View Full Version : TP-Power TP3640-2600KV-Open-5F Motortiming seaking 180AMP
Mrdennis1979
09-07-2022, 03:43 PM
Hi All!
i have a question, does anybody know what the correct timing setting is for a TP3640-2600KV- with a 5F winding in combination with a Seaking 180amp.
thanx in advance!
best regards
Dennis
EddieM41
09-07-2022, 05:22 PM
good place to start....15 degrees. It should be a "Y" wind.
tbonemcniel
09-08-2022, 08:38 AM
Hi All!
thanx in advance!
best regards
Dennis
What is this 5F winding you speak of? Windings can only be Delta (D) or Wye (Y).
A TP 3640 2600kv is a 3Y winding, which means it will generally prefer higher timing. However, 15* might be too much. I typically set my Y wound motors at around 8* to start, make a run logging temperature and speed, then incrementally increase timing until temperature begins to rise to the point where it's not worth whatever extra mph (if any) it brings. At that point, back off to the previous setting.
Mrdennis1979
09-08-2022, 08:48 AM
Ok thanx! great explanation thanx!
The webshop of tp where i buy it here in europe says that it is a 5F
https://tppower.de/epages/bd5f179c-685e-4a79-bbe0-e825a2cc9e1a.sf/de_DE/?ObjectPath=/Shops/bd5f179c-685e-4a79-bbe0-e825a2cc9e1a/Products/TP3640_2600KVo5f
But i will give it a try with the settings and make some measurements of the temperature
thanx!
koen
09-08-2022, 03:41 PM
TP advice for d and y motors is a 0" timing
Mrdennis1979
09-09-2022, 03:46 AM
Thanx! will try it out!
EddieM41
09-09-2022, 02:23 PM
That may be what they advise...their way of being safe. You might get more run time and cooler temperatures. But to get the most power out of the motor without burning the house down...starting at somewhere between 10 and 15 degrees with a "Y" wind and the correct prop you'll have more fun. Just saying..............
Mrdennis1979
09-09-2022, 04:53 PM
Thanx Ed, will start low, and look at the temps, i'm running dasboata props for my IMPULSE 32 & ZONDA R, the zonda will also get an upgrade 2 TP3650-2350kv
koen
09-10-2022, 04:19 AM
these motors can pull a lot of amps(look at tppower.de you can see full spec of these motors ,max amp 264)if you go for a lower kv you can pull bigger props and stil stay cool and lower amps ,these motors are for saw not for racing
1coopgt
09-10-2022, 04:02 PM
It says 3Y. Think the 5 = 5mm shaft. Scroll down the page a little bit to the specs. First spec is Winds , 3Y
tbonemcniel
09-11-2022, 08:35 PM
What are you talking about? Of my like 15 boats I think it is currently, all but 3 have TP motors in them. They all oval race perfectly.
fweasel
09-11-2022, 09:01 PM
The only thing I agree with in this post if larger props on lower kV. The rest is flat out wrong.
