View Full Version : Motor Coupler issue help
NissanGTR
08-23-2022, 04:48 PM
My Motor Coupler on the Sonicwake touches itself and can't stay tight. Is there a better aftermarket one?
Also is there a better aftermarket flex shaft that will hold the stock prop?
dasboata
08-24-2022, 09:24 AM
more then likely your shaft diameter is worn down from slipping try here in the OSE store !!!
Capt'n Crash
08-24-2022, 12:00 PM
If the end of your shaft is worn down you could also apply a layer of solder to build it back up.
NissanGTR
08-24-2022, 12:11 PM
Got it! Good advice, thanks!
