View Full Version : spacer
Notch-R
01-13-2022, 10:39 PM
how do i fill the gap when running after market props?
Alfa Spirit
01-14-2022, 06:52 AM
Use a nylstop screw, not this purple bullet.
Notch-R
01-14-2022, 09:22 AM
i use the screw then the bullet on the stock prop.the aftermarket has a shorter hub.174427
Notch-R
01-14-2022, 09:24 AM
why do the pictures post sidways?
NativePaul
01-14-2022, 04:21 PM
Use a piece of fuel/water cooling tube as a spacer.
Alfa Spirit
01-15-2022, 05:58 AM
You can reduce the flexshaft lenght.
Notch-R
01-15-2022, 09:54 AM
then the stock style prop won't work
Notch-R
01-16-2022, 02:07 PM
174435
Notch-R
01-16-2022, 02:08 PM
i need the spacer shown above
koen
01-19-2022, 06:07 AM
you can fill the gap with peek rings(it's a kind of teflon)it gives also no problem with the balance of the propshaft (tfl sells them)
Notch-R
01-20-2022, 12:40 AM
i found one here at the ose store
