Fixitguy1
05-10-2020, 07:22 PM
I m using Giant Power 6000 70c-140 x4 batteries and Daboata 1815 props
The stock setting is 2.5mm wondering where I should be at with this set up
dasboata
05-11-2020, 03:58 PM
Is that 2.5 up or down,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, angle I presume ???????????????????
Fixitguy1
05-14-2020, 07:09 PM
That’s 2.5mm down for the stock setting
One respond was push batteries all the way up, drop the strut all the way down and hang on
MADRCER
05-14-2020, 10:07 PM
That?s 2.5mm down for the stock setting
Sounds like someone is trying to give you a setup to run on the Gulf of Mexico....The stock setting with batteries in the normal position sounds pretty good to me, if I was running on flat to semi flat water.
Fixitguy1
05-18-2020, 08:20 PM
Yeah I think that guy showed a picture of that boat after it flipped back over front and cart wheeled
I’m going to run it with the stock props and stock setting first to see what I have
Thanks
