View Full Version : I have 2 plugs coming off of ESC and running 2 batteries. I want to run 1 6s battery,
3Jjb4Skoot
10-26-2022, 06:04 PM
I have 2 leads coming off of ESC and running 2 batteries. I want to run one 6s battery, is the plug to transfer the power thru the unused plug
called a Bind Plug Loop Connector ?
jkflow
10-26-2022, 06:24 PM
Yes,
very common nowadays on RC cars.
Example:
https://www.horizonhobby.com/product/firma-150a-brushless-smart-esc-3s-6s/SPMXSE1150.html
tbonemcniel
10-31-2022, 08:53 AM
If the two existing plugs are wired in series, which is likely and stock for a Sonicwake, then you need a simple connector that loops back on itself to plug into the unused plug.
If the two existing plugs are wired in parallel, then you don't need to do anything but maybe cap the unused plug for safety purposes.
TRUCKPULL
10-31-2022, 12:27 PM
Pictures please.
Will help a lot, are you asking about the radio plugs on the ESC, or the power plugs?
Larry
3Jjb4Skoot
11-12-2022, 01:45 PM
So must be wired in series, I found a loop plug on the bay and all worked well.176007
