hello, I have yet run my voracity boat because did not find a break away rudder for it, do you guys know of any that would fit??
Bushmen77
03-22-2021, 07:51 PM
You want to sell your boat? If so pm me.
Breakaway rudder.
I don’t have one to look at .
To make your rudder a breakaway you need one bolt and another hole .
If your rudder has two bolts take out the lower bolt. Go to ace hardware or home depo and buy a small copper screw and bolt . Don’t go bigger that 1/8 round . Tighten the top bolt pretty hard. Grab it with your han and make sure it will pivot with good force. It does not matter if the brass bolt is smaller then the hole just let it float in the lower hole. There you go should cast you less than a buck. No need to go buy anything.
