View Full Version : TSP Jolly Cat Assembly
Even though this isent a build in the true sence I figured you guys will enjoy the process. I am on my way back out to the bench for the first time in weeks. It will take me longer to get things organised than to do what I had planned today. I will have some pictures up in a bit. I am regaining some peace of mind. It's allowing me to begin relaxing again.:)
Tunda
06-09-2007, 02:23 PM
I wish i could get me one of those hulls cant wait on the pic........
hkusp45
06-11-2007, 05:42 AM
Post up them PICS!!
We want to see!!
Not much to see yet really. I just got the bullet connectors pulled off the 7xl and started soldering them on the 11xl. I await delivery of the cooling blocks I need to upgrade the cooling system on the esc. I also need to order a 5mm thrust bearing some more shrink ect. Doing that tonight.
hammertime
06-13-2007, 05:41 PM
cant wait to see that beautiful little baby
I am slowly workin my way out to the bench now.....I may even sit down & work tonight....I keep getting some wierd type of post traumatic stress syndrome when I start workin on the boats:( . The last 6 weeks have really screwed me up....:confused:. That being said...I am down...but I am far from out ;)
Diegoboy
06-14-2007, 09:04 AM
I keep putting that white jolly in my cart, then removing it... lol
I want it, but... darn that $500
I would love to buy that White Triton.....With a nice set of the SpeedMaster hardware. But I don't have the cash or the time. Mabe this winter:)
Diegoboy
06-14-2007, 10:39 PM
I mention the white jolly on OSE, and now it's gone. Who snatched it? :confused:
part time
06-14-2007, 10:43 PM
i bought it to run it over with my 1/6 scale truck. i got bored crushing 1/10 cars.
Diegoboy
06-14-2007, 11:14 PM
lol :D
Can I have the pieces when you're done with it? :rolleyes:
06-15-2007, 06:59 AM
A customer that has a yellow Jolly already! I don't think he's been on the board. But I posted some of his video a while back and he has pictures in the ose gallery.
That cat is fast. Guy is in texas I think. He drives it like a dragster...lol. Drops off plane to turn it then guns it down the pond.
Well I made it out to my bench today. I still don't believe it myself. I may not be done yet either. So I took my hex apart and added some proper cooling. With 16 cells and the 11XL I am going to be drwaing some amps. This time I did it right. I removed the aluminum spacers from in between the inboard fets. I took a set of OSE cooling plates, used to capton thermal tape, slid them through opsite sides of the esc and the fit perfect. I put an MHZ water cooling block on the top fets. For the lower fets I removed the spacer, and installed a fan to blow across them and move the heat out of the shrink wrap. The S-BEC is shrink wrapped up in the package also. I now have to go to MHZ and het one of the carbon fiber flush mount 0 drag dual 4mm water intakes. Im going to install in on the verry back of the right sponsen. This way the OSE plates, MHZ block and motor all all independant. In case of a clog I dont blow the whole system. I think I may go back out and install the motor and start on the electrics tonight.
http://i42.photobucket.com/albums/e343/STOAK/DSC00836.jpg
http://i42.photobucket.com/albums/e343/STOAK/DSC00833.jpg
http://i42.photobucket.com/albums/e343/STOAK/DSC00837.jpg
saleens7
06-17-2007, 04:01 PM
looks good....be impossibe to overheat it now...
hammertime
06-17-2007, 05:15 PM
if i buy one of these esc can i send it to you.....
Hammer I really couldent get it back to you in a reasonable time frame. I was suposed to do a couple for someone else and didnt because of my lack of free time. It is quite simple. I would be willing to coatch you through one. :).
Mich. Maniac
06-17-2007, 08:51 PM
So did you get those blocks from me or did you have to buy them. I sent them priority. well my wife did.
Mich. Maniac
06-17-2007, 08:53 PM
So those wont be waterproof either then, is it possible to use like silicone to seal the ends. it would defeat your cooling fan but if you didnt use the fan would that be ok?
I gotem....Thanks a mill. Water proofing these is not really possible unless you have some type of potting epoxy. I have gotten this unit wet 4 times. Dryed it out each time and it's been fine. No worries.
I got the motor in, received paced and esc placment worked out. I'll try and clean up the wiring and get some cooling run tomorrow and tuesday night. MrsSjfe is off for 6 days:D after tuesday night. The equipment will collect dust untill she goes back next week.
part time
06-17-2007, 10:29 PM
So those wont be waterproof either then, is it possible to use like silicone to seal the ends. it would defeat your cooling fan but if you didnt use the fan would that be ok? some silicon has acid in it and it can destroy the etchings on the boards. use conformal coatings or the special epoxy.
I am back to work tonight. I hope to knock the rest of the work out. Maybe even get a test in this weekend.
hammertime
06-26-2007, 03:32 PM
wooooohooooooo
Not much going on with this. The heat has me exhausted & sick @ night. The AC is down in the machine and I was told it's not being replaced any time soon. It was 115 degrees in the cab today...111 yesterday. Lost 6 pounds in 2 days. I have written it up as a saftey issue incase I pass out @ the controls. It's going to be a long summer. This blows:(
Last night I got the esc mounted, servo installed, rudder bracket bolted on and the cooling system finished. Tonight I have to prep the supervee for shipping. If I have time left over I may get her finished for a wednesday test.
Well the pictures show it all. I just have to pick up the right servo horn. Velcro the battery trays and set up the radio. That is an octura v series 3 blade. I may get her in the water Wednesday :D.
http://i42.photobucket.com/albums/e343/STOAK/DSC00846.jpg
yz120
07-02-2007, 11:26 PM
tom, shes awesome looking-when ya gonna give her away(jk):D
Jeepers
07-03-2007, 01:21 AM
Dude I feel for you, I work around a prefab concrete kiln somtimes its around 120 degrees in the building, I go outside to cool off, not much difference since its 100 degrees today. I hate summer so bad I actually look forward to fall and winter.
The jolly looks great! what motor you have in it?
That is an 11XL. It will be running on 20.8 volts.
ReddyWatts
07-03-2007, 12:58 PM
SJFE drink lots of water. The 6 pounds you lost in 2 days is probably from water loss.
yz120
07-03-2007, 06:09 PM
i secound that! i live in the middle of the az. desert(119) today on the way home and run a warehouse with no cooling. it sure sucks:(
Toss in 80 to 90% humidity.....You have to gulp the air...
Mich. Maniac
07-03-2007, 10:14 PM
oh come on just get a little fridge in their with some frosty cold ones and a fat cigar!
yz120
07-03-2007, 10:22 PM
:eek:
i feel for ya man.
STB. 125DEG. WED. & THURS. HERE:eek:
I saw that...Jesus... It has been beautiful here for the last 3 days...But hells comming back soon.
Well here she is. From the time I decided on the hull to completion has been 4 months. I will get it in the water tomorrow. Look for the test thread.
http://i42.photobucket.com/albums/e343/STOAK/DSC00849.jpg
http://i42.photobucket.com/albums/e343/STOAK/DSC00851.jpg
Mich. Maniac
07-20-2007, 07:49 PM
jees, I cant get over the size of drive line. how about stuffing tube, you get that on ose or did it come in the hull?>
It came out of the box like that. All I did was install the electrics. Well worth the money.
Stealth Assassin
07-29-2007, 10:24 AM
It came with a wire drive?:cool:
Yup sure did. .78 wire. It would seem the changed the drive system quite a but. The pictures Steven has listed shows the rudder mounted directly to the hull. Mine was delivered with the stand off. It moved the prop back about 5 inches and out from under the hull. My coupler will be here Monday. I will be testing it directly.
Stealth Assassin
07-29-2007, 10:48 AM
I am really Interested In the outcome of the kb45...
Good luck and don't forget to christen the hull before you pull the trigger!;)
Diegoboy
07-29-2007, 02:55 PM
I'd like to see you install this (http://www.modelrectifier.com/search/product-view.asp?ID=7595) on the Jolly...
:D
Diegoboy
07-29-2007, 03:01 PM
Maybe even two!!
dirtysouth31
07-29-2007, 05:50 PM
i need to put that on my duck
hammertime
07-29-2007, 06:44 PM
the duck rocks.........and that outboard is hilareous.......that would be cool with like a scale build of a runabout
If they werent 810 bucks a piece I would use them on a scale cat.
wickedgmc
07-30-2007, 12:33 AM
SJFE, I like those battery trays you have but cannot locate them anywhere, where did you get yours? When you mounted the KB brushless did you have to drill new holes in the mount or did it just bolt right up?
Steven said 2-4 weeks for more Jollys and it has been 2 weeks so I am now getting very antsy..........
NorthernBoater
07-30-2007, 12:56 AM
They came with my Jolly Cat. Although I did not use them because I wanted to be able to move the batteries more. I instead epoxied balsa wood attach Velcro for batteries.
wickedgmc
07-30-2007, 01:08 AM
cool, someone else I can get info from, I am itching to buy mine just waiting for OSE to get a yellow one with the hardware
