anyone had problems with vr3?
  • minirio
    • Jan 2009
    • 5
    has anyone had problems with vr3? stock everything but might be running on 2's 1450 lipo's? also with x431 prop MAYBE!?!
  • Jim Bob
    • Nov 2008
    • 42
    I tried the same set-up and it melted the insulation on the 20guage wires and raosted the esc. TWICE.
    • Jesse J
      scale FE racer: Namba 826
      • Aug 2008
      • 7083
      whats vr3? I ran mine with 31mm prop and 2S lipo no prob - good run times and real quick
      "Look good doin' it"
      See the fleet
      • Jim Bob
        • Nov 2008
        • 42
        VR3 is the duratrax high rpm motor.
        • kaosjimmy03
          • May 2009
          • 4
          i have one on the way as well as a electrfly t400 and a speed 400 motor to try and ill let yall know which one i have a better outcome with also to mention im staying stock just prop change and motor
          jimmy
          • minirio
            • Jan 2009
            • 5
            ^could ya just chuck the 400 speed motor in it with stock everything and tell me if its faster then stock motor?
            cheers!!!
            • Skunk Works
              • 183
              I ran a vr3 with the stock setup and it got smoking hot, think it burned out the esc. Moved on to a brushless setup and it is much better. Will try the vr3 again in something different.....so far not impressed with the motor.
              Stay in front and don't get sprayed!
              • wparsons
                • 461
                I picked up a VR3 for a relatives boat, about 6 runs later a brush broke/disintegrated. Looking at brushless now.
                Light travels faster than sound, so people may appear to be bright until you hear them speak.
