View Full Version : going brushless!!!
thegreat1
02-08-2009, 06:04 AM
well guys my tax money just came in so i went ahead and ordered a bunch of parts. here goes: fiegao 9l, x-power 100a, blackjack strut/rudder set, ose motor mount, ep 4500 6cell, and an octura m440 prop. how does this sound to you guys? i really don't know what to exspect this is my first build where i didn't just copy someone else's idea and did it on my own. do ya'll think i did good?
thegreat1
02-08-2009, 06:05 AM
oh also what size flax shaft should i use? i have an .098 laying around but it seems small for this power what would be better?
thegreat1
02-09-2009, 05:39 PM
no love?
Jesse J
02-09-2009, 08:40 PM
are you going flex shaft to the stearable outdrive? you might think about 8 cells?
thegreat1
02-10-2009, 02:49 AM
no i am going to be running blackjack hardware.
ApacheDude
02-11-2009, 12:00 AM
The Apache and Blackjack steerable drive assembly is the same if I recall...
The shafts are different as is the prop.
thegreat1
02-11-2009, 05:51 AM
the blackjck nitro uses a seperate strut and rudder.
9895
thegreat1
02-13-2009, 09:39 AM
well the first of my parts came in yesterday. i got the stut and rudder in. i haven't gotten to the strut yet but the rudder is mounted and looks great. here are pics.
http://i445.photobucket.com/albums/qq177/jayreaa1/DSC02343.jpg?t=1234535749
http://i445.photobucket.com/albums/qq177/jayreaa1/DSC02345.jpg?t=1234535857
http://i445.photobucket.com/albums/qq177/jayreaa1/DSC02344.jpg?t=1234535948
jfabcustom
02-16-2009, 01:41 PM
Looks good!
I have a brushless proboat mini-c. Though they are not the same boat, they are similar and share similar characteristics. I designed a simple strut/rudder bracket and scratched it out on my dad's bridgeport mill (What a nice tool to have). I figured this would be an improvement over the stock steerable outdrive and hopefully I'll gain some stability above 20MPH. I want to experiment with some very small turn fins as well, but I'm gunna try it with just the strut/rudder on the first run. I'll send a pic.
jfabcustom
02-16-2009, 02:26 PM
Here are some Pics. The blue anodized hardware is from Mini Cat Racing. The raw aluminum bracket is the piece I milled.
http://i91.photobucket.com/albums/k301/jenai-84/P2160088.jpg
http://i91.photobucket.com/albums/k301/jenai-84/P2160091.jpg
thegreat1
02-20-2009, 11:50 PM
well i got the rest of my parts in on saterday (thanks steven) but i had to get underway*(in the navy) on sunday so i didn't get a chance to put everything in and get to the pond. so when i get back next month i will have a project to build. i also got with my money a fireball motor for my mini-t, a c-4 9200 and mini tazer for my micro rs4, a turnigy 4600 and mamba max 100a esc for my 4wd truggy and some other misc parts to get all of my rc's up and running again. i can't wait to get home. its gonna be like a week of building and playing.
thegreat1
03-17-2009, 01:56 PM
some updates. so i finally got back home on saturday and today got to do some work on the boat. so i destickered it installed the motor and wire drive added to stregth to the transon.
things that still need to be done. install esc and find battery (i seem to have lost a 6 cell pack of mine.) here are some pics
http://s445.photobucket.com/albums/qq177/jayreaa1/th_DSC02668.jpghttp://s445.photobucket.com/albums/qq177/jayreaa1/th_DSC02664.jpg
thegreat1
03-17-2009, 01:58 PM
http://s445.photobucket.com/albums/qq177/jayreaa1/th_DSC02666.jpg
http://s445.photobucket.com/albums/qq177/jayreaa1/th_DSC02667.jpg
FE Wannabe
03-20-2009, 07:10 PM
I am really interested in how well that hardware works for you. I have also converted my Apache to brushless and I am tired of flipping it everytime I run it.
SweetZ28
03-28-2009, 09:33 PM
Hi here's a thread on mine i used these parts with all the stock rear fin and steering unit and it works really good.
I want to put a brushless in mine also....i took it out today for it's first run it's pretty quick in stock form with the flex shaft system installed .....but i was doing some zig zag turns and it flopped right over on it's lid!! Lucky i had a rescue boat and got it back to shore.... seems like it don't handel to well like it flips pretty easy?
FE Wannabe
03-29-2009, 12:19 AM
Yep, that is the issue with the stock outdrive, it wants to hook any time you turn too sharp at speed. The problem only gets worse as you add speed. I am hoping a change in hardware will improve the handling.
SweetZ28
03-29-2009, 10:02 AM
That's interesting... wonder if i shorten the flex cable and make the prop come out the rear of the boat and leave a little space between the stock turn fin rudder if this would make it handel any better when the prop is not going through the turn fin and no longer turning with it?
Just thought of this I could leave the stock set up as is but lock it centered and use a stock super V27 steering rudder set up out the back...what do you think would this be a good alternative?
FE Wannabe
03-29-2009, 11:20 AM
Z28,
I am no expert, but I think you will have a couple of problems with your idea. First, the outdrive is designed to turn the boat with directional thrust. If you fix the prop to no longer turn with the outdrive, I don't think the boat will turn very well. You would need a longer rudder instead.
The other problem I see is that the prop shaft would be coming out of the transom at too much of positive angle, unless you use a strut mounted to the transom to run the propshaft through. I think that is why ProBoat changed their design on the nitro BlackJack 26 to use a separate propshaft and rudder.
FE Wannabe
04-03-2009, 08:38 PM
9895
What size propshaft does the BlackJack nitro SS strut use? 1/8" or 3/16" or something else?
Inquiring minds want to know.........:biggrin:
thegreat1
05-13-2009, 11:24 PM
hey man sorry it has taken me so long to respond. the only time i really get to get on here is underway. so i know that the strut is not 3/16th inch because that is that size prop shart i am using and i had to drill it out.
as far as my progress on the boat goes i have everything installed and ready to run i am just waiting on batteries. i removed all the plastic undreneath the hatch and fiberglassed everything added some floatation in the nose and gotten everything in order. i can't wait to run the thing. i am going to run 2s2p for now and i'll have 3s2p on standby if i want more speed. i love the fact that i now have room for 2 batteries and i would suggest to everyone who has this boat to gut the thing. it lowers the cog so much. i think this boat is going to be really stable now. but i don't know how it ran stock as i never bought the rtr version just the hull and everything else seperate. as soon as i get home on the 6th i will post pics. the paint job on it is gay but i let my wife do it (trying hard to get her into the hobby)well that is all i have got for now i will let you all know when i get to the water.
FE Wannabe
05-14-2009, 08:38 PM
I may end up gutting mine after all, it gives you so much addtional space to work with. Thanks for the info.
Diegoboy
05-14-2009, 08:40 PM
Can you post a pic of the interior after the 'Gutting"?
thegreat1
05-15-2009, 12:05 AM
i won't be able to until after the 6th i am underway until then so i will get back to you on that. but until then watch this bannanna dance. :banana:
thegreat1
05-15-2009, 04:08 AM
hey diego if you look at the thread below this one you can see pics of an apache with the interior cut out "gutted"
Diegoboy
05-15-2009, 09:06 AM
I saw those. I just wanted to see the boat I will be running with soon! :tongue_smilie:
thegreat1
05-15-2009, 09:13 AM
OH! well if this is the only reason you wanted to see it i won't be able to post until um i was mid november. sorry guys. lol j/k give me until the 6th then i will post some.
thegreat1
06-09-2009, 07:48 AM
well diego here you go. OH and i figured since i will probably be a fembot when i get up there i painted the boat accordingly lol.
http://i445.photobucket.com/albums/qq177/jayreaa1/DSC03068.jpg?t=1244547868
http://i445.photobucket.com/albums/qq177/jayreaa1/DSC03066.jpg?t=1244548046
http://i445.photobucket.com/albums/qq177/jayreaa1/DSC03063.jpg?t=1244548093
Diegoboy
06-09-2009, 07:54 AM
Nice! She will surely fit right in. :smile:
Meniscus
06-09-2009, 10:03 AM
Cool! Now all you need is decals. I can't wait to see it on the water, and it shouldn't be too difficult to see that!
I have a few boats that are difficult to see at speed, so your color choice is definitely a plus.
FE Wannabe
06-09-2009, 11:11 AM
Great1,
Do you have any pictures of the transom? I would like to see how the hardware turned out.
Thanks,
Brad
thegreat1
06-09-2009, 12:28 PM
http://i445.photobucket.com/albums/qq177/jayreaa1/DSC03069.jpg?t=1244564879
here ya go man
FE Wannabe
06-09-2009, 01:43 PM
Looks good, can't wait for the handling results. Let us know how it runs!
thegreat1
06-29-2009, 07:01 PM
so i finally got to run the boat last weekend and well i need a bigger pond lol. i also need to do some tuning but don't know really know what needs to be done. when i get on the throttle the boat torque rolls real bab onto the right sponson and also a little to the bow. i moved the batteries back some and it helped a little with nose heaviness but not the roll. i only ran it for a few minutes because i got bored with the small pond. i think i am going to be taking a 2 month hiatis from the hobby until i get to virginia where i can have a good pond to run in.
onionvolcano
07-04-2009, 10:30 AM
try adding turn fins or trim tabs, those will probably solve your problem, and give it a cool look when you pull it out of the water:bounce:
FE Wannabe
07-04-2009, 11:08 AM
Great1,
I think your prop might be too big and that is what is causing the torque roll. I am running an Octura Y534 plastic prop on a Feigao 10L on 3S lipo and it accelerates really well and stays flat to the water. I am going to try a Y535 next so I can try a metal prop.
bluthndr
07-06-2009, 03:41 PM
ya thats the problem because when i ran mine with a x438 it rolled terribly. then i swap it with the y535 and it runs perfect!
koshokid
07-06-2009, 07:05 PM
The x435 seems to work best with my brushless Apache.
thegreat1
07-07-2009, 06:36 PM
i guess i will have to go with a smaller prop. when i first got most of the parts i was going on the idea that what works for the vj should with the apache because it is basically the same hull.. well i guess not.
onionvolcano
07-12-2009, 12:34 PM
hey! I have a few questions, does the feigao motor have bullet connectors already installed onto it, and also what is the shaft size for the apatche?
thegreat1
07-13-2009, 08:10 PM
no the motor didn't have bullets on it from the factory. and as far as the stock shaft i don't know. i bought the bare hull with full intention to go brushless from the begining
onionvolcano
07-31-2009, 04:36 PM
Also does the 100 amp esc have bullet connectors?
