stand , maybe 30 seconds and thats it , 3.2v is what I set the cutoff at under load
I am sure it can easily hold its own against one , at least you don't void your warranty if you run 6S
bustitup
06-01-2009, 12:23 PM
Peter
Its my mean machine cat
I used the optional programer set at
Forward only
Low start
LVC at 3.2 per cell
Low timing
Flight power 2s 5000mah 25c x2 in series
2200kv castle neu motor
Boat would only go 23mph......soon as I switched out the esc she ran 43mph
Using a m445 prop
bustitup
06-01-2009, 12:27 PM
Peter
Forward only
Low start
LVC at 3.2 per cell
Low timing
Using a m445 prop
Punisher 67
06-02-2009, 02:26 AM
Jeez I don't know Nick I am at a loss . sorry my friend
Jesse J
06-02-2009, 09:35 AM
So, any news Nick? I just got bullets soldered on and would like to test, any tips?
bustitup
06-02-2009, 12:55 PM
Jesse
I havnt had it back out again yet but hope to tonight
I also hope its a programing issue user error
Getting it to recognize full throttle
Hope yours works fine will give me hope
GL bro
Jesse J
06-02-2009, 02:35 PM
how many cells bec does this have? I didn't get a manual with it...
bustitup
06-02-2009, 02:43 PM
I would suggest not using it but thats just me
Constant Current: 180A
Burst Current: 360A
Resistance: .0007ohm
Battery: 2-6S Lipoly
BEC: 5.8v/ 3A
Motor Type: Sensorless Brushless
Size: 72 x 68 x 34mm
Weight: 165g
