View Full Version : Power Suggestions For 29'' Rico Mono
I'm starting to build a 29'' rico mono and need some advise on how to power it. I want to do this one as a budget build, sport setup, decent runtimes, 40-45 mph, 4s lipos. Not sure if a SV or BJ power system would work or an etti with a fiago.
Thanks
Kevin
Doug Smock
03-29-2009, 09:44 PM
40 to45 mph on 4s I would go with the Etti and a Feigao 9XL. X442 to a x445.
The SV power system would work, but IMO you would fall short of your speed goal unless you abuse the equipment.
Good luck, post some pics.
Doug
PS I just built a 31" Rico, you'll like the boat.:thumbup1:
I tried a 9xl in another 29'' mono and had heat problems but that may have just been my setup. Is a 9xl in it a hot setup? If so what would be a bit more conservative? Here are some pics. Already installed carbon fiber and will post more pics when I start to build it.
Doug Smock
03-29-2009, 10:57 PM
You shouldn't have had heat issues unless you were running a large prop, if the boat was heavy, or running wet. Was the motor cooled?
The setup in my Delta Force 29 is an 8xl with the etti 150 on either 4s2p 10,000man with an octura x440 or x442. This setup will yield mid 40's low 50's depending on water conditions. No heat issues at all.
T. Hatch
The motor and esc were cooled and I used a x440 x637 and m445. The boat loved the m445 but smoked the esc. It may have just been something I did, it was when I first got into FE and didn't fully understand how to calculate everything.
Doug Smock
03-29-2009, 11:23 PM
The 9XL, Etti 150 and a x442 should be a bulletproof setup in that hull.
I've run that setup with a Barracuda 80 with no problems.
Good luck with her,
Doug
ED66677
03-30-2009, 02:57 AM
agree with TTH, watercooled 8XL and cheap 120A ESC, 4S and K40/K42 prop works very well, the 9XL should spin an even bigger prop!
check you COG, 20% should help if she doesn't get on plane and "burns power for nothing", I had the same on my 29" DF copy when the COG was around 30%.
Doug Smock
03-30-2009, 07:25 AM
Thanks
Kevin
:tiphat:;)
It seems that an etti 150 and a 8xl or 9xl is the way to go. The question is which one? Whats the advantage or disadvantage to each one.
ED66677
03-30-2009, 02:23 PM
the 9XL will be able to spin a larger prop than the 8XL, not a lot bigger though! IMO just enought to have a better prop efficiency and gain few mph at the end!
Sounds like the 9xl is the way to go. Thanks for the help.
bustitup
03-30-2009, 03:44 PM
edit: sorry I thought I started a new thread but I messed up sorry for the jack
ED66677
03-30-2009, 03:50 PM
does it exist? not sure!
Doug Smock
03-30-2009, 04:36 PM
Good luck with your build !!!
Doug
Flying Scotsman
03-30-2009, 04:42 PM
Good luck with her,
Doug
Agreed, I have a similar system in a DF 29...9XL..X442...2 5000 2S 1P 25C in series, Sentilon 100 HV ESC.
Douggie
focused
03-30-2009, 06:09 PM
Speaking of xl8 and xl9 in this video http://vimeo.com/3912063 (http://vimeo.com/3912063) both on 6s lipo Zippy H 5000mah 45mm K-prop and not even full throttle yet . It was the second testing day so we`ll take it easy but no heat problems so far.
Boat nr 1 is a Hydro-Marine Xray-L wanderer(nemesis) 20xl8 6s lipo Zippy H and ETTI 125A first run 45k Prop , second run 42x55 grimracer.
Boat nr2 is a MHZ Lizard feigao 540xl9 6s lipo H zippy 5000mah ETTI 125A 45k prop.
Michiel.
