Ryanj
06-10-2022, 03:22 PM
Hi everyone. Some may have seen already or heard. I've been making there mounting adapter plates for the TFL adjustable stinger to be bolted to the Sonicwake 36. The Version 2 had been a hit so i have been working on a V3 now as being a new mount all together. simple and allows the stinger to mate to the hull better and the Plus to work better with the Stock size flex cable. Only cutting required is the stuffing tube on the boat. This tube has to be shorten to allow the new adjustable stinger to move and allow for angle. removing the old strut, measuring 5mm or 1/4in from the transom of the hull and mark the stuffing tube. with a metal saw, pipe cutter cutting the tube at this location. Then removed the tfl mount from the tfl stinger and install new mount to the tfl stinger using the same screws. Mounting the the stinger with the new mount uses the same screws from the old strut on the boat. Straight forward conversion. just like the stinger that RCBB offers. Creating the post to Throw this out there if any interest. This v3 mount im still about 3-4 weeks out. 1st Picture is V2 but gives the ideas. 2nd and 3rd pictures are version 3 in the process. Version 3 Im working with a company to CNC these mount conversions out of aluminum
175168175169175170
175168175169175170
