Has anyone tried to remove the black anodizing yet? I know there are certian chemicals that will remove it, but it can also pit the aluminum. I might try sand blasting too. Anyone else have better suggestions?
How to remove anodizing from hardware
Tags: None
Longballlumber, here is one of the more recent discussions related to your question:
http://forums.offshoreelectrics.com/...ead.php?t=6440IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
No problem, we all do it! At least I know I do!IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
sand blast it and wet sand what ever you were guna remove the anodizing from. go from 400-600-800-1000-1500-2000 grit and after the 2000 grit use mothers aluminum polish. it should look almost like chrome if not the same, after your done... otherwise, the easy off should work....Last edited by EATMYWAKE; 02-20-2009, 08:32 PM.Comment
Sodium Hydroxide (draino) will work but the water needs to be 160 degrees for best results. Put a table spoon in a shallow non aluminum or glass pan and stir - the parts need to be moved around to keep fresh chemicals in contact with the surface. After a few minutes check the parts - when done they will be a dull grey and ready for polishing.
WARNING!!!: this is harsh stuff and rubber gloves and goggles are required. Also this needs to be done in a well ventilated area as the gas given off is very nasty!IMPBA 20481S D-12Comment
WARNING!!!: this is harsh stuff and rubber gloves and goggles are required. Also this needs to be done in a well ventilated area as the gas given off is very nasty!IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
