View Full Version : Tactic 2.4 radio mod info for 100% rev throttle
SweetZ28
01-22-2009, 10:17 AM
:thumbup1:Hi guy's this was asked on another board so i thought i would post it here for you guy's because the tactic radio the way it coms it don't have no way near 100% reverse throw travel on the trigger so here's a simple mod i did to give the radio 100% reverse also.
May want to keep this tacked up top in the board for further use.
Ok i tested the Tactic and it don't have 100% reverse...I tested it on my ESC as the new Tactic when installed in my slash in reverse the esc's full reverse light did not come on...so here is a mod i did to make the reverse throw on the trigger the normal 100% throw.
Hope this helps everyone.
http://static.rcgroups.com/forums/attachments/2/6/8/0/6/a2295374-228-a%20radio%20001.jpg
http://static.rcgroups.com/forums/attachments/2/6/8/0/6/a2295375-208-a%20radio%20002.jpg
http://static.rcgroups.com/forums/attachments/2/6/8/0/6/a2295376-81-a%20radio%20004.jpg
http://static.rcgroups.com/forums/attachments/2/6/8/0/6/a2295377-146-a%20radio%20006.jpg
Ub Hauled
01-22-2009, 12:05 PM
Usually on boats we don't use reverse at 100%,
actually, it should not be done so... one can sink the boat.
My advice is, if you must have reverse, setup enough just to get outta trouble,
up to 50%.
SweetZ28
01-22-2009, 01:16 PM
up to 50%.
Why not push reverse only a little back?
Also You can always do the mod and if you want less reverse slip a piece of silicone fuel line over the trigger so it won't push as far in reverse when using in a boat but lot's of guy's will be using these with there boats and other RC cars to this is why i posted the mod.
