View Full Version : UL-1 first observations
Flying Scotsman
01-28-2009, 01:20 PM
For a RTR boat very impressive out of the box
There were some minor problems...as properchopper advised me of..check the powertrain allignment...mine was off...check all fasteners...check the water jacket..mine was ok.
A minor crack in the fibreglass at the stuffing tube entry point into the hull.
Check rudder position in neutral position...mine was off.
I am amazed at the overall quality and fiinish at this price level.
I will paint the plastic white hull cover as it looks plastic and cheap.
So far a 7 out of 10.
Edit update
After reassembly the water jacket which was not removed and was given an air check now leaks badly with a water test at arround 50psi
Douggie
Darin Jordan
01-28-2009, 01:28 PM
Douggie,
When you say it's "off", are you talking about after firing it up??
When I disassembled mine, I took the pin out of the rudder to get the steering arm off (not a trivial task... which is good for racing... one less thing to worry about falling off! ;) )... The pin has flats in it for the set screws on the rudder and the steering arm, and they are NOT at 90-degrees to each other... So when everything is tightened down, the steering are will not be at a 90-degree angle to the rudder...
Still works fine, however...
Flying Scotsman
01-28-2009, 01:33 PM
Darin, you are correct as to off
Douggie
Darin Jordan
01-28-2009, 01:55 PM
Douggie
Just live with it then... I don't think there is anyway to correct that short of replacing the hinge-pin... I'll get some shots tonight to post of mine so you can see what I'm referring to...
Not a big deal, really... Just looks a little off...
Capt. Crash
01-28-2009, 02:10 PM
Douggie
Ok...how do I do this...what do I look for...how do I correct?
01-28-2009, 02:33 PM
The flex cable should slide right into the coupler as you feed it through the stuffing tube. If you adjust the strut much this will throw the motor/cable alignment out. I was able to bend the tube down a slight amount to bring it back into alignment with the coupler.
Flying Scotsman
01-28-2009, 02:43 PM
Captain Crash from the prop to the motor the shaft should be in line with each other and allow you to push the flex/wire shaft into the motor connector with no binding.
Douggie
Flying Scotsman
01-28-2009, 02:59 PM
Jay, your answer is much better than my feeble attempt.:smile:
Also, I will try Jay's resolution to the water jacket problem. As found in my edit
Douggie
detox
01-28-2009, 03:07 PM
I received my replacement water jacket from Aquacraft. The new end caps and housing have that same sloppy loose fit at the threads as before.
Capt. Crash
01-28-2009, 03:48 PM
Thanks...I had a bear getting that cable into the coupler last night...I thought it was the motor shaft being misaligned after I added a thrust bearing and remounted the motor. I will look at the stuffing tube tonight.
BTW...the motor mount bolts have very fine threads and strip out pretty easy...trust me...I know!
Crash
Darin Jordan
01-28-2009, 03:51 PM
Crash
Are you referring to the mounts where they bold to the hull, or the mount to the motor??
killjoy781
01-28-2009, 03:53 PM
should i not get the ul-1?
lol you guys are startin ta scare me.
Capt. Crash
01-28-2009, 04:00 PM
The motor casing. I turned the starboard one a little too far....now I have the magic blue liquid on the threads. :olleyes:
Flying Scotsman
01-28-2009, 04:04 PM
Killjoy. I trust that you enjoy your UL-1. As many FE boaters are very excited with this RTR model. What boats do you presently own and what is your RC experience...just currious?
Douggie
killjoy781
01-28-2009, 04:17 PM
Douggie
:rofl: i know,,,,im excited toooo! I CURRENTLY DO NOT OWN A BOAT...
*3 years racing & building rc cars (nitro)
*6mnths flying helis (electric)
*1 year miss elam (nitro) sucked because it had a 15 dynamite
*4 years ww2 planes (electric)
*2 years EDF
AND NOW IM READY FOR MY UL-1
I MUST ASK:::: WHAT ARE THE UPS AND DOWNS ABOUT THIS MODEL?
AM I ABLE TO USE A PAIR OF 2200MAH 20C's?
Capt. Crash
01-28-2009, 04:18 PM
Don't worry about us....I love the boat...get one and it will put a huge grin on your face the first time you squeeze the trigger!:bounce:
Flying Scotsman
01-28-2009, 04:21 PM
Enjoy and view the mod updates. Also look up the differences with nitro and FE boats on this and other FE forums. On your edit, yes you can use those batteries But the boat will not reach it's potential. Total available amperage. FE 101 logic
Douggie
killjoy781
01-28-2009, 04:29 PM
man i cant wait!!!!!!
where is the best place to buy one at? i think OSE is the answer....cheaper than towerhobbies.
has anyone of you ever orderd from here before? if so, how long did the shipping take to get to you?
Flying Scotsman
01-28-2009, 04:36 PM
Oh boy, I give up on twits,
Douggie
Grimracer
01-28-2009, 04:53 PM
We are just about done with the work on this.. hang tight..
I know.. boring blaha blaha blaha..just want it to work.. ME TOO!... none of this comes easy.. sorry and thanks for haning with us on this...
Grim
killjoy781
01-28-2009, 04:58 PM
Douggie
twits? hey thanks for 411 on the UL-1
egneg
01-28-2009, 05:03 PM
I have ordered quite a bit of stuff from OSE and although it was not this boat it has only taken 2 and at the most 3 days. And if there was any question Steve emailed me for clarification.
Chuck
Jeff Wohlt
01-28-2009, 05:05 PM
You have to take Douggie with...well valium if you have it :)
OSE is a great provider of parts and boats with top class service. As far as boats....you can read albout the many boats on this site. Some good reviews and some not so good. The nice thing is you will get help here from guys that know their stuff.
You want a good experience with your investment so ask questions and read posts about them before you buy.
Miss Ellam is nice boat and well put together...why not convert it to FE? Would not take much.
Flying Scotsman
Thank you Grim, for staying on top of minor issues. Jeff.... VALIUM.. NO.....THE FAMOUS GROUSE :bowdown: now you are talking :smile:
Douggie
killjoy781
01-28-2009, 05:06 PM
i have ordered quite a bit of stuff from ose and although it was not this boat it has only taken 2 and at the most 3 days. And if there was any question steve emailed me for clarification.
Chuck
thank you! That is awesome news to hear!
Do you guys think i should also get me a retrieval rc boat? Like a tug boat? Where is the best place to find such a model?
Flying Scotsman
01-28-2009, 05:25 PM
Yes, we all need some means of retrieaval!!
If you are serious, send me a pm and I will advise you of where to purchase the same boat, I use.
Douggie
Jeff Wohlt
01-28-2009, 05:35 PM
LOL...well I could not think of that so I used something stronger. My point was to make sure our new people feel the love ! :) Only females can be twits. Males are just good ol d----bags
egneg
01-28-2009, 05:52 PM
Douggie
Is that the same inflatable pool duck that Paddy uses?
Flying Scotsman
01-28-2009, 06:32 PM
Interesting Chuck no pm and no it is an awesome tug, that should get his juices running.
NB. It would be great to get back to the topic of this fine hull, warts and all
Douggie
killjoy781
01-28-2009, 07:47 PM
Douggie
how much do they range in price?
Jeff Wohlt
01-28-2009, 07:53 PM
I use my kids little z boat or whatever they call it. Even has a guard on the front for pushing. The hole thing was $79. I also have the walmart 2 person blow up raft I keep in the truck $19
If that does not work I send out the yellow Lab...I just hate the teeth marks in the hull she puts in it. :)
killjoy781
01-28-2009, 08:08 PM
lol no kidding thats awesome....well, i just dont want to get in the lake, ill have to find me a work boat under $40.00
Flying Scotsman
01-28-2009, 09:28 PM
Killjoy, as my pm stated Vac- U- Boat
http://www.vac-u-boat.com/
Doug Smock
01-28-2009, 10:21 PM
Yep, and ask Phil for the four blade prop.
Doug
Capt. Crash
01-29-2009, 08:07 AM
Aquacraft makes a great RTR tug that with a few mods can be made to be quite powerful and useful. It's bigger than the vac-u-tug but not too big to get in the car and carry around. I use mine to set and retrieve the marks and do rescue duty. It does it all...from fast boats, to planes, to snagging and dragging sailboats and even rescuing little girls balls.
alvinsmith75
01-29-2009, 08:45 AM
That just doesn't sound right.
"little girls balls"
Capt. Crash
01-29-2009, 02:03 PM
Yea...just think what would be said if I went with little boys instead...:eek:
Flying Scotsman
01-29-2009, 05:13 PM
I will be painting the hull cover as I previously mentioned. Those folks over in China must have strong wrists and hands.
The exhaust manifolds were stripped and glue was applied to correct the problem. All fasteners are over tightened except at the motor mount? Which was loose. Removing the flex connector took a lot of force.
Douggie
Capt. Crash
01-30-2009, 08:09 AM
Douggie
One of my manifolds were cracked from over torque and the motor housing to mount bolts were loose...be careful with them...they have very fine threads and strip out the housing threads fairly easy if you over tighten. My drive cable connector was also extremely tight as was the set screw.
Darin Jordan
01-30-2009, 10:32 AM
That's all interesting... Everything on mine came apart very easily...
Jeff Wohlt
01-30-2009, 12:48 PM
Guys, those issues are what QC is all about.. This is common when dealing with China.
sailr
01-30-2009, 01:11 PM
Grim,
My UL-1 is on order and should arrive in the next couple of days. Obviously the first thing I will check is the water jacket. Is AQ doing anything to replace the ones that leak with ones that don't? Just curious. Hate to have to go spend $15-20 for an aftermarket one that works.
Grim
Flying Scotsman
01-30-2009, 02:09 PM
In my humble oppinion buy a replacement water jacket.
Douggie
Grimracer
01-30-2009, 04:39 PM
Grim,
Dude.. honsitly i dont know.. but.. I will let you know when i know more..
I do know this.. when the time comes call Hobby Services and i will see to it that you get the updated parts.
Fear not the water jacket!...:rockon2:
Grim
sailr
01-31-2009, 10:49 AM
Thanks Mike. You da man!
Grim
