Blazer Marine P Sport Hydro build
  • Mark Scott
    • Aug 2016
    • 59
    This is a in development design of a new boat from Blazer Marine. 2 different P Sport Hydros will be offered. Believe there is a Q boat in development also. Not certain if there will be two Q boats.
    P LTD Sport Hydro will be 31". This build is of the 33.5" P Sport Hydro kit. BTW, this is my first spt hydro build, ever. Friends are freaking out as they are wondering why the motor isn't hanging off the back.
    Anyway, early pics of the kit in the build process.
  • meangenesracing
    • Jun 2012
    • 1158
    [ATTACH=CONFIG]176264[/ATTACH]
    [ATTACH=CONFIG]176265[/ATTACH]
    [ATTACH=CONFIG]176266[/ATTACH]
    Wouldn't even worry about motor placement as of yet. Get floatation inside and skins on top first.mount hardware set your batteries of choice and motor inside.dont forget to epoxy piece of aluminum inside right sponson for mounting turn fin bracket to before putting top skins on. Cog on mine is approximately 1 inch behind sponsons
    • Mark Scott
      • Aug 2016
      • 59
      Appreciate the information.
      Disclaimer: I have a direct discussion with Brian on his design. Helps being in the same club. This is the fourth design he came up with. The other three have been trashed. I've been pushing him for over a year to design an electric boat. Believe others have been pushing also. He has a new .45 sport hydro in development too. He has the CG somewhat in the ball park. Believe he used the weight of the Castle Hydra, mounted to the front. Turn fin setup will come from him. Already told him I want a 31", haven't stated need a Q also.
      Boat was designed to use 2 2S packs. Motor choice is between a TP Power 4050 or 4060 in the 2k kv area.
      • longballlumber
        • 3132
        Have fun with it Mark!
        • Mark Scott
          • Aug 2016
          • 59
          20 seconds for two laps and I'll have fun! lol.. Going after your record Mike!
          • Mark Scott
            • Aug 2016
            • 59
            Recent updates on the build.
            • Mark Scott
              • Aug 2016
              • 59
              Continued:
              • longballlumber
                • 3132
                Nice work Mark! I am excited to see you get this going.
                • Mark Scott
                  • Aug 2016
                  • 59
                  Thanks Mike. Should see the pics of Brian's build up. Getting to the point to choose which drive line to use. Flex cable or wire drive.
                  • Mark Scott
                    • Aug 2016
                    • 59
                    First coat of epoxy laid down. Using Total Boat - Total Penetration for initial two coats, then will use two coats of West Systems 205.
                    Total Penetration is thin as water. Another useful item is that while in liquid state, it is water soluble.
                    • Mark Scott
                      • Aug 2016
                      • 59
                      While wet, rub'd in as much as possible. Second coat was 1.5hrs later. Same action, rub'd any access into wood. Hour later, one coat of 205 laid down. The sub hatch bottom was also epoxied during this time.
                      • ray schrauwen
                        • 9471
                        Mark, I'm assuming that you will add 1/8" spruce sticks in the places that they are missing in above pictures?
                        Nortavlag Bulc
                        • Mark Scott
                          • Aug 2016
                          • 59
                          Actually, the spruce sticks won't be added. You will see what is done instead in a few days.
                          • Mark Scott
                            • Aug 2016
                            • 59
                            Here is the floatation for the boat. This is why no spruce added. Debating to fill in the other two front sections. Might add some, will see tomorrow.
                            • RaceMechaniX
                              • Sep 2007
                              • 2821
                              Mark, Pack as much foam and floatation as you can in there. The foam also stiffens these hulls which helps. I know most people don't like 2-part foam, but here is where is shines as it gets in every nook and cranny and strengthens everything. I do this will all my sport hydro and rigger builds. It's also easy to sand down to match the contours.
                              Tyler Garrard
                              NAMBA 639/IMPBA 20525
                              T-Hydro @ 142.94mph former WR
