MHZ Chaparral FE
  • EPower
    Banned
    • 391
    MHZ Chaparral FE
    Hi There
    All the parts for this build are here now So i'm ready to go
    I had this boat all setup for gas power but after finishing the FE Lizard Xtreme i got hooked all the gas stuff went out the door
    Here are a few pictures and any suggestions will be appreciated
    Adrian
  • z400
    • 1311
    Man i love the look of that hull!
    Cant wait for more pictures Adrian!
    Z
    KBB34" Mono - Fast
    ToySport Triton- Not as fast
    • Red65
      • Feb 2009
      • 19
      Sweet, looking forward to the build..
      • Gerwin Brommer
        • Dec 2008
        • 918
        Nice !!!!
        Which cellconfiguration ? 10S2P I hope ??
        What kind of strutt/drive are you gonna use ?
        • lomdel
          • Nov 2008
          • 708
          Am gonna watch this build with anticipation and great expectations! No pressure...
          • EPower
            Banned
            • 391
            Hi There
            Thanks for all the comments this is my second FE build and yeah !! no pressure this setup is going to be 12S2P i was told this motor could handle 12S so let's see what happens
            like i said this boat was ready to go with go with petrol power all i had to do was the silencer and a few air vents
            Strutt & rudder are speedmaster so i hope i can use the existing harware
            Really all i have to do is mount the motor ESC and batt and i should be ready to go
            any suggestions on what type of thrust bearing setup i should run on this motor?
            Thanks Adrian
            • z400
              • 1311
              Gettin there!!
              Looking great BTW!
              Z
              KBB34" Mono - Fast
              • DISAR
                • Aug 2007
                • 1072
                Nice boat. What is your setup? (motor,esc,batteries,propeller) 12s means that the esc must handle 12s.
                The thrust bearing will be fitted on the motor shaft therefore it depends on the motor shaft diameter. OSE has them for all diameters.
                http://www.rcfastboats.com/
                • DISAR
                  • Aug 2007
                  • 1072
                  Are you going to place the motor aft or forward? I prefer aft, shorter shaft.
                  • Gerwin Brommer
                    • Dec 2008
                    • 918
                    12S2P is excellent !
                    For direct drive, 12S is fine.
                    Did you reinforce the back of the boat ?
                    • Flying Scotsman
                      Fast Electric Adict!
                      • Jun 2007
                      • 5190
                      MHZ are quality hulls and that is a looker. As previously requested by Disar What is your proposed setup? (motor,esc,batteries,propeller and Gerwin Did you reinforce the back of the boat ?
                      Douggie
                      • tth
                        • Apr 2008
                        • 1510
                        First post third pic shows a shultz 40.160 and a rather large plett brushless motor, looks like HP 370BM/50.
                        • Gerwin Brommer
                          • Dec 2008
                          • 918
                          Douggie.
                          Yes sir ! 9mm ply, and covered with epoxy.
                          (I'm talking about my MHZ Cayman now, soon to be replaced by a MHZ Xray :-) )
                          All the holes in the back have ss-tubes in it, to make sure no water will reach the ply.
                          • Flying Scotsman
                            • Jun 2007
                            • 5190
                            Gerwin, I was asking E power the question you raised not what you would do. As I know you know what to do to a transom
                            As an aside note what Gerwin does with the SS tubes.
                            Douggie
                            • EPower
                              Banned
                              • 391
                              Hi Guys the motor is a Plettenberg HP 370BM/50 A1"S" the ESC is a Schulze Fut-40.160 WK 02.09V16 It will handle up to 14S
                              and yes the transom is reinforced with CF
                              i also brought two Hyperion EOS0610I-Net two 12v 18 amp Ac-Dc power supplies and a Kipor Sinemaster 1000 watts generator Inverter to charge my batt at the pond
                              This motor is a monster 12 mm output shaft maybe the German guys might know how to setup a thrust bearing on this setup
                              Gerwin here is a vid of a cayman with the same motor running 32 cells you may have seen it before
                              Cheers Adrian
