View Full Version : 1/12 Proboat Miss Elam Hull
ABX131
03-19-2022, 10:28 PM
I just picked up a 1/12 Miss Elam electric hull. It has the factory rudder and shaft support and tube but no shaft or prop or motor. I'm installing a Leopard 3674 2200KV motor and I need to know what size the factory flex shaft is to order a replacement. Also looking for prop suggestions. Any input would be very helpful.
Peter A
03-21-2022, 02:33 PM
Factory shaft is .150. I suggest you find some of the old build threads on this boat. Darin Jordan did a good one. I basically followed that with the one I had years ago. TBH it always ran best with the original 1500kv motor. It has limitations on top speed.
As far as props go, X442.
ABX131
03-21-2022, 10:01 PM
Thank you...What is TBH? I reached out to Steve at OSE for ideas on the engine to use and he suggested a LEO 3674 2200KVwith an OSE Raider 6S 150 amp ESC. I found Darin Jordan's thread on the shaft improvements and will give it a go. Much appreciated!
